    690 Posts 77 Posters 3.3m Views 70 Watching
    • cowboysdudeC
      Another example of how to change the current temp
      Here’s the css for your custom css if you like it:
      .MMM-NOAA .tempf {
      color: white;
      text-shadow: 1px 1px 2px black, 0 0 25px blue, 0 0 5px darkblue;
      Reply Quote 2
      • cowboysdudeC
        @Mykle1 awwwwwwwwwwwwwwwwwwwwwww olive juice…LMAO
          JoeFranz
          This looks very good with the temperature, great :-)
          However, I now only “night” displayed, although my station displays a UV value of 6 :-(
          • cowboysdudeC
            cowboysdude Module Developer @JoeFranz
            @JoeFranz Ok I will fix that! :)
            Do a git pull to update your files that should fix it for now.
            J 1 Reply Last reply
              JoeFranz @cowboysdude
              @cowboysdude UV is ok now, but still the moon is shining…
              tbbearT 1 Reply Last reply
              • tbbearT
                tbbear Module Developer @JoeFranz
                @JoeFranz Please do a git pull now and u will get a working version
                Robert the Bear
                  JoeFranz
                  Still the moon… :-(
                  • tbbearT
                    @JoeFranz sorry, but now its ok
                    Robert the Bear
                      JoeFranz @tbbear
                      @tbbear Sun ist shining… :-)
                      Thank you
                      • cowboysdudeC
                        Well hopefully the moon issue is solved :)
                        • cowboysdudeC
                          Description:
                          Update
                          1. Fixed American Alert system [see video] Will show alert with expiration date. If there are more than 1 warning will show the number of warnings in the Weather Warning header, again, see video.
                            https://www.youtube.com/watch?v=tZV-UKk6AWk
                          2. Added night to the forecast at top [now shows Day and Night] switches to night at 6 PM.
                          3. Cleaned up code
                          4. Moon works for ANY language.
                          Using custom css you can change header color like this …
                          .MMM-NOAA .rheading {
                          background-color: #868c88;
                          Putting this
                          display: none;
                          in your custom.css will net you this:
                          Version 1.2.0
                          Download:
                          [card:cowboysdude/MMM-NOAA]
                          Mykle1M 1 Reply Last reply
                          • Mykle1M
                            @cowboysdude
                            I’d appreciate it if you would stop making this module better and better and let some of us little guys get some air time. ;-)
                            https://www.youtube.com/watch?v=_cW4lW_KiIw
                            Reply Quote 3
                            • K
                              kbostick88
                              Hey guys, I cant get this module to show up on my mirror, can someone help me out?
                              Hey everyone, I am kind of new to this, but think i get the basics
                              I got the module installed by entering the following commands
                              cd MagicMirror/modules
                              git clone https://github.com/cowboysdude/MMM-NOAA.git
                              cd MMM-NOAA
                              npm install
                              I then did the config as follows
                              	module: 'MMM-NOAA',
                              	postition: 'top_left',
                              		apiKey: "4cc3880807c6aaa9",    // https://www.wunderground.com/weather/api  select the middle plan...
                              		airKey: "orBbd9wjdyTK6yp5R",    // IF you want Air Quality Index
                              		pws1: "KMIWESTL11" ,
                                                  loco1: "Detroit/Us",
                              Yet when it loads I dont see anything on my mirror
                              • tbbearT
                                tbbear Module Developer @kbostick88
                                @kbostick88 Hi, look at ur config its called position not postition only a little typing error
                                Robert the Bear
                                K 1 Reply Last reply
                                • K
                                  kbostick88 @tbbear
                                  @tbbear Thank you, I can’t believe I didn’t see that. Now it shows up! but I have NaN issues
                                  tbbearT 2 Replies Last reply
                                  • tbbearT
                                    @kbostick88 are u sure that ur keys are ok and also ur pws1. i will check them if u want
                                    Robert the Bear
                                    • tbbearT
                                      @kbostick88 Looks like ur pws1 is not correct, maybe again a typing error … -)
                                      Robert the Bear
                                      • K
                                        kbostick88
                                        I got it. Thanks!
                                        • tbbearT
                                          @kbostick88 your welcome
                                          Robert the Bear
                                          • K
                                            kbostick88 @tbbear
                                            @tbbear I am having issues with one other module also, any chance you might be able to help me with that one? I had the module working, but all of a sudden part of it seems broke. I get NaN on that one… its MMM-cryptocurrency
                                            Bitcoin works fine, ethereum, litecoin and ripple all show NaN but all 4 were working yesterday. not sure why they are not working now, nothing changed.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 34
                                            • 35
                                            • 18 / 35
