    (2.1.0) New default module: update notification.
    Scheduled Pinned Locked Moved Upcoming Features
    15 Posts 6 Posters 15.3k Views 6 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @MichMich
      @MichMich isn’t it like pushing down the other modules with the default module margin, if there is no update available?
      Firing an alert would make more sense to me.
      PS; german translation added
        Jopyth Moderator
        I like the idea, but as @strawberry-3-141 says, maybe a notification at start up would be good alternative? Or as an additional option, so if you do not set a position, you see the notification, and if you have a fixed position it does not show a notification.
        If it pushes other modules down, the module could just hide itself instead?
        @strawberry-3-141 Added some feedback on the translation.
        • MichMichM Offline
          MichMich
          Indeed, when hidden it is pushing down other modules. Will fix this in an upcoming release. (This is actually a core issue … When it’s hidden. It should not push other modules down.)
          I’m not a fan of an alert since these are very obstructive. In some cases you won’t have the time to immediately update. If we use notifications, these would stay in the way.
          Since most mirrors aren’t restarted very often, a message at start up would not make much sense.
          • MichMichM Offline
            MichMich
            Margin issue should be fixed now.
              Jopyth Moderator @MichMich
              @MichMich Well, I start my mirror in the morning, and shut it down before going to sleep, so a notification at start up would be perfect for me. I even installed a “light” switch under my mirror to do that. But maybe this is really just me, I can implement this on my fork.
              • MichMichM Offline
                MichMich
                But then still, after starting you would instantly see the message, right?
                  @MichMich Yes. Since the mirror is integrated into our wardrobe, with our shoes beneath it, I get ready for my morning run in front of it. So there I would notice the update notification (that was my original thought at least). But this is really not a big issue, the fixed message probably works fine as well.
                  • lolobyteL Offline
                    lolobyte @MichMich
                    @MichMich
                    hi, an where can i find this module?
                    I recently install mm2 an there is no notification in the default modules.
                      roramirez Core Contributors @lolobyte
                      @lolobyte Hi, you can find it into the develop branch.
                      Please check out a clean clone
                      git clone -b develop https://github.com/MichMich/MagicMirror.git
                      Or using your MagicMirror code project
                      git fetch
                      git checkout develop
                      lolobyteL 1 Reply Last reply Reply Quote 0
                      • lolobyteL Offline
                        lolobyte @roramirez
                        @roramirez
                        Oh, great. Thanks a lot ramirez.
                        I’m affraid about loosing my config and other things in mm2.
                        Must i be affraid?
                          @lolobyte Prevent this with a copy backup your MagicMirror directory.
                          • lolobyteL Offline
                            lolobyte
                            Another question…
                            Is it possible to run a second instance of MM2?
                              Yes, use a different port for each instance in configuration file.
                              https://github.com/MichMich/MagicMirror/#configuration
                              • H Offline
                                Hawking
                                If I’m not totally mistaken, this module does not only check for updates of MagicMirror itself but also all other used modules. Maybe one should make this clearer in the description/Readme. I was a bit surprised to suddenly see several git-remote-http-processes (for all my modules) in top.
