    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 526.5k Views 43 Watching
    • H Offline
      Henrik @fabbr
      @fabbr I’ve sent the details. Note that I did this a couple of months ago and there have been a minor change or two, like updated team logos, to the module since then.
        conkhidot
        Hey community,
        have anyone tried it with the new season 18/19 ?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @conkhidot
          @conkhidot I just saw that there is now a new api version and the current implementation will not work with the new season :/
          • foxF Offline
            fox
            From where do i get the ID of Bundesliga 2018 / 2019
            i dont understand the content
            https://www.football-data.org/documentation/quickstart
            Issues With MMM-WatchDog known?
            https://forum.magicmirror.builders/post/29827
            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
            • evroomE Offline
              evroom
              Was looking into that too.
              It looks like v1 is not working anymore:
              $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v1/competitions/'
              <html>
              <head><title>504 Gateway Time-out</title></head>
              <body bgcolor="white">
              <center><h1>504 Gateway Time-out</h1></center>
              <hr><center>nginx/1.6.2</center>
              </body>
              </html>
              Api v2 does work:
              $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v2/competitions/'
              {"count":145,"filters":{},"competitions":[{"id":2144,"area":{"id":2000,"name":"Afghanistan"},"name":"Playoffs 2/3","code":null,"plan":"TIER_FOUR","currentSeason":{"id":212,"startDate":"2018-05-22","endDate":"2018-05-27","currentMatchday":null},"numberOfAvailableSeasons":1,"lastUpdated":"2018-07-13T13:34:06Z"},{"id":2006,"area":{"id":2001,"name":"Africa"},"name":"WC Qualification","code":null,"plan":"TIER_FOUR","currentSeason":{"id":7,"startDate":"2015-10-07","endDate":"2017-11-14","currentMatchday":6},"numberOfAvailableSea............
              German Bundesliga would be id: 2002
              $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v2/competitions/2002'
              {"id":2002,"area":{"id":2088,"name":"Germany"},"name":"Bundesliga","code":null,"plan":"TIER_ONE","currentSeason":{"id":155,"startDate":"2018-08-24","endDate":"2019-05-18","currentMatchday":null},"seasons":[{"id":155,"startDate":"2018-08-24","endDate":"2019-05-18","currentMatchday":null},{"id":3,"startDate":"2017-08-18","endDate":"2018-05-21","currentMatchday":34},{"id":213,"startDate":"2016-08-26","endDate":"2017-05-20","currentMatchday":null},{"id":214,"startDate":"2015-08-14","endDate":"2016-05-14","currentMatchday":null},{"id":215,"startDate":"2013-08-09","endDate":"2014-05-10","currentMatchday":null},{"id":216,"startDate":"2012-08-24","endDate":"2013-05-18","currentMatchday":null},{"id":217,"startDate":"2011-08-05","endDate":"2012-05-05","currentMatchday":null},{"id":218,"startDate":"2010-08-20","endDate":"2011-05-14","currentMatchday":null},{"id":219,"startDate":"2009-08-07","endDate":"2010-05-08","currentMatchday":null},{"id":220,"startDate":"2008-08-15","endDate":"2009-05-23","currentMatchday":null},{"id":221,"startDate":"2007-08-10","endDate":"2008-05-17","currentMatchday":null},{"id":224,"startDate":"2006-08-11","endDate":"2007-05-19","currentMatchday":null},{"id":225,"startDate":"2005-08-05","endDate":"2006-05-13","currentMatchday":null},{"id":226,"startDate":"2004-08-06","endDate":"2005-05-21","currentMatchday":null},{"id":227,"startDate":"2003-08-01","endDate":"2004-05-22","currentMatchday":null},{"id":228,"startDate":"2002-08-09","endDate":"2003-05-24","currentMatchday":null},{"id":229,"startDate":"2001-07-28","endDate":"2002-05-04","currentMatchday":null},{"id":230,"startDate":"2000-08-11","endDate":"2001-05-19","currentMatchday":null},{"id":231,"startDate":"1999-08-13","endDate":"2000-05-20","currentMatchday":null},{"id":232,"startDate":"1998-08-14","endDate":"1999-05-29","currentMatchday":null},{"id":233,"startDate":"1997-08-01","endDate":"1998-05-09","currentMatchday":null},{"id":234,"startDate":"1996-08-16","endDate":"1997-05-31","currentMatchday":null}],"lastUpdated":"2018-06-05T00:10:05Z"}
              But unfortunately the v2 commands have a new syntax and probably different output, so the code would need a change.
              The changes are probably for the better:
              https://www.football-data.org/documentation/api#changelog
              but until someone spends some spare-time, we will have to do without it.
              MagicMirror version: 2.33.0
              Test environment:
              MagicMirror version: v2.33.0
              foxF 1 Reply Last reply Reply Quote 0
              • foxF Offline
                fox @evroom
                @evroom said in MMM-Soccer - Soccer Standings:
                <html>
                </body>
                </html>
                Api v2 does work:
                Yes that explains a lot. Now i understand that its not working. would be nice if the author would update it.
                  Mykle1 Project Sponsor Module Developer @fox
                  @fox said in MMM-Soccer - Soccer Standings:
                  Or, you can fork the repo, make the corrections yourself, and submit a PR to the author. :-)
                  • evroomE Offline
                    evroom
                    Maybe not nice for the author of MMM-Soccer, but I switched to MMM-SoccerLiveScore.
                    Have to wait for the competition to start to see how it really works, but the matches for August are already displayed.
                    I modified the api commands in MMM-Soccer to be compliant with v2, but could not get the parsing right.
                    Am a novice to JavaScript, CSS and JSON, so that was to be expected.
                    Test environment:
                      strawberry 3.141 Project Sponsor Module Developer @evroom
                      @evroom I would be more than happy, if you could try to investigate your parsing issues. In case I will find some time before my longer holidays in the states, I will try to change the api myself.
                      • evroomE Offline
                        evroom
                        @strawberry-3-141 ,
                        I will give it a try in the next days. Might have some questions though. As said, I am a novice to JavaScript and JSON, but fit in Perl. For the moment the biggest challenge is to have a programming / test environment setup. MM is running on a Pi and perhaps it is better to have a MM instance running on my MacBook. Or even better, to be able to test the module out of MM, if possible. Will report back asap on my progress, if any.
                        Test environment:
                        • 13
                        • 14
                        • 15
                        • 16
                        • 17
                        • 20
                        • 21
                        • 15 / 21
