    Downgrade Magic Mirror?
    14 Posts 6 Posters 10.8k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @chaseb1357
      @chaseb1357
      Rename your current MagicMirror folder to something else.
      Install the MM version of your choice.
      Move your modules into the new MagicMirror folder.
      Reply Quote 2
      • cowboysdudeC
        Stick of dynamite… hahahaahhha
        chaseb1357C 1 Reply Last reply
        • chaseb1357C
          chaseb1357 @cowboysdude
          @cowboysdude Thank you so much, it worked like a charm. After successfully welding an enclosure together to put the dynamite and RPi, I set it off. And BOOM! Magic Mirror is now running like a charm ;)
          • MichMichM
            MichMich
            Just curious. Why do you want to downgrade?
            • chaseb1357C
              chaseb1357 @MichMich
              @MichMich The only reason for me is I really love the ability to use the Remote Control module so I can easily remote access my mirrors. And I noticed in the new update that Http isn’t working, so I just want to go back to where I can remote access my mirrors.
              • cruunnerrC
                cruunnerr
                strange… i use the actual version and remote control is working. i even updated the mirror with the remote control module XD worked fine :)
                • chaseb1357C
                  chaseb1357 @cruunnerr
                  @cruunnerr that is strange indeed. I’m not sure what’s going on with my setup then. I mainly made this post because I discovered this one researching before posting: https://forum.magicmirror.builders/topic/5025/can-t-access-magic-mirror-via-http
                  • cruunnerrC
                    cruunnerr
                    well, i allowed to listen to all ip’s at all:
                    var config = {
                            address: "0.0.0.0", // Address to listen on, can be:
                                                  // - "localhost", "127.0.0.1", "::1" to listen on lo$
                                                  // - another specific IPv4/6 to listen on a specific$
                                                  // Default, when address config is left out, is "loc$
                            port: 8080,
                            ipWhitelist: [], // Set [] to allow all IP addresses
        // or add a specifi$
        // ["127.0.0.1", ":$
        // or IPv4 range of$
                    Maybe thats the reason. I had a few problems with just allowing single ip dresses so i went to this option. But works fine, and i have a hardware firewall installed in my network so i hope that this is enough^^
                    for external access i use VPN
                    • chaseb1357C
                      chaseb1357
                      Well what do you know. It works now! My old code was this and it worked fine on older versions:
                      	"ipWhitelist": [
                      		"127.0.0.1",
                      		"::ffff:127.0.0.1",
                      		"::1",
                      		"192.168.11.1/24",
                      		"::ffff:192.168.11.1/24"
                      But now that I put this it works fine, no need to downgrade now, much thanks:
                      	"address": "0.0.0.0",
                      	"ipWhitelist": [
                      • cruunnerrC
                        cruunnerr
                        great :)
                        first i tried it with “192.168.178.0/24”, too but couldn’t get it work. i read something about disabling IPv6 would help etc.
                        but however i am glad u got it working
                        • cowboysdudeC
                          cowboysdude Module Developer @chaseb1357
                          @chaseb1357 said in Downgrade Magic Mirror?:
                          HAHAHAHHHAHAHA Actually I just put 2.10 back on mine because well it works… LOL
                          • K
                            Kastore
                            Yes i know this topic is old, but it is spot on what i look for.
                            How do I downgrade to an older version.
                            I cant find any git pullcommand and the copy and paste and keep getting errors…
                            2.3 worked like a charm and 2.4 keeps producing errors for me that I cant fix due to my lack of knowledge
                            Mykle1M 1 Reply Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @Kastore
                              @kastore
                              https://github.com/MichMich/MagicMirror/releases
