    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr
      @Rec3ptor
      If u followed the guide i posted, your PIGPIOD installation path should be “/usr/local/bin/pigpiod”
      For autostart when booting u must edit the rc.local. Mine is like this:
      pi@MagicMirror:~ $ cat /etc/rc.local
      #!/bin/sh -e
      # rc.local
      # This script is executed at the end of each multiuser runlevel.
      # Make sure that the script will "exit 0" on success or any other
      # value on error.
      # In order to enable or disable this script just change the execution
      # bits.
      # By default this script does nothing.
      # Print the IP address
      _IP=$(hostname -I) || true
      if [ "$_IP" ]; then
        printf "My IP address is %s\n" "$_IP"
      fi
      iwconfig wlan0 power off &
      sleep 5 &
      sleep 10 &
      /usr/bin/python /home/pi/pir.py &
      exit 0
      So enter this via ssh:
      sudo nano /etc/rc.local
      and just put this into the file:
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @cruunnerr
        @cruunnerr
        My nickname for you:
        King Cron
        :thumbsup:
        • T
          teitlebot @richland007
          @richland007 This wont be helpful but I will say I had a similar problem a few months back but now it works. Must be some configuration that changed in the mean time on my pi but I dont know what.
            bolish
            Hello there,
            I’m currently planning my project and will integrate PIR sensor + related 2.1 method through HDMI.There is one thing confusing me :
            • we talk about HDMI CEC in method 2.1
            • nevertheless, it seems the PIR Sensor module is “only” turning HDMI output off and that is triggering "issues such as “powersaving / no input”.
            But is HDMI CEC not allowing us to send a “turn screen off” command to the monitor instead of disabling the rasp. HDMIoutput and relying / hoping on the monitor’s behaviour?
            Sorry once more if I mssed the point, but would like to understand before moving forward.
            Regards
              sdetweil @bolish
              @bolish said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
              as I understand it, not many monitors/tv’s provide support for external power off/on commands…
              none of my TV’s used for MM support this…
              B 1 Reply Last reply
                bolish @sdetweil
                @sdetweil Maybe you’re right! I didn’t considered that.
                But seems possible, correct? By changing the actual commands to the ones defined by the libcec librairy?
                  sdetweil @bolish
                  @bolish I do not know… as I said, none of my TVs support ANY commands to turn off/on…
                  in my MMM-SleepWake module, I use module.hide() to hide everything, leaving a blank screen… for those devices that do not provide external control…
                    bolish
                    OK, I will then try myself when I will receive my stuff and let forums knows if working or not.
                      chandra
                      @cruunnerr ,
                      Thank you very much for the detailed write up. As a beginner, i could follow the steps. I used the 2.1 Using PIR-Module. Its working well.
                      Few questions,
                      Now trying to connect LED strip-
                      1. should i remove the module from the config?
                      2. Or 2.2 Using PIR-script will work simultaneously?
                        I read your following post, But, can you help me how to implement all?
                      @cruunnerr said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                      In my Case I am using a RGB 5050 Stripe. I am using three pins with mosfets and for the software part PIGPIOD.
                      Just like that: https://dordnung.de/raspberrypi-ledstrip/
                      Here are my scripts:
                      monitor on:
                      vcgencmd display_power 1
                      pigs p 17 1
                      pigs p 22 1
                      pigs p 24 1
                      sleep 0.06s
                      pigs p 17 2
                      pigs p 22 2
                      pigs p 24 2
                      sleep 0.06s
                      pigs p 17 3
                      pigs p 22 3
                      pigs p 24 3
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 5
                      pigs p 22 5
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 6
                      pigs p 22 6
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 7
                      pigs p 22 7
                      pigs p 24 6
                      sleep 0.06s
                      pigs p 17 8
                      pigs p 22 8
                      pigs p 24 7
                      sleep 0.06s
                      pigs p 17 9
                      pigs p 22 9
                      pigs p 24 8
                      sleep 0.06s
                      pigs p 17 10
                      pigs p 22 10
                      pigs p 24 9
                      sleep 0.06s
                      pigs p 17 11
                      pigs p 22 11
                      pigs p 24 10
                      sleep 0.06s
                      pigs p 17 12
                      pigs p 22 12
                      pigs p 24 11
                      Monitor off:
                      pigs p 17 12
                      pigs p 22 12
                      pigs p 24 11
                      sleep 0.06s
                      pigs p 17 11
                      pigs p 22 11
                      pigs p 24 10
                      sleep 0.06s
                      pigs p 17 10
                      pigs p 22 10
                      pigs p 24 9
                      sleep 0.06s
                      pigs p 17 9
                      pigs p 22 9
                      pigs p 24 8
                      sleep 0.06s
                      pigs p 17 8
                      pigs p 22 8
                      pigs p 24 7
                      sleep 0.06s
                      pigs p 17 7
                      pigs p 22 7
                      pigs p 24 6
                      sleep 0.06s
                      pigs p 17 6
                      pigs p 22 6
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 5
                      pigs p 22 5
                      pigs p 24 5
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 4
                      pigs p 22 4
                      pigs p 24 4
                      sleep 0.06s
                      pigs p 17 3
                      pigs p 22 3
                      pigs p 24 3
                      sleep 0.06s
                      pigs p 17 2
                      pigs p 22 2
                      pigs p 24 2
                      vcgencmd display_power 0
                      sleep 0.06s
                      pigs p 17 1
                      pigs p 22 1
                      pigs p 24 1
                      sleep 0.06s
                      pigs p 17 0
                      pigs p 22 0
                      pigs p 24 0
                        chandra @cruunnerr
                        Sure, my pir.py is the same as shown on point 2.2 but with other GPIO used
                        #!/usr/bin/env python
                        import sys
                        import time
                        import RPi.GPIO as io
                        import subprocess
                        import pigpio
                        io.setmode(io.BCM)
                        SHUTOFF_DELAY = 119 # seconds
                        PIR_PIN = 25       # 22 on the board
                        LED_PIN = 16
                        def main():
                            io.setup(PIR_PIN, io.IN)
                            io.setup(LED_PIN, io.OUT)
                            turned_off = False
                            last_motion_time = time.time()
                            while True:
                                if io.input(PIR_PIN):
                                    io.output(LED_PIN, io.LOW)
                                    print ".",
                                    sys.stdout.flush()
                                    if turned_off:
                                        turned_off = False
                                        turn_on()
                                else:
                                    if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                        turned_off = True
                                        turn_off()
                                    if not turned_off and time.time() > (last_motion_time + 1):
                                        io.output(LED_PIN, io.HIGH)
                                time.sleep(.1)
                        def turn_on():
                                subprocess.call("sh /home/pi/lights_on.sh", shell=True)
                        def turn_off():
                                subprocess.call("sh /home/pi/lights_off.sh", shell=True)
                        if __name__ == '__main__':
                            try:
                                main()
                            except KeyboardInterrupt:
                                io.cleanup()
                        Because i use some LED Stripes which turn on when the pir detects movement my “monitor_on.sh” is called “lights_on.sh”
                        lights_on.sh:
                        pigs p 17 1
                        pigs p 22 1
                        pigs p 24 1
                        sleep 0.06s
                        pigs p 17 2
                        pigs p 22 2
                        pigs p 24 2
                        sleep 0.06s
                        pigs p 17 3
                        pigs p 22 3
                        pigs p 24 3
                        sleep 0.06s
                        pigs p 17 4
                        pigs p 22 4
                        pigs p 24 4
                        sleep 0.06s
                        pigs p 17 5
                        pigs p 22 5
                        pigs p 24 5
                        sleep 0.06s
                        pigs p 17 6
                        pigs p 22 6
                        pigs p 24 5
                        sleep 0.06s
                        pigs p 17 7
                        pigs p 22 7
                        pigs p 24 6
                        sleep 0.06s
                        pigs p 17 8
                        pigs p 22 8
                        pigs p 24 7
                        sleep 0.06s
                        pigs p 17 9
                        pigs p 22 9
                        pigs p 24 8
                        sleep 0.06s
                        pigs p 17 10
                        pigs p 22 10
                        pigs p 24 9
                        sleep 0.06s
                        pigs p 17 11
                        pigs p 22 11
                        pigs p 24 10
                        sleep 0.06s
                        pigs p 17 12
                        pigs p 22 12
                        pigs p 24 11
                        lights_off.sh:
                        pigs p 17 12
                        pigs p 22 12
                        pigs p 24 11
                        sleep 0.06s
                        pigs p 17 11
                        pigs p 22 11
                        pigs p 24 10
                        sleep 0.06s
                        pigs p 17 10
                        pigs p 22 10
                        pigs p 24 9
                        sleep 0.06s
                        pigs p 17 9
                        pigs p 22 9
                        pigs p 24 8
                        sleep 0.06s
                        pigs p 17 8
                        pigs p 22 8
                        pigs p 24 7
                        sleep 0.06s
                        pigs p 17 7
                        pigs p 22 7
                        pigs p 24 6
                        sleep 0.06s
                        pigs p 17 6
                        pigs p 22 6
                        pigs p 24 5
                        sleep 0.06s
                        pigs p 17 5
                        pigs p 22 5
                        pigs p 24 5
                        sleep 0.06s
                        pigs p 17 4
                        pigs p 22 4
                        pigs p 24 4
                        sleep 0.06s
                        pigs p 17 4
                        pigs p 22 4
                        pigs p 24 4
                        sleep 0.06s
                        pigs p 17 3
                        pigs p 22 3
                        pigs p 24 3
                        sleep 0.06s
                        pigs p 17 2
                        pigs p 22 2
                        pigs p 24 2
                        sleep 0.06s
                        pigs p 17 1
                        pigs p 22 1
                        pigs p 24 1
                        sleep 0.06s
                        pigs p 17 0
                        pigs p 22 0
                        pigs p 24 0
                        But what exactly doesn’t work with my script? Maybe i can help :)
                        Got this ( https://dordnung.de/raspberrypi-ledstrip/) working successfully on another raspberry running stretch.
                        now going to try this on Magicmirror. But i got confused, because PIR sensor is on GPIO22 and the same GPIO22 is used in led strip (5050).
                        Can you guide , which GPIO to be assigned?
                          sdetweil @chandra
                          @chandra move one to a different GPIO pin and change the config as required for that
                          C 1 Reply Last reply
                            chandra @sdetweil
                            @sdetweil said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                            thank you, but as i mentioned, i’m just a beginner. just copying and pasting.:face_with_stuck-out_tongue_winking_eye:
                            So lets fix led on GPIO22 and move PIR to another.
                            • cruunnerrC
                              cruunnerr
                              I am glad, you got it :)
                              As you can see i used PIN 25 for the PIR and 17,22,24 for the LED’s.
                              Keep in mind, that the physical GPIO Number isn’t the same as with BCM numbering !!! Thats important!
                              In the script (line 9) u can see that it uses the BCM Numbering. That means the following:
                              BCM pin 17 = physical PIN 11
                              BCM pin 22 = physical PIN 15
                              BCM pin 24 = physical PIN 18
                              BCM pin 25 = physical PIN 22
                              So the LED’s must be connected with physical PIN 11,15,18 and the PIR on PIN 22.
                              Hope that was clear ^^
                              My english isn’t very well.
                              S C 2 Replies Last reply
                                sdetweil @cruunnerr
                                @cruunnerr yeh, don’t know why use the BCM ever… use the actual pin numbers… hurts my head trying to figure out the pin mappings…
                                https://raspberrypi.stackexchange.com/questions/12966/what-is-the-difference-between-board-and-bcm-for-gpio-pin-numbering
                                io.setmode(io.BOARD) instead of io.setmode(io.BCM)
                                  chandra @cruunnerr
                                  Yup, I connected like that. There is a problem. Disabled the PIR Module.
                                  Screen goes off after 120sec, But when it sense the motion, the screen is black.
                                  My magicmirror is not set to “auto start” , I use “cd ~/MagicMirror
                                  DISPLAY=:0 npm start”.
                                  “python pir.py” is working properly. I used the steps described in 2.2.
                                  cruunnerrC 1 Reply Last reply
                                    chandra
                                    One thing found was: when edited the rc.local using “sudo nano /etc/rc.local” and writing “python /home/pi/pir.py &” above exit 0", the “&” is still there.
                                    It was supposed to look like:
                                    #!/bin/sh -e
                                    # rc.local
                                    # value on error.
                                    # bits.
                                    if [ "$_IP" ]; then
                                    fi
                                    exit 0
                                    But, i am getting
                                    #!/bin/sh -e
                                    # rc.local
                                    # value on error.
                                    # bits.
                                    if [ "$_IP" ]; then
                                    fi
                                    exit 0
                                    What is the mistake im doing? ( presently checking the screen on off only)
                                    • cruunnerrC
                                      cruunnerr
                                      There is no mistake as far as i can see.
                                      The “&” just need to be written, when a second or third command follows.
                                      So when u are just using this one command both (with or without the “&”) should work
                                      • cruunnerrC
                                        cruunnerr @chandra
                                        @chandra said in {HowTo} turn on/off your monitor (Time based, PIR/Button, App):
                                        Hint from the main post:
                                        To check if it works just go into terminal via ssh and type:
                                        sudo tvservice -o to turn off
                                        sudo tvservice -p to turn on
                                        edit: for some monitors the following commands work better. Please use them if your monitor needs it:
                                        vcgencmd display_power 0 to turn off
                                        vcgencmd display_power 1 to turn on
                                        edit:
                                        also check this:
                                        https://forum.magicmirror.builders/topic/6291/howto-turn-on-off-your-monitor-time-based-pir-button-app/11
                                        • T
                                          teitlebot
                                          The script works as intended but I would like to use the module.
                                          The module doesnt turn off my monitor. I have the correct pin labeled.
                                          What else can I check? Where is the python code for the module? is there a pir.py file somewhere?
                                            chandra @cruunnerr
                                            thank you. Got a confidence.
                                            As mentioned earlier , i don’t have a experience with computer programming.
                                            • 7 / 9
