    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 22.1k Views 8 Watching
    • H Offline
      hoddog
      Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
      foxF F 2 Replies Last reply Reply Quote 0
      • foxF Offline
        fox @hoddog
        @hoddog Here is my result: https://forum.magicmirror.builders/post/33238
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        • H Offline
          hoddog
          Should I wait for new update or install everything from beginning?
          • MichMichM Offline
            MichMich
            What you could try:
            • backup your module folder.
            • backup your config file
            • remove MagicMirror
            • reinstall
            • put modules & config back.
            F P 2 Replies Last reply Reply Quote 0
            • H Offline
              hoddog
              So i’ve used solution from here:
              https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
              For my not working modules.
              And it works. Mirror started… Huuuh.
              Thank you mr ryck!
              • F Offline
                Fonfon @hoddog
                @hoddog said in Update Error of v.2.2.0 :(:
                Same problem same modules
                solution ?
                • foxF Offline
                  fox
                  I did a complete reinstall. This was the last time that i did an Update of the Magic Mirror :)
                  This happend with every update till now.
                  • O Offline
                    open_book @bhepler
                    @bhepler @fox I had the same problem and followed the steps here to reinstall electron. It worked for me without further changes.
                    Thanks!
                    sudo insert motivational.quote
                    • F Offline
                      Fonfon @bhepler
                      • F Offline
                        Fonfon @MichMich
                        @MichMich Hi,
                        i backup my modules folder and my config folder
                        i delete MagicMirror folder
                        reinstall MagicMirror
                        copy/paste modules &config folders
                        i do that but same error on the same module
                        i don’t understand why
                        i need some help please
                        thanks
                        • F Offline
                          Fonfon
                          why update do that ?
                          need to reinstall all modules
                          now its good …
                            PRECIOUS VIRAL @MichMich
                            @MichMich How to solve this error?
                            pi@PrivatePiNetwork:~/MagicMirror $ git pull && npm install
                            Updating b799609…20823bf
                            error: Your local changes to the following files would be overwritten by merge:
                            fonts/package.json
                            modules/default/clock/clock.js
                            modules/default/currentweather/currentweather.js
                            modules/default/weatherforecast/README.md
                            Please, commit your changes or stash them before you can merge.
                            error: The following untracked working tree files would be overwritten by merge:
                            fonts/package-lock.json
                            package-lock.json
                            vendor/package-lock.json
                            Please move or remove them before you can merge.
                            Aborting
                              afedriansyah
                              hey I’ve been trying to install the magic mirror from https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash and once I clicked enter and this message appeared0_1546483547246_magicmirror.jpg
                              anyone any ideas how to solve this. a helpful answer and guide would be appreciated
                                SoleLo @open_book
                                @open_book How do you remove and reinstall the electron?
                                  shbatm Module Developer @afedriansyah
                                  @afedriansyah it looks like you already have it cloned to the directory, if you really really want to start fresh (WARNING WILL DELETE YOUR EXISTING INSTALLATION): rm -R ~/MagicMirror and then rerun the script. If you just want to upgrade, after the git pull, do npm install.
                                  Finally, I wouldn’t recommend running MM as root, unless you know what you’re doing…
                                    mdhenriksen @afedriansyah
                                    @afedriansyah I’ve read that there might be some issues with the automatic installer in the Pi. If you do a re-install and it doesn’t work, try a manual install. All the instructions are on the GitHub page. ☺️
