    My Custom Smart Mirror.
    28 Posts 12 Posters 35.5k Views 13 Watching
    • SubLim3S Offline
      SubLim3
      OK, UPDATE: I have continued to program on the Magic Mirror and although it doesn’t look like it, the last few weeks of programming have paid off. I have added Module Schedules and Timers. At night (from 6pm till 4am) it will display Moon Phases. I also added a network scanner that tells me when my kids Xbox or Tablets are online. I caught them once playing in the middle of the night LoL.
      I have also built an Android app that lets me control the mirror using the MMM-Remote-Control. I can turn Modules on and off, turn the mirror on and off, update the modules and reboot the whole system. Pretty handy when I am showing it off.
      Lastly, to get in the Halloween Spirit I added some scary backgrounds that fade in and out at random. True story, I got good and drunk the night I decided to add these wallpapers. During the middle of the night I get up to go to the bathroom and Scared The Hell out of Myself when I walked past my mirror and saw the Nun!
      • E Offline
        electros Project Sponsor
        Hi, can you tell me please if your android app work from internet or just in local network ? And maybe you can share that app with us please ? Thanks.
        SubLim3S 1 Reply Last reply Reply Quote 0
        • SubLim3S Offline
          SubLim3 @electros
          @electros
          The app is only a wrapper pointing to my mirror at http://192.168.1.222:8080/remote.html. This is only able to be done as I have statically assigned my mirror as the .222 address. I could run a port forward on my firewall and allow it to work from outside the house but I haven’t got a need to since I wouldn’t be standing in view of the mirror and it’s a security vulnerability. Let me know if you have further questions.
          • azscramA Offline
            azscram
            Nicely done.
            Is that the PIR Sensor at the top of the mirror?
            • SubLim3S Offline
              SubLim3 @azscram
              @azscram
              No, that was my Echo Dot. The PIR is somewhat visible in the second picture. There is a small ribbon cable going from the Pi to the PIR. It’s on the right side so anytime I want it on I just wave my hand on right of the mirror. It’s incredibly sensitive so I never have a problem waking it up.
              I am in process of adding a PS3 Eye cam and using MMM-Hotword and MMM-AssistantMk2. Might even go as far as training facial recognition.
              1 Reply Last reply Reply Quote -1
                dawees
                nice setup. one question what module did u use for background ? I have MMM-EasyPix but do not know how to put pic to fullscreen. Can you share your config ?
                  Mykle1 Project Sponsor Module Developer @dawees
                  @dawees
                  You could use MMM-EasyPix as a background module but that is really not its purpose. Just try this module.
                  https://github.com/mykle1/MMM-EasyBack
                    dawees
                    thanks works better :)
                      @dawees said in My Custom Smart Mirror.:
                      thanks works better
                      Fantastic! Enjoy! :-)
                      • SubLim3S Offline
                        SubLim3
                        I use MMM-BackgroundSlideshow. Here is list of my modules:
                        Update: MMM-BackgroundSlideshow stopped working for me so I switched to MMM-EasyBack.
                        • H Offline
                          hannes23
                          Looks realy great, good work!
                          What monitor did you use? Mine is bleeding it’s backlight through the mirror, which isn’t the case with your screen, according to the pictures.
                          • SubLim3S Offline
                            SubLim3 @hannes23
                            @hannes23 So long as the light in front of the mirror is brighter than the monitor behind the mirror it won’t bleed through. I am using an old LCD screen I had lying around but an OLED would produce the best results as the black on those is truly black. I only get bleed through when I turn the light off in my room. If the light is on, all looks good.
                              MadScientist
                              A mirror with a higher transmission should also reduce the backlight bleeding since you won’t have to increase the brightness as much, creating a better black and therefore having better contrast.
                                PaulB
                                Dear @SubLim3 the none looks cool. Well done :) Cool mirror. Where did hang it? Hope you guys enjoys it :)
                                Many Greetings from Germany,
                                Paul
                                • K Offline
                                  kass
                                  Hello! I have one question! The only type of mirror that you used in that project was the two-way mirror, right? I’m asking this because I’m looking to put 2 types of mirror: a two way one only for the monitor (because it’s a 17 inch 4:3 one and it’s small) and the rest will be just a simple mirror. Thanks in advance and also great project. Good luck.
                                  • Y Offline
                                    yawns Moderator @kass
                                    @kass said in My Custom Smart Mirror.:
                                    You don’t need to do that. Use one big mirror glass, place the monitor wherever you want to and make sure the entire rest of the mirror is covered with black foil, black cardboard or something similar. As long as no light from the back reached the area of the mirror glass it works like a mirror and you cannot “look behind”. Only the area which is lit up by the monitor will be see through.
                                    • SubLim3S Offline
                                      SubLim3
                                      YET ANOTHER UPDATE: I have gone through and added a few more modules to include MMM_AssistantMK2, MMM_AlexaOnOff and MMM-Screencast. Having the embedded Google assistant in the mirror helps get additional information when I see something about weather or my calendar. Having AlexaOnOff helps when I want to vocally turn the mirror on/off or even reboot or update. I use the screen cast occasionally to play fitness videos while correcting my form. I even added a much larger list of compliments including ones specific to weather that everyone tends to enjoy.
                                      Lastly, I added the WatchDog module which has really helped stabilize the mirror. I recommend anyone running this on a Pi to have this module. This has been at times challenging but remains on of my favorite projects and gets used daily. I hope everyone enjoys theirs as much as I enjoy mine.
                                        dazza120 @SubLim3
                                        @SubLim3 in what way has Watchdog stabilised the mirror with a pi?
                                        • SubLim3S Offline
                                          SubLim3 @dazza120
                                          @dazza120 I never determined why but my mirror would “hide all modules” regularly. I would constantly wake up or notice that the screen was on but not displaying anything. A restart of MM would resolve but since running WatchDog this hasn’t been the case. It’s like services stopped working and WatchDog is supposed to restart any services that stop. I installed WatchDog at the same time I updated to the latest MM build so it could be coincidental.
                                            dazza120 @SubLim3
                                            @SubLim3 ok cool, may have to look at this but for now I’ve upgraded to the Pi4 4Gb, I think the main issue with the pi is memory and holding onto memory once a service loads.
