    MMM-MyCommute
    286 Posts 80 Posters 720.4k Views 77 Watching
      ATibbs @olexs
      @olexs Thanks for putting the work in, you did a great job. I too have showcalendarevents set to 3 and everything seems to be running fine. Thanks again.
      • pyrosmileyP Offline
        pyrosmiley @olexs
        @olexs Thanks a lot for that fork – it’s exactly what I needed for the mirror!
          aishaamila @j.e.f.f
          @j.e.f.f does this modules in Malaysia? Because i keep on getting syntax error so the config cannot be validated
            j.e.f.f Project Sponsor Module Developer @aishaamila
            @aishaamila I don’t see why it wouldn’t. Does google maps work for you just in your browser?
            If you can’t figure it out PM me and I’ll help you troubleshoot.
              AlexNY007
              Not sure everybody is aware of this but today when i was trying to deploy the module and then getting the APi i found out that Google now is requesting a billing account. Even has a $200 limit for use per month. Do you guys know if this is per project or per account? If so anybody recently created an account for this module? any hints will be appreciated.
              AlbinolanA 1 Reply Last reply Reply Quote 0
              • O Offline
                olexs
                Annoyingly enough, this is correct. Google is changing their Maps API access, and billing now needs to be set up for all uses of the API - including free tier. The 200$ limit is their free allowance, as long as you stay under that you don’t pay anything at all. Using only MMM-MyCommute should not even come close to that. But you still have to provide billing information, even if it’s never going to be used.
                I have updated my account and project that I use for MMM-MyCommute, and it works just fine.
                  AlexNY007 @olexs
                  @olexs yes. I read their last FAQ and basically its is what you said. Sorry if this sound stupid but, when you said MM-Commute should not come close to the allowance limit, do you mean that even if i have one project for em and my wife should not cost me a billing headache? I mean if i do something like this.
                  • O Offline
                    olexs @AlexNY007
                    @alexny007 Unless you have many (dozens) instances of the module running on the same account, it will stay far below the 200$ free tier limit, and it won’t cost you anything.
                    A 1 Reply Last reply Reply Quote 1
                      AlexNY007 @olexs
                      @olexs Thank you!!! looking forward to experiment with this module.
                      • AlbinolanA Offline
                        Albinolan @AlexNY007
                        @alexny007 I created my account last week, and was presented with the billing screen, however I somehow managed to set it up without actually giving any information, seems to be a bug when you have multiple tabs open, which allows you to bypass it. It says that I have one set up, but when I go to view its details, it asks me to enter them.
                          Jeffers1984
                          Hi everyone,
                          Hoping you can help me with a query I have! I am certainly no coder and I will probably use the wrong terminology, so I apologise in advance.
                          I have updated my Node.js to V10.4.0 since then and despite rebooting my Pi, MMM-MyCommute is no longer working. Does anyone have any suggestions as to why? here is my full config (I have removed all sensitive info).
                          var config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 24,
                          	units: "metric",
                          // ALERTS
                          			module: "alert",
                          // UPDATE NOTIFICATIONS
                          			module: "updatenotification",
                          			position: "top_bar"
                          // UPDATE CLOCK
                          			module: "clock",
                          			showWeek: true,
                          			timezone: "Etc/GMT",
                          			width: "200px"
                          // CALENDAR
                          			header: "Work Calendar",
                          						symbol: "calendar-check-o ",
                          						url: "...",
                          					//	maximumEntries: 3,
                          						maximumNumberOfDays: 3,
                          						timezone: "Etc/GMT-1",
                          // WEATHER
                          			module: "currentweather",
                          				locationID: "2634739", //Location ID from http://openweathermap.org/help/city_list.txt
                          				appid: "..."
                          // FORECAST
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          				appid: "..."
                          // NEWS
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          					title: "Everton FC",
                          					url: "feeds.evertonfc.com/everton-news?format=xml",
                          					title: "BBC Headline",
                          					url: "http://feeds.bbci.co.uk/news/rss.xml",
                          					title: "BBC Technology",
                          					url: "http://feeds.bbci.co.uk/news/technology/rss.xml",
                          					title: "BBC Science",
                          					url: "http://feeds.bbci.co.uk/news/science_and_environment/rss.xml",
                          				showSourceTitle: true,
                          				showPublishDate: true
                          // TRAFFIC
                                module: "MMM-MyCommute",
                                header: "Traffic",
                                classes: "default everyone",
                                disabled: false,
                                  apikey: ".",
                                  origin: "... ...",
                                  startTime: "00:00",
                                  endTime: "23:59",
                                  hideDays: [],
                                  showSummary: true,
                                  colorCodeTravelTime: true,
                                  moderateTimeThreshold: 1.1,
                                  poorTimeThreshold: 1.3,
                                  nextTransitVehicleDepartureFormat: "[next at] h:mm a",
                                  travelTimeFormat: "h [h] m [min]",
                                  travelTimeFormatTrim: "left",
                                  pollFrequency: 10 * 60 * 1000, //every ten minutes, in milliseconds
                                  destinations: [
                                      destination: "...",
                                      label: "Matt Work",
                                      mode: "driving",
                                      destination: "...",
                                      label: "Sarah Work",
                                      mode: "driving",
                                      destination: "...",
                                      label: "Nursery",
                                      mode: "driving",
                                      destination: "...",
                                      label: "... Community",
                                      mode: "driving",
                                      destination: "...",
                                      label: "Grandad Jeffs",
                                      mode: "driving",
                          Thanks,
                          EDIT:
                          I have done some more troubleshooting and notice that when I remove the MMM-MyCommute code from the Config above MagicMirror then starts fine?! Not sure if that does help at all! The terminal error is:
                          “WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.” but clearly the config file is there (as above), so must be a syntax error right?
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @Jeffers1984
                            @jeffers1984 you have two issues:
                                        mode: "driving",
                                        destination: "...",
                                        label: "Nursery",
                                        mode: "driving",
                                        destination: "...",
                            you start the block with label nursery with a closing instead of an opening bracket.
                            second issue is in the newsfeed you have duplicated feeds, because you created one object for all instead of one for each feed. Therefore you will only get the last newsfeed, if you want all you have to do:
                            feeds: [
                            I doubt that those issues are coming from the node 10 upgrade and it worked before :face_with_stuck-out_tongue_winking_eye:
                              Jeffers1984 @strawberry 3.141
                              @strawberry-3-141 ahh - now you say that… I did add the nursery route at the same time!
                              🙈 thanks for your help!! I will try and action your changes later!
                                • T Offline
                                  tbanzato
                                  • twosquirrelsT Offline
                                    twosquirrels
                                    Is this still working as designed? I reinstalled my magicmirror recently, and when I went to get this module working, it pointed me to get an API key at https://developers.google.com/maps/documentation/javascript/get-api-key which no longer appears to be free?
                                    This is all I had for my config previously, so I can’t find if/what my key previously was:
                                          module: 'MMM-MyCommute',
                                          position: 'top_left',
                                          header: 'Commute Times',
                                          classes: 'default everyone',
                                        travelTimeFormat: "h[h] m[m]"
                                    I don’t know how it even was working since it doesn’t have the API key, but it definitely was working fine for months.
                                    • K Offline
                                      Kecko
                                      so i need to pay for the google API or why do they want to know my creditcard or bankaccount…?
                                        j.e.f.f Project Sponsor Module Developer @Kecko
                                        @kecko Google changed the rules. As long as you are under a certain number of request, the. It’s still free. But if you go above that then you’ll automatically be billed. It used to be that you’d just get cut off at the threshold. I don’t remember exactly what the threshold is but I’m sure a quick search will turn it up.
                                        K 1 Reply Last reply Reply Quote 1
                                        • K Offline
                                          Kecko @j.e.f.f
                                          @j-e-f-f allright thanks for the info!
                                            binia
                                            Hi, thanks for the Module but i have a Problem with.
                                            I have add 4 Stations and sometime the Modul works for 2 Stations.
                                            But after 10 min i got a red Error on the working stations.
                                            Whats the Problem?
                                            Thanks.
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
