    [MMM-Rainbow] Animated text color transition
    34 Posts 8 Posters 24.6k Views 8 Watching
    • G
      ganget
      I really like the idea of this module, I’m searching for the possibility to make only my clock have this effect and maybe a gradient kind of color shift. Can you help me with this idea?
      S cowboysdudeC 2 Replies Last reply
        Seann Module Developer @ganget
        @ganget Sure man, seems simple enough. You could always customize the clock module, or recreate your own and just add a class name to the clock, then alter MMM-Rainbow.js to only change the css for that module. I cheated when creating this module by using jQuery so it’s really simple to mess with. But if you do need any help, feel free to give me a message.
        G 1 Reply Last reply
        • BKeyportB
          BKeyport Module Developer
          Love the concept, actually. Would love to see it limited to the user’s choice of modules, however.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @BKeyport
            MMM-NOAA3 has been doing this for some time now, as an option
            BKeyportB 1 Reply Last reply
            • BKeyportB
              BKeyport Module Developer @Mykle1
              @mykle1 doing what? I was referring to the original rainbow color. Would be cool to apply it to modules of choice.
              • Mykle1M
                @bkeyport said in [MMM-Rainbow] Animated text color transition:
                Lets see. The topic states “[MMM-Rainbow] Animated text color transition” so I guess I was talking about that. Only noticed you because you mentioned me directly. I think @seann has done a fantastic job here. Joined the forum 8 days ago and already he’s contributing and offering his
                help to others. He and I are going get along just fine. :-)
                • BKeyportB
                  So, you’re saying the NOAA weather app does rainbow colors for other modules?
                  … Okay.
                    Seann Module Developer @BKeyport
                    @bkeyport Also, this is easily done. I’ll work on this for you when I have some more free time. The only issue with doing it to the clock is; the current clock uses “updateDom” to set the time each second, which from what I have seen basically re creates the elements. Meaning the transitions start from when the element is created so it’s not in time with the other transitions. So it would be easier to create your own clock module which just replaces the innerHTML of each element instead of re creating them. I have been making my own clock which will display down to minutes instead of seconds as i’m sure this would cause less strain on my terrible Pi 3 a+.
                    justjim1220J 1 Reply Last reply
                    • BKeyportB
                      Actually, I’d be more interested in the mechanics in getting it to work down to the module level more than anything, would be nice to use it for say “Grabbing Attention” in a particular module…
                      • G
                        ganget @Seann
                        @seann I took a different approach to this, mainly because I only wanted to have it for only one module. I have changed my custom.css and one line in the clock.js, so it grabs a different style.
                        My code makes a gradient background which I clip to the text. Then to make it move across the text i use webkit-animation. I’m not totally satisfied with the result of the animation yet but i will keep tweaking that.
                        the animation moves way too fast now and when I make the animation duration longer it doesn’t feature all the colors of the gradient.
                        the only line i needed to change in the clock.js file
                        timeWrapper.className = "time clock-time-only-color large light";
                        Custom.css (lines i added)
                        .clock-time-only-color {
                        	background-image: linear-gradient(to right, #ff0000,#ff4000,#ff8000,#ffbf00,#ffff00,#bfff00,#80ff00,#40ff00,#00ff00,#00ff40,#00ff80,#00ffbf,#00ffff,#00bfff,#0080ff,#0040ff,#0000ff,#4000ff,#8000ff,#bf00ff,#ff00ff,#ff00bf,#ff0080,#ff0040,#ff0000);
                        	-webkit-background-clip:  text;
                        	-webkit-animation: animate 3s linear infinite;
                        	background-size: 500%;
                        	color: transparent;
                        @-webkit-keyframes animate{
                        	0%	{background-position: 0% 500%;}
                        	50%	{background-position: 100% 0%;}
                        	100%    {background-position: 0% 100%;}
                        Do you have any idea on how I can make the animation duration way longer like 10 min and still show all the colors in the gradient?
                        Thank you for the initial idea and for inspiring me!
                        S justjim1220J 2 Replies Last reply
                          @ganget I’m not really that good with css animations but from what I can see,
                          should have something to do with it right? maybe if you make that 10 minutes instead.
                          • G
                            ganget @Seann
                            @seann yeah i tried increasing the number to like 20 sec up to 6000. But the problem i get then is that it shows me only the first 2 colors in the gradient. Dunno but will try and work on it tomorrow
                            • justjim1220J
                              justjim1220 Module Developer @ganget
                              @ganget
                              change your background size to 20% instead of 500%
                              Only other issue I find is that it refreshes itself every second, would be better if it were more fluid-like that the refresh isn’t so notice-able.
                              Jim Hallock - 1995
                              • justjim1220J
                                @ganget & @BKeyport
                                So, I modified my MMM-DigClock with your rainbow css with some other tweaks…
                                .MMM-DigClock .time {
                                  font-size: 300px;
                                  text-align: center;
                                  line-height: 85%;
                                  letter-spacing: 5px;
                                  font-weight: 900;
                                  font-family: DS-Digital;
                                  background: -webkit-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                  background: -moz-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                  background: -o-linear-gradient(left, red,orange,yellow,green,blue,purple);
                                  background: linear-gradient(to left, red,orange,yellow,green,blue,purple);
                                  -moz-background-clip: text;
                                  -webkit-animation: animate 10s linear infinite;
                                  -moz-animation: animate 10s linear infinite;
                                  -o-animation: animate 10s linear infinite;
                                  background-size: 25%;
                                  -webkit-text-fill-color: transparent;
                                And it seems to work fairly decent.
                                But I had to change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
                                // Schedule update interval.
                                		var self = this;
                                		setInterval(function() {
                                			self.updateDom();
                                		}, 60000);
                                Jim Hallock - 1995
                                • justjim1220J
                                  justjim1220 Module Developer @Seann
                                  @seann
                                  you can change the update interval within the clock code to update every minute instead of every second, by placing the following within the start: function() …
                                      var self = this;
                                  	self.updateDom();
                                      }, 60000);
                                  Jim Hallock - 1995
                                  G S 2 Replies Last reply
                                  • G
                                    ganget @justjim1220
                                    @justjim1220 Good tip man! I will change the update interval and look at the difference.
                                    • G
                                      ganget @ganget
                                      @justjim1220 I changed the update interval to 60 sec and that makes it work allot better. I kept the background size at 500% so the color gradient won’t repeat.
                                      	background-image: linear-gradient(to left, red,orange,yellow,green,blue,purple);
                                      	-webkit-animation: animate 60s linear infinite;
                                      	color: transparent;
                                      	100%	{background-position: 500% 0%;}
                                      The result
                                      Thanks for your help!
                                        Seann Module Developer @justjim1220
                                        @justjim1220 Say if you start your mirror at 30 seconds past the minute, the clock on the mirror wont update until 30 seconds past the next minute, that’s why I created my own clock
                                        • justjim1220J
                                          @seann was you able to get past the every second update?
                                          Jim Hallock - 1995
                                          • justjim1220J
                                            @ganget Does it show every color?
                                            Jim Hallock - 1995
