    690 Posts 77 Posters 3.3m Views 70 Watching
      JoeFranz
      This looks very good with the temperature, great :-)
      However, I now only “night” displayed, although my station displays a UV value of 6 :-(
      • cowboysdudeC
        cowboysdude Module Developer @JoeFranz
        @JoeFranz Ok I will fix that! :)
        Do a git pull to update your files that should fix it for now.
        J 1 Reply Last reply
          JoeFranz @cowboysdude
          @cowboysdude UV is ok now, but still the moon is shining…
          tbbearT 1 Reply Last reply
          • tbbearT
            tbbear Module Developer @JoeFranz
            @JoeFranz Please do a git pull now and u will get a working version
            Robert the Bear
              JoeFranz
              Still the moon… :-(
              • tbbearT
                @JoeFranz sorry, but now its ok
                Robert the Bear
                  JoeFranz @tbbear
                  @tbbear Sun ist shining… :-)
                  Thank you
                  • cowboysdudeC
                    Well hopefully the moon issue is solved :)
                    • cowboysdudeC
                      Description:
                      Update
                      1. Fixed American Alert system [see video] Will show alert with expiration date. If there are more than 1 warning will show the number of warnings in the Weather Warning header, again, see video.
                        https://www.youtube.com/watch?v=tZV-UKk6AWk
                      2. Added night to the forecast at top [now shows Day and Night] switches to night at 6 PM.
                      3. Cleaned up code
                      4. Moon works for ANY language.
                      Using custom css you can change header color like this …
                      .MMM-NOAA .rheading {
                      background-color: #868c88;
                      Putting this
                      display: none;
                      in your custom.css will net you this:
                      Version 1.2.0
                      Download:
                      [card:cowboysdude/MMM-NOAA]
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        @cowboysdude
                        I’d appreciate it if you would stop making this module better and better and let some of us little guys get some air time. ;-)
                        https://www.youtube.com/watch?v=_cW4lW_KiIw
                        Reply Quote 3
                        • K
                          kbostick88
                          Hey guys, I cant get this module to show up on my mirror, can someone help me out?
                          Hey everyone, I am kind of new to this, but think i get the basics
                          I got the module installed by entering the following commands
                          cd MagicMirror/modules
                          git clone https://github.com/cowboysdude/MMM-NOAA.git
                          cd MMM-NOAA
                          npm install
                          I then did the config as follows
                          	module: 'MMM-NOAA',
                          	postition: 'top_left',
                          		apiKey: "4cc3880807c6aaa9",    // https://www.wunderground.com/weather/api  select the middle plan...
                          		airKey: "orBbd9wjdyTK6yp5R",    // IF you want Air Quality Index
                          		pws1: "KMIWESTL11" ,
                                              loco1: "Detroit/Us",
                          Yet when it loads I dont see anything on my mirror
                          • tbbearT
                            tbbear Module Developer @kbostick88
                            @kbostick88 Hi, look at ur config its called position not postition only a little typing error
                            Robert the Bear
                            K 1 Reply Last reply
                            • K
                              kbostick88 @tbbear
                              @tbbear Thank you, I can’t believe I didn’t see that. Now it shows up! but I have NaN issues
                              tbbearT 2 Replies Last reply
                              • tbbearT
                                @kbostick88 are u sure that ur keys are ok and also ur pws1. i will check them if u want
                                Robert the Bear
                                • tbbearT
                                  @kbostick88 Looks like ur pws1 is not correct, maybe again a typing error … -)
                                  Robert the Bear
                                  • K
                                    kbostick88
                                    I got it. Thanks!
                                    • tbbearT
                                      @kbostick88 your welcome
                                      Robert the Bear
                                      • K
                                        kbostick88 @tbbear
                                        @tbbear I am having issues with one other module also, any chance you might be able to help me with that one? I had the module working, but all of a sudden part of it seems broke. I get NaN on that one… its MMM-cryptocurrency
                                        Bitcoin works fine, ethereum, litecoin and ripple all show NaN but all 4 were working yesterday. not sure why they are not working now, nothing changed.
                                        • tbbearT
                                          @kbostick88 sorry, i dont use any one of this modules. i would love to help u but i dont know the modules u are using. But maybe contact Mykle1 he is the best helper here. If u like the help i did for u maybe gimme a click on the ^ sign close to my answers.
                                          Robert the Bear
                                          • K
                                            kbostick88
                                            ok thanks, i posted it in the correct module so ill see if i can get it. Thanks for the help!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 34
                                            • 35
                                            • 18 / 35
