    [MMM-Rainbow] Animated text color transition
    34 Posts 8 Posters 21.1k Views 8 Watching
      Seann Module Developer
      MMM-Rainbow - Animated text color transition.
      Update info: As suggested, I have added the option to assign the random colors to specific modules or to all modules. See the config below to see how to use.
      Preview
      Modular
      Non-Modular
      Installation
      Installation is very simple, just clone the git into your modules directory then add the module to your config.
      cd ~/MagicMirror/modules
      git clone https://github.com/aSeann/MMM-Rainbow
      Using the module
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      var config = {
      		module: "MMM-Rainbow",
      		/*	Position not required as it has no UI.	*/
      			fadeTime: 1500,		//	Duration in milliseconds it takes for the color to fade.
      			nextColor: 1500,	//	Duration in milliseconds until the next random color is generated and set.
      			modular: false,		//
      			moduleList: [		//	Only required if modular is true.
      				"MMM-iClock",
      				"MMM-Showtimes"
      Mykle1M 1 Reply Last reply Reply Quote 6
        Mykle1 Project Sponsor Module Developer @Seann
        @seann
        Kinda cool. :-)
          Seann Module Developer @Mykle1
          @mykle1 Thanks, I didn’t actually expect any response to this. I have started experimenting with other things though, so expect to see a few more posts from me. :grinning_face:
            @seann
            The more, the merrier. When I started this I never expected anyone to even look at my work. You never know what others might find interesting. My motto: Have fun!
            • G Offline
              ganget
              I really like the idea of this module, I’m searching for the possibility to make only my clock have this effect and maybe a gradient kind of color shift. Can you help me with this idea?
              S cowboysdudeC 2 Replies Last reply Reply Quote 0
                Seann Module Developer @ganget
                @ganget Sure man, seems simple enough. You could always customize the clock module, or recreate your own and just add a class name to the clock, then alter MMM-Rainbow.js to only change the css for that module. I cheated when creating this module by using jQuery so it’s really simple to mess with. But if you do need any help, feel free to give me a message.
                G 1 Reply Last reply Reply Quote 1
                • BKeyportB Online
                  BKeyport Module Developer
                  Love the concept, actually. Would love to see it limited to the user’s choice of modules, however.
                    Mykle1 Project Sponsor Module Developer @BKeyport
                    MMM-NOAA3 has been doing this for some time now, as an option
                    BKeyportB 1 Reply Last reply Reply Quote 1
                    • BKeyportB Online
                      BKeyport Module Developer @Mykle1
                      @mykle1 doing what? I was referring to the original rainbow color. Would be cool to apply it to modules of choice.
                        @bkeyport said in [MMM-Rainbow] Animated text color transition:
                        Lets see. The topic states “[MMM-Rainbow] Animated text color transition” so I guess I was talking about that. Only noticed you because you mentioned me directly. I think @seann has done a fantastic job here. Joined the forum 8 days ago and already he’s contributing and offering his
                        help to others. He and I are going get along just fine. :-)
                        • BKeyportB Online
                          So, you’re saying the NOAA weather app does rainbow colors for other modules?
                          … Okay.
                            Seann Module Developer @BKeyport
                            @bkeyport Also, this is easily done. I’ll work on this for you when I have some more free time. The only issue with doing it to the clock is; the current clock uses “updateDom” to set the time each second, which from what I have seen basically re creates the elements. Meaning the transitions start from when the element is created so it’s not in time with the other transitions. So it would be easier to create your own clock module which just replaces the innerHTML of each element instead of re creating them. I have been making my own clock which will display down to minutes instead of seconds as i’m sure this would cause less strain on my terrible Pi 3 a+.
                            • BKeyportB Online
                              Actually, I’d be more interested in the mechanics in getting it to work down to the module level more than anything, would be nice to use it for say “Grabbing Attention” in a particular module…
                              • G Offline
                                ganget @Seann
                                @seann I took a different approach to this, mainly because I only wanted to have it for only one module. I have changed my custom.css and one line in the clock.js, so it grabs a different style.
                                My code makes a gradient background which I clip to the text. Then to make it move across the text i use webkit-animation. I’m not totally satisfied with the result of the animation yet but i will keep tweaking that.
                                the animation moves way too fast now and when I make the animation duration longer it doesn’t feature all the colors of the gradient.
                                the only line i needed to change in the clock.js file
                                timeWrapper.className = "time clock-time-only-color large light";
                                Custom.css (lines i added)
                                .clock-time-only-color {
                                	background-image: linear-gradient(to right, #ff0000,#ff4000,#ff8000,#ffbf00,#ffff00,#bfff00,#80ff00,#40ff00,#00ff00,#00ff40,#00ff80,#00ffbf,#00ffff,#00bfff,#0080ff,#0040ff,#0000ff,#4000ff,#8000ff,#bf00ff,#ff00ff,#ff00bf,#ff0080,#ff0040,#ff0000);
                                	-webkit-background-clip:  text;
                                	-webkit-animation: animate 3s linear infinite;
                                	background-size: 500%;
                                	color: transparent;
                                @-webkit-keyframes animate{
                                	0%	{background-position: 0% 500%;}
                                	50%	{background-position: 100% 0%;}
                                	100%    {background-position: 0% 100%;}
                                Do you have any idea on how I can make the animation duration way longer like 10 min and still show all the colors in the gradient?
                                Thank you for the initial idea and for inspiring me!
                                S justjim1220J 2 Replies Last reply Reply Quote 0
                                  @ganget I’m not really that good with css animations but from what I can see,
                                  should have something to do with it right? maybe if you make that 10 minutes instead.
                                  • G Offline
                                    ganget @Seann
                                    @seann yeah i tried increasing the number to like 20 sec up to 6000. But the problem i get then is that it shows me only the first 2 colors in the gradient. Dunno but will try and work on it tomorrow
                                    • justjim1220J Offline
                                      justjim1220 Module Developer @ganget
                                      @ganget
                                      change your background size to 20% instead of 500%
                                      Only other issue I find is that it refreshes itself every second, would be better if it were more fluid-like that the refresh isn’t so notice-able.
                                      "Life's Too Short To Dance With Ugly People"
                                      Jim Hallock - 1995
                                        @ganget & @BKeyport
                                        So, I modified my MMM-DigClock with your rainbow css with some other tweaks…
                                        .MMM-DigClock .time {
                                          font-size: 300px;
                                          text-align: center;
                                          line-height: 85%;
                                          letter-spacing: 5px;
                                          font-weight: 900;
                                          font-family: DS-Digital;
                                          background: -webkit-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                          background: -moz-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                          background: -o-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                          background: linear-gradient(to left, red,orange,yellow,green,blue,purple);
                                          -moz-background-clip: text;
                                          -webkit-animation: animate 10s linear infinite;
                                          -moz-animation: animate 10s linear infinite;
                                          -o-animation: animate 10s linear infinite;
                                          background-size: 25%;
                                          -webkit-text-fill-color: transparent;
                                        And it seems to work fairly decent.
                                        But I had to change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
                                        // Schedule update interval.
                                        		var self = this;
                                        		setInterval(function() {
                                        			self.updateDom();
                                        		}, 60000);
                                        Jim Hallock - 1995
                                          justjim1220 Module Developer @Seann
                                          @seann
                                          you can change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
                                              var self = this;
                                          	self.updateDom();
                                              }, 60000);
                                          Jim Hallock - 1995
                                          G S 2 Replies Last reply Reply Quote 0
                                          • G Offline
                                            ganget @justjim1220
                                            @justjim1220 Good tip man! I will change the update interval and look at the difference.
