    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 23.7k Views 8 Watching
      bhepler Module Developer @fox
      @fox Did you try reinstalling electron via the instructions given? ie, delete /home/pi/MagicMirror/node_modules/electron and reinstalling?
      This should be close:
      cd /home/pi/MagicMirror/node_modules
      sudo rm -rf electron
      cd ..
      npm install electron@1.4.15
      After that, I suspect a npm install and then npm start.
      F O F 3 Replies Last reply Reply Quote 1
      • F Offline
        fox @bhepler
        @bhepler
        thank you for your reply.
        Everything worked until the last command.
        Then i got
        pi@magicpi:~/MagicMirror $ npm build && npm start
        > magicmirror@2.2.2 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.2.2
        Loading config ...
        Loading module helpers ...
        Module helper loaded: MMM-cryptocurrency
        Module helper loaded: MMM-Wunderlist
        Module helper loaded: MMM-ModuleScheduler
        WARNING! Could not load config file. Starting with default configuration. Error        found: Error: Module version mismatch. Expected 50, got 54.
        App threw an error during load
            at Error (native)
            at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
            at Object.Module._extensions..node (module.js:583:18)
            at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
            at Module.load (module.js:473:32)
            at tryModuleLoad (module.js:432:12)
            at Function.Module._load (module.js:424:3)
            at Module.require (module.js:483:17)
            at require (internal/module.js:20:19)
            at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindin        gs/bindings.js:76:44)
            at Error (native)
        MagicMirror will not quit, but it might be a good idea to check why this happene        d. Maybe no internet connection?
        If you think this really is an issue, please open an issue on GitHub: https://gi        thub.com/MichMich/MagicMirror/issues
        Launching application.
        But it does not start.
        I did also
        pi@magicpi:~/MagicMirror $ npm list | grep electron
        ├─┬ electron@1.4.15
        │ ├─┬ electron-download@3.3.0
        │ ├─┬ electron-chromedriver@1.7.1
        │ │ └─┬ electron-download@4.1.0
        │ │ │ └─┬ electron-to-chromium@1.3.30
        │ │ │   └── electron-releases@2.1.0
        pi@magicpi:~/MagicMirror $ npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
          This thread should help: https://forum.magicmirror.builders/post/7634
          • F Offline
            fox @bhepler
            @bhepler
            I tried the commands of the thread it, but no effect… Any help ?
            • H Offline
              hoddog
              Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
              F F 2 Replies Last reply Reply Quote 0
              • F Offline
                fox @hoddog
                @hoddog Here is my result: https://forum.magicmirror.builders/post/33238
                • H Offline
                  hoddog
                  Should I wait for new update or install everything from beginning?
                  • MichMichM Offline
                    MichMich
                    What you could try:
                    • backup your module folder.
                    • backup your config file
                    • remove MagicMirror
                    • reinstall
                    • put modules & config back.
                    F P 2 Replies Last reply Reply Quote 0
                    • H Offline
                      hoddog
                      So i’ve used solution from here:
                      https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
                      For my not working modules.
                      And it works. Mirror started… Huuuh.
                      Thank you mr ryck!
                      • F Offline
                        Fonfon @hoddog
                        @hoddog said in Update Error of v.2.2.0 :(:
                        Same problem same modules
                        solution ?
                        • F Offline
                          fox
                          I did a complete reinstall. This was the last time that i did an Update of the Magic Mirror :)
                          This happend with every update till now.
                          • O Offline
                            open_book @bhepler
                            @bhepler @fox I had the same problem and followed the steps here to reinstall electron. It worked for me without further changes.
                            Thanks!
                            sudo insert motivational.quote
                            • F Offline
                              Fonfon @bhepler
                              • F Offline
                                Fonfon @MichMich
                                @MichMich Hi,
                                i backup my modules folder and my config folder
                                i delete MagicMirror folder
                                reinstall MagicMirror
                                copy/paste modules &config folders
                                i do that but same error on the same module
                                i don’t understand why
                                i need some help please
                                thanks
                                • F Offline
                                  Fonfon
                                  why update do that ?
                                  need to reinstall all modules
                                  now its good …
                                    PRECIOUS VIRAL @MichMich
                                    @MichMich How to solve this error?
                                    pi@PrivatePiNetwork:~/MagicMirror $ git pull && npm install
                                    Updating b799609…20823bf
                                    error: Your local changes to the following files would be overwritten by merge:
                                    fonts/package.json
                                    modules/default/clock/clock.js
                                    modules/default/currentweather/currentweather.js
                                    modules/default/weatherforecast/README.md
                                    Please, commit your changes or stash them before you can merge.
                                    error: The following untracked working tree files would be overwritten by merge:
                                    fonts/package-lock.json
                                    package-lock.json
                                    vendor/package-lock.json
                                    Please move or remove them before you can merge.
                                    Aborting
                                      afedriansyah
                                      hey I’ve been trying to install the magic mirror from https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh | bash and once I clicked enter and this message appeared0_1546483547246_magicmirror.jpg
                                      anyone any ideas how to solve this. a helpful answer and guide would be appreciated
                                        SoleLo @open_book
                                        @open_book How do you remove and reinstall the electron?
                                          shbatm Module Developer @afedriansyah
                                          @afedriansyah it looks like you already have it cloned to the directory, if you really really want to start fresh (WARNING WILL DELETE YOUR EXISTING INSTALLATION): rm -R ~/MagicMirror and then rerun the script. If you just want to upgrade, after the git pull, do npm install.
                                          Finally, I wouldn’t recommend running MM as root, unless you know what you’re doing…
                                            mdhenriksen @afedriansyah
                                            @afedriansyah I’ve read that there might be some issues with the automatic installer in the Pi. If you do a re-install and it doesn’t work, try a manual install. All the instructions are on the GitHub page. ☺️
