    Update Error of v.2.2.0 :(
    21 Posts 11 Posters 21.8k Views 8 Watching
    • H Offline
      hoddog
      Same problem here. After yesterday’s update (git hub && npm install) two modules (MMM-PIR and MMM-MyCommute) has wrong version (except 50, got 48). After launching screen is just black. I’ve tried to update electron (npm rebuild --runtime=electron --target=1.4.15 --disturl=https://atom.io/download/atom-shell --abi=50)but nothing changed. How to start it?
      foxF F 2 Replies Last reply Reply Quote 0
      • foxF Offline
        fox @hoddog
        @hoddog Here is my result: https://forum.magicmirror.builders/post/33238
        Issues With MMM-WatchDog known?
        https://forum.magicmirror.builders/post/29827
        Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
        • H Offline
          hoddog
          Should I wait for new update or install everything from beginning?
          • MichMichM Offline
            MichMich
            What you could try:
            • backup your module folder.
            • backup your config file
            • remove MagicMirror
            • reinstall
            • put modules & config back.
            F P 2 Replies Last reply Reply Quote 0
            • H Offline
              hoddog
              So i’ve used solution from here:
              https://forum.magicmirror.builders/topic/6045/black-screen-after-install-update-v2-2?page=1
              For my not working modules.
              And it works. Mirror started… Huuuh.
              Thank you mr ryck!
              • F Offline
                Fonfon @hoddog
                @hoddog said in Update Error of v.2.2.0 :(:
                Same problem same modules
                solution ?
                • foxF Offline
                  fox
                  I did a complete reinstall. This was the last time that i did an Update of the Magic Mirror :)
                  This happend with every update till now.
                  • O Offline
                    open_book @bhepler
                    @bhepler @fox I had the same problem and followed the steps here to reinstall electron. It worked for me without further changes.
                    Thanks!
                    sudo insert motivational.quote
                    • F Offline
                      Fonfon @bhepler
                      • F Offline
                        Fonfon @MichMich
                        @MichMich Hi,
                        i backup my modules folder and my config folder
                        i delete MagicMirror folder
                        reinstall MagicMirror
                        copy/paste modules &config folders
                        i do that but same error on the same module
                        i don’t understand why
                        i need some help please
                        thanks
