Magic mirror Pi3 + Windows 7 1.60m x 0.60m
First of all, I want to thank all the contributors of this forum without whom I could not have created my mirror.
It has been about three months since I attended this forum silently to finally be able to present you my work.
I wanted to make a mirror to put it in my living room above a buffet.
The buffet being very long, it was necessary to create a mirror imposing enough to dress the wall.
So I left on dimensions of 1.60 meters by 0.60 meter.
This allowed me to go through a 32-inch screen.
having a home containing a lot of home automation (blinds, lights, heating, cameras, …) I wanted to be able to order some of my equipment thanks to the mirror.
So I started to install magic mirror on a raspberry pi 3. I started to have problems with the display of the cameras on magic mirror. Even with a 32-inch screen, there is a moment when all the modules you want to put have no place to display.
So, as I had room, I told myself that I could add a separate 19-inch screen for the cameras, on a Windows computer that I used to PVR.
so I insert in the mirror:
1 raspberry 3 for magic mirror
1 32-inch screen for the magic mirror1 acer veriton under windows 7 for cameras
1 19-inch screen for cameras.I started by mounting the frame. I wanted the mirror glass to be directly glued to the chassis with a 5 cm deflection to hide all the switches.
In addition, it was necessary that the 5 cm of the mirror is opaque because I wanted to put an LED strip for the light. so I had a special primer for car windshields.
For the mirror, I’m lucky to have a friend who works in a factory. So I could have a 6mm laminated glass spy mirror of 1.60 * 0.60 at a very good price.
I stuck the mirror on the chassis with windshield glue.
after all these explanations, place some photos:
![0_1514318123933_IMG_20171113_122408 [800x600].jpg](/assets/uploads/files/1514318125131-img_20171113_122408-800x600.jpg)
![0_1514318152778_IMG_20171113_122425 [800x600].jpg](/assets/uploads/files/1514318154046-img_20171113_122425-800x600.jpg)
![0_1514319896765_IMG_20171113_122439 [800x600].jpg](/assets/uploads/files/1514319898615-img_20171113_122439-800x600.jpg)
![0_1514319920981_IMG_20171114_165711 [800x600].jpg](/assets/uploads/files/1514319922163-img_20171114_165711-800x600.jpg)
![0_1514319966563_IMG_20171209_173620 [800x600].jpg](/assets/uploads/files/1514319967622-img_20171209_173620-800x600.jpg)
![0_1514320007094_IMG_20171215_170144 [800x600].jpg](/assets/uploads/files/1514320008915-img_20171215_170144-800x600.jpg)
![0_1514320150372_IMG_20171215_170205 [800x600].jpg](/assets/uploads/files/1514320151734-img_20171215_170205-800x600.jpg)
![0_1514320168388_IMG_20171215_170144 [800x600].jpg](/assets/uploads/files/1514320169203-img_20171215_170144-800x600.jpg)
![0_1514320225785_IMG_20171226_203457 [800x600].jpg](/assets/uploads/files/1514320226620-img_20171226_203457-800x600.jpg)
![0_1514320250573_IMG_20171226_203507 [800x600].jpg](/assets/uploads/files/1514320251408-img_20171226_203507-800x600.jpg)
![0_1514320280859_IMG_20171226_203518 [800x600].jpg](/assets/uploads/files/1514320281819-img_20171226_203518-800x600.jpg)
![0_1514320299634_IMG_20171226_203536 [800x600].jpg](/assets/uploads/files/1514320300414-img_20171226_203536-800x600.jpg)
I added to magic mirror the OPENJARVIS solution for voice control.I plugged a rf 433 module on the ft and I can ask the mirror to turn on the lights, to open the shutters.
With jarvis I can have the weather, the radio, the way … to the voice. I think it’s a good complement for magic mirror.
I installed the following modules:
[Remote-Control] Shutdown, Configure and Update your MagicMirror
Calendar Monthly
Calendar
My commute (x3)
Soccer live score
Soccer
World
Clock
Suncalc
Wunderground,
Newsfeed,
SnowI failed to install the following modules:
MMM-NOAA - Another Weather Module (each indicates standby but no info appears)
MMM-Jarvis-Voice-Control (the microphone does not appear on the magic mirror interface)Here…
I hope I have not been too long in the presentation.
Hoping that in my turn I can help forum members as you have helped me a lot.
PS: Sorry for the translation … Google translate is my friend;)
Very impressive!
Nice job!
Peter -
I dig it man! I really enjoy the story and the pictures. You’ve done an excellent job. Congratulations! :-)
looks really really nice. Well done! :D
Did you really just glued the mirror? i would be scared that the glass will fall…
Anyhow it looks great ! -
@Peter said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
Very impressive!
Nice job!
Peter@Mykle1 said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
Thank you for the compliments.
@cruunnerr said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
Anyhow it looks great !In fact, I glued the ice on the wooden frame using glue for automobile windshields.
For fixing to the wall, it is fixed thanks to specific fixing brackets.
![0_1514371439493_IMG_20171226_120915 [800x600].jpg](/assets/uploads/files/1514371440840-img_20171226_120915-800x600.jpg)
![0_1514371462179_IMG_20171227_113537 [800x600].jpg](/assets/uploads/files/1514371463971-img_20171227_113537-800x600.jpg)
Normally he should not move :)
This. Is. Awesome!
My jaw still hurts from when it fell to the ground of amazement :-O
Wow this is looking awesome, one of the best I have seen so far.
WOW very nice job!!! I don’t recall seeing you asking questions in the NOAA weather module forum…
@enettekoven said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
This. Is. Awesome!
@strawberry-3.141 said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
Thank you very much for the compliments.
@cowboysdude said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
In fact, I did not ask any questions on the subject. I tried by myself by reading all the posts.
However, I do not admit to being defeated … I was going to try to make it work again today.
I’ll go over the right topic to share the results.Regards,
@Chris said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
very nice work…
is the Jarvis working know … ?
thanks for the complimentDo you want to talk about the open-jarvis solution or the MMM-Jarvis-Voice-Control module?
For open-jarvis, it works very well and there are many plug-ins available.
By cons, I did not try to reinstall MMM-Jarvis-Voice-Control.I am fighting with MMM-Assistant right now … :s
Wooooooow! That one is really stunning :) congratulations, bravo, super!
Two question, what glue do you use? Brand or shop? And what did you use to cover the outer glass (leds)?
@schlachtkreuzer6 said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
Thank you for the compliments,@schlachtkreuzer6 said in Magic mirror Pi3 + Windows 7 1.60m x 0.60m:
3M glue with car windshield ref. 08603
And what did you use to cover the outer glass (leds)?!
3M hanging primer ref. 58012
For the frame, medium-type wood.
The thickness of the chassis depends on the size of the mirror,cordially
@Chris
Thanks for the detailed info!
