    (2.1.0) New default module: update notification.
    Scheduled Pinned Locked Moved Upcoming Features
    15 Posts 6 Posters 20.6k Views 6 Watching
      Jopyth Moderator @MichMich
      @MichMich Well, I start my mirror in the morning, and shut it down before going to sleep, so a notification at start up would be perfect for me. I even installed a “light” switch under my mirror to do that. But maybe this is really just me, I can implement this on my fork.
      • MichMichM
        MichMich
        But then still, after starting you would instantly see the message, right?
        J 1 Reply Last reply
          @MichMich Yes. Since the mirror is integrated into our wardrobe, with our shoes beneath it, I get ready for my morning run in front of it. So there I would notice the update notification (that was my original thought at least). But this is really not a big issue, the fixed message probably works fine as well.
          • L
            lolobyte @MichMich
            @MichMich
            hi, an where can i find this module?
            I recently install mm2 an there is no notification in the default modules.
            R 1 Reply Last reply
              roramirez Core Contributors @lolobyte
              @lolobyte Hi, you can find it into the develop branch.
              Please check out a clean clone
              git clone -b develop https://github.com/MichMich/MagicMirror.git
              Or using your MagicMirror code project
              git fetch
              git checkout develop
              L 1 Reply Last reply
              • L
                lolobyte @roramirez
                @roramirez
                Oh, great. Thanks a lot ramirez.
                I’m affraid about loosing my config and other things in mm2.
                Must i be affraid?
                  @lolobyte Prevent this with a copy backup your MagicMirror directory.
                  • L
                    lolobyte
                    Another question…
                    Is it possible to run a second instance of MM2?
                      Yes, use a different port for each instance in configuration file.
                      https://github.com/MichMich/MagicMirror/#configuration
                      • H
                        Hawking
                        If I’m not totally mistaken, this module does not only check for updates of MagicMirror itself but also all other used modules. Maybe one should make this clearer in the description/Readme. I was a bit surprised to suddenly see several git-remote-http-processes (for all my modules) in top.
