    (2.1.0) New default module: update notification.
    Scheduled Pinned Locked Moved Upcoming Features
    15 Posts 6 Posters 20.3k Views 6 Watching
    • MichMichM Offline
      MichMich
      The new default module updatenotification will display a message whenever a new version of the MagicMirror application is available. It will show the number of commits behind on the current branch and the name of the active branch.
      The new module is included in the new sample config. Make sure you add it to your own config if you want to add it:
          module: "updatenotification",
          position: "top_center"
      This module uses new default translations. Any pull requests with translation in other languages are welcome! (English and Dutch already included.)
      strawberry 3.141S L 2 Replies Last reply Reply Quote 3
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @MichMich
        @MichMich isn’t it like pushing down the other modules with the default module margin, if there is no update available?
        Firing an alert would make more sense to me.
        PS; german translation added
          Jopyth Moderator
          I like the idea, but as @strawberry-3-141 says, maybe a notification at start up would be good alternative? Or as an additional option, so if you do not set a position, you see the notification, and if you have a fixed position it does not show a notification.
          If it pushes other modules down, the module could just hide itself instead?
          @strawberry-3-141 Added some feedback on the translation.
          • MichMichM Offline
            MichMich
            Indeed, when hidden it is pushing down other modules. Will fix this in an upcoming release. (This is actually a core issue … When it’s hidden. It should not push other modules down.)
            I’m not a fan of an alert since these are very obstructive. In some cases you won’t have the time to immediately update. If we use notifications, these would stay in the way.
            Since most mirrors aren’t restarted very often, a message at start up would not make much sense.
            • MichMichM Offline
              MichMich
              Margin issue should be fixed now.
                Jopyth Moderator @MichMich
                @MichMich Well, I start my mirror in the morning, and shut it down before going to sleep, so a notification at start up would be perfect for me. I even installed a “light” switch under my mirror to do that. But maybe this is really just me, I can implement this on my fork.
                • MichMichM Offline
                  MichMich
                  But then still, after starting you would instantly see the message, right?
                    @MichMich Yes. Since the mirror is integrated into our wardrobe, with our shoes beneath it, I get ready for my morning run in front of it. So there I would notice the update notification (that was my original thought at least). But this is really not a big issue, the fixed message probably works fine as well.
                    • L Offline
                      lolobyte @MichMich
                      @MichMich
                      hi, an where can i find this module?
                      I recently install mm2 an there is no notification in the default modules.
                        roramirez Core Contributors @lolobyte
                        @lolobyte Hi, you can find it into the develop branch.
                        Please check out a clean clone
                        git clone -b develop https://github.com/MichMich/MagicMirror.git
                        Or using your MagicMirror code project
                        git fetch
                        git checkout develop
                        • L Offline
                          lolobyte @roramirez
                          @roramirez
                          Oh, great. Thanks a lot ramirez.
                          I’m affraid about loosing my config and other things in mm2.
                          Must i be affraid?
                            @lolobyte Prevent this with a copy backup your MagicMirror directory.
                            • L Offline
                              lolobyte
                              Another question…
                              Is it possible to run a second instance of MM2?
                                Yes, use a different port for each instance in configuration file.
                                https://github.com/MichMich/MagicMirror/#configuration
                                • H Offline
                                  Hawking
                                  If I’m not totally mistaken, this module does not only check for updates of MagicMirror itself but also all other used modules. Maybe one should make this clearer in the description/Readme. I was a bit surprised to suddenly see several git-remote-http-processes (for all my modules) in top.
