    MMM-Soccer - Standings, Schedules and Top Scorers
    bundesligafootballmodalpremiere leagueprimiera divisionsoccervoice control
    209 Posts 43 Posters 578.0k Views 43 Watching
    • F
      fox
      From where do i get the ID of Bundesliga 2018 / 2019
      i dont understand the content
      https://www.football-data.org/documentation/quickstart
      Issues With MMM-WatchDog known?
      https://forum.magicmirror.builders/post/29827
      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
      • evroomE
        evroom
        Was looking into that too.
        It looks like v1 is not working anymore:
        $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v1/competitions/'
        <html>
        <head><title>504 Gateway Time-out</title></head>
        <body bgcolor="white">
        <center><h1>504 Gateway Time-out</h1></center>
        <hr><center>nginx/1.6.2</center>
        </body>
        </html>
        Api v2 does work:
        $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v2/competitions/'
        {"count":145,"filters":{},"competitions":[{"id":2144,"area":{"id":2000,"name":"Afghanistan"},"name":"Playoffs 2/3","code":null,"plan":"TIER_FOUR","currentSeason":{"id":212,"startDate":"2018-05-22","endDate":"2018-05-27","currentMatchday":null},"numberOfAvailableSeasons":1,"lastUpdated":"2018-07-13T13:34:06Z"},{"id":2006,"area":{"id":2001,"name":"Africa"},"name":"WC Qualification","code":null,"plan":"TIER_FOUR","currentSeason":{"id":7,"startDate":"2015-10-07","endDate":"2017-11-14","currentMatchday":6},"numberOfAvailableSea............
        German Bundesliga would be id: 2002
        $ curl -H 'X-Auth-Token:(apikey)' 'http://api.football-data.org/v2/competitions/2002'
        {"id":2002,"area":{"id":2088,"name":"Germany"},"name":"Bundesliga","code":null,"plan":"TIER_ONE","currentSeason":{"id":155,"startDate":"2018-08-24","endDate":"2019-05-18","currentMatchday":null},"seasons":[{"id":155,"startDate":"2018-08-24","endDate":"2019-05-18","currentMatchday":null},{"id":3,"startDate":"2017-08-18","endDate":"2018-05-21","currentMatchday":34},{"id":213,"startDate":"2016-08-26","endDate":"2017-05-20","currentMatchday":null},{"id":214,"startDate":"2015-08-14","endDate":"2016-05-14","currentMatchday":null},{"id":215,"startDate":"2013-08-09","endDate":"2014-05-10","currentMatchday":null},{"id":216,"startDate":"2012-08-24","endDate":"2013-05-18","currentMatchday":null},{"id":217,"startDate":"2011-08-05","endDate":"2012-05-05","currentMatchday":null},{"id":218,"startDate":"2010-08-20","endDate":"2011-05-14","currentMatchday":null},{"id":219,"startDate":"2009-08-07","endDate":"2010-05-08","currentMatchday":null},{"id":220,"startDate":"2008-08-15","endDate":"2009-05-23","currentMatchday":null},{"id":221,"startDate":"2007-08-10","endDate":"2008-05-17","currentMatchday":null},{"id":224,"startDate":"2006-08-11","endDate":"2007-05-19","currentMatchday":null},{"id":225,"startDate":"2005-08-05","endDate":"2006-05-13","currentMatchday":null},{"id":226,"startDate":"2004-08-06","endDate":"2005-05-21","currentMatchday":null},{"id":227,"startDate":"2003-08-01","endDate":"2004-05-22","currentMatchday":null},{"id":228,"startDate":"2002-08-09","endDate":"2003-05-24","currentMatchday":null},{"id":229,"startDate":"2001-07-28","endDate":"2002-05-04","currentMatchday":null},{"id":230,"startDate":"2000-08-11","endDate":"2001-05-19","currentMatchday":null},{"id":231,"startDate":"1999-08-13","endDate":"2000-05-20","currentMatchday":null},{"id":232,"startDate":"1998-08-14","endDate":"1999-05-29","currentMatchday":null},{"id":233,"startDate":"1997-08-01","endDate":"1998-05-09","currentMatchday":null},{"id":234,"startDate":"1996-08-16","endDate":"1997-05-31","currentMatchday":null}],"lastUpdated":"2018-06-05T00:10:05Z"}
        But unfortunately the v2 commands have a new syntax and probably different output, so the code would need a change.
        The changes are probably for the better:
        https://www.football-data.org/documentation/api#changelog
        but until someone spends some spare-time, we will have to do without it.
        MagicMirror version: 2.37.0
        • F
          fox @evroom
          @evroom said in MMM-Soccer - Soccer Standings:
          <html>
          </body>
          </html>
          Api v2 does work:
          Yes that explains a lot. Now i understand that its not working. would be nice if the author would update it.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @fox
            @fox said in MMM-Soccer - Soccer Standings:
            Or, you can fork the repo, make the corrections yourself, and submit a PR to the author. :-)
            • evroomE
              evroom
              Maybe not nice for the author of MMM-Soccer, but I switched to MMM-SoccerLiveScore.
              Have to wait for the competition to start to see how it really works, but the matches for August are already displayed.
              I modified the api commands in MMM-Soccer to be compliant with v2, but could not get the parsing right.
              Am a novice to JavaScript, CSS and JSON, so that was to be expected.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @evroom
                @evroom I would be more than happy, if you could try to investigate your parsing issues. In case I will find some time before my longer holidays in the states, I will try to change the api myself.
                • evroomE
                  evroom
                  @strawberry-3-141 ,
                  I will give it a try in the next days. Might have some questions though. As said, I am a novice to JavaScript and JSON, but fit in Perl. For the moment the biggest challenge is to have a programming / test environment setup. MM is running on a Pi and perhaps it is better to have a MM instance running on my MacBook. Or even better, to be able to test the module out of MM, if possible. Will report back asap on my progress, if any.
                  • evroomE
                    evroom
                    It looks like I mixed up things.
                    You have:
                    MMM-soccer: uses api.football-data.org - api v1
                    MagicMirror-FootballLeagues: api.football-data.org - api v1
                    MMM-SoccerLiveScore: uses www.ta4-images.de
                    Modules using api.football-data.org - api v1 - are not working and that leaves MMM-SoccerLiveScore as the only module working at this moment.
                    Now … I promised to have a look at MMM-Soccer, which is MMM-soccer (small detail), to see if I can get v2 working.
                    So I started with github (never used it before) and got MM working on my MacBook.
                    Stupidly I got a copy of MMM-SoccerLiveScore and was surprised to see it working.
                    Only then I realised that my comments were based on MagicMirror-FootballLeagues and not on MMM-Soccer.
                    Not even speaking about MMM-SoccerLiveScore.
                    Probably the heat-wave melted my brains, or what was left of it.
                    What to do ?
                    On the one hand we have MMM-SoccerLiveScore.
                    Install it. Configure it. Run it. Go with it.
                    Nothing needed.
                    I have it running myself.
                    Then we have MMM-soccer and MagicMirror-FootballLeagues.
                    Both need to be adapted to run with api v2.
                    MagicMirror-FootballLeagues, owner @master117, looks to be more up-to-date and a better start than MMM-soccer.
                    It says to be a spin.off of MMM-SoccerLiveScore, but I do not know exactly why.
                    And I do not know if an adapted MagicMirror-FootballLeagues will have more possibilities over the other(s).
                    I might give it a try, just for the fun of it.
                    strawberry 3.141S 1 Reply Last reply Reply Quote 1
                    • strawberry 3.141S
                      @evroom I never heard of footballleagues.
                      When I’m correct then soccerlivescroe display the matches and this module display the standings so the modules follow different approaches.
                      • evroomE
                        evroom
                        Both modules display matches and standings.
                        https://github.com/master117/MagicMirror-FootballLeagues
                        https://github.com/LukeSkywalker92/MMM-SoccerLiveScore
                        Differences might be in the extra possibilities of the api and therefore additional possibilities for the module.
                        For example football-data.org v2 can show you the squad.
                        • strawberry 3.141S
                          I updated the module to work with api v2. One problem that I figured out so far is that the api no longer provides links to the club logos, therefore I added a config option logos to hide them.
                          It’s under construction and can be tested on the develop branch
                          git checkout develop
                          [card:fewieden/MMM-soccer]
                          • evroomE
                            evroom
                            @strawberry-3-141 ,
                            I have it running. Added “NETHERLANDS”, 2003.
                            I found out that v1 is still available, but only for pre-World Cup stuff.
                            But that means you can use v1 for the logos:
                            http://api.football-data.org/v1/teams/57
                            http://upload.wikimedia.org/wikipedia/en/5/53/Arsenal_FC.svg
                            You could add a separate league number_league name_team_logo.json file, with a collection of team logos.
                            Per league, per team.
                            Then users can add missing logos themselves and perhaps share their collection with you to be put on github.
                            Just an idea.
                            In the meantime I will try to contact the football-data.org person to ask what happened to the logos in v2.
                            Hope you are not offended when I say that SoccerLiveScore has it all.
                            Except for 2 things that are unique for your module:
                            focus and number of teams to show on the table.
                            Cannot say if the sources of data is equally well maintained, so cannot say if it is worth the trouble of coding, unless it brings you pleasure.
                            • strawberry 3.141S
                              @evroom well we had problems in v1 already that logos were taken down due to copyrights and I sent the api owner updated links, that were never added, so I don’t think that it will come back in v2. For the same reason I also don’t want to host the files on github. I think mostly the german league was the problem, why I added a logic to overwrite broken image links from the api.
                              It looked like this:
                              		'CLUBNAME': 'https://CLUBLOGO.svg'
                              if you want to start collecting the logo links in an object where the key is the club name then i can add them to my list. But I don’t have the time to do so myself.
                              • evroomE
                                evroom
                                @strawberry-3-141 ,
                                Thanks for the background info.
                                Did not know it was an issue before, but then again I am a novice MM user.
                                Time and mood is always an issue.
                                Better for cold evenings or weekends, not when it is 35 degrees and having spent 8 hours behind a PC in a relatively hot office 😀
                                • strawberry 3.141S
                                  I just released version 2 of this module
                                  Added
                                  • Club logo downloader
                                  • New config option logos.
                                  • Swedish translations
                                  • Doclets.io integration
                                  • Contributing guidelines
                                  • Issue template
                                  • Pull request template
                                  • Editor config
                                  Changed
                                  • Switched from Api v1 to v2.
                                  • Updated league ids.
                                  • Switched rendering from js to nunjuck template.
                                  • Updated travis-ci config.
                                  • Disabled markdown lint rules MD024 and MD026
                                  • evroomE
                                    evroom
                                    Great job on version 2.0.
                                    I have it running.
                                    Added Eredivisie and some logos; all fine.
                                    Just one question.
                                    In your example your header is left aligned and shows “1. BUNDESLIGA 2015/16”.
                                    Not updated to show the version 2.0 example.
                                    When I choose the Bundesliga I just get “BUNDESLIGA” and it is right aligned.
                                    How do I get it at least left aligned ?
                                    I tried adding this to the custom.css, but it doesn’t work:
                                    .MMM-soccer .header {
                                        text-align: left;
                                    • strawberry 3.141S
                                      @evroom your try was pretty close, the correct one is
                                      .MMM-soccer header {
                                         text-align: left;
                                      the header is not a class, but a tag, that’s why you don’t have a leading . there.
                                      It also depends on the position of the module, if you have it e.g. in top_left it’s automatically on the left.
                                      • evroomE
                                        evroom
                                        @strawberry-3-141
                                        Thanks, works like a charm.
                                        Any possibility to introduce a rotation option, in order to rotate the standings of the leagues in “show” or “leagues” ?
                                        • strawberry 3.141S
                                          @evroom rotation is currently only supported for voice
                                            surger13 Project Sponsor
                                            I cant get it to work again, not even with the new version.
                                            Where is the mistake?
                                            module: "MMM-soccer",
                                            			disabled: false,
                                            			position: "bottom_left",
                                            			header: "",
                                            				colored: true,
                                            				show: 'GERMANY',
                                            				logos: false,
                                            				focus_on: {
                                            					"GERMANY": "Erzgebirge Aue"
                                            				max_teams: 5,
                                            				leagues: {
                                            					"GERMANY": "BL2",
                                            • 10
                                            • 11
                                            • 8 / 11
