    (2.1.0) New default module: update notification.
    Scheduled Pinned Locked Moved Upcoming Features
    15 Posts 6 Posters 15.1k Views 6 Watching
    • MichMichM Offline
      MichMich
      Indeed, when hidden it is pushing down other modules. Will fix this in an upcoming release. (This is actually a core issue … When it’s hidden. It should not push other modules down.)
      I’m not a fan of an alert since these are very obstructive. In some cases you won’t have the time to immediately update. If we use notifications, these would stay in the way.
      Since most mirrors aren’t restarted very often, a message at start up would not make much sense.
      • MichMichM Offline
        MichMich
        Margin issue should be fixed now.
          Jopyth Moderator @MichMich
          @MichMich Well, I start my mirror in the morning, and shut it down before going to sleep, so a notification at start up would be perfect for me. I even installed a “light” switch under my mirror to do that. But maybe this is really just me, I can implement this on my fork.
          • MichMichM Offline
            MichMich
            But then still, after starting you would instantly see the message, right?
              @MichMich Yes. Since the mirror is integrated into our wardrobe, with our shoes beneath it, I get ready for my morning run in front of it. So there I would notice the update notification (that was my original thought at least). But this is really not a big issue, the fixed message probably works fine as well.
              • lolobyteL Offline
                lolobyte @MichMich
                @MichMich
                hi, an where can i find this module?
                I recently install mm2 an there is no notification in the default modules.
                  roramirez Core Contributors @lolobyte
                  @lolobyte Hi, you can find it into the develop branch.
                  Please check out a clean clone
                  git clone -b develop https://github.com/MichMich/MagicMirror.git
                  Or using your MagicMirror code project
                  git fetch
                  git checkout develop
                  lolobyteL 1 Reply Last reply Reply Quote 0
                  • lolobyteL Offline
                    lolobyte @roramirez
                    @roramirez
                    Oh, great. Thanks a lot ramirez.
                    I’m affraid about loosing my config and other things in mm2.
                    Must i be affraid?
                      @lolobyte Prevent this with a copy backup your MagicMirror directory.
                      • lolobyteL Offline
                        lolobyte
                        Another question…
                        Is it possible to run a second instance of MM2?
