    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 936.4k Views 74 Watching
    • Cr4z33C
      Cr4z33 @j.e.f.f
      @j-e-f-f I don’t know why, but when I use your module after a while MM becomes all dark although modules keep working (ie. MMM-AssistantMk2).
      There’s no specific timing for the issue to appear (it can be after 1 hour or after 15 mins, etc.).
      Modules won’t appear again until I restart MM.
      This is my current module config:
      			module: "MMM-DarkSkyForecast",
      			header: "Meteo",
      			classes: "default everyone",
      			disabled: false,
      					apikey: "***",
      					latitude: "***",
      					longitude: "***",
      					language: "it",
      					forecastHeaderText: "***",
      					label_timeFormat: "hh:mm",
      					iconset: "4c",
      					concise: false,
      					showSummary: false,
      					forecastLayout: "table"
      Cr4z33C 1 Reply Last reply
        motdog @j.e.f.f
        @j-e-f-f yep. Thanks. Just lots of trial and error but it was set up how I wanted.
        • Cr4z33C
          Cr4z33 @Cr4z33
          @Cr4z33 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          			header: "Meteo",
          			disabled: false,
          					apikey: "***",
          					latitude: "***",
          					longitude: "***",
          					language: "it",
          					iconset: "4c",
          					concise: false,
          					showSummary: false,
          @j-e-f-f you there? :smiling_face_with_open_mouth_cold_sweat:
          J S 2 Replies Last reply
            j.e.f.f Project Sponsor Module Developer @Cr4z33
            @Cr4z33 I have not seen this behaviour… the module does not do anything to hide any modules including itself… you can examine the code for yourself to see. My guess is there is some unintended consequence of my module interacting with one of the other ones your are also using… Can you try disabling the other modules one at a time to see if the behaviour goes away? If it does, whichever was the last one to be disabled is likely the other party. We can start investigating what’s going on after that.
              sdetweil @Cr4z33
              that usually means MM has crashed… many times this is memory related… we know that the default updater module also causes a similar behavior
              • Cr4z33C
                Cr4z33 @j.e.f.f
                @j-e-f-f OK, I’ve started disabling all other 3rd-party modules and enabling them one by one.
                Apart from that what shall I look to then once there’s an issue between your module and the one of someone else? :)
                @sdetweil so what do you suggest me to do? :thinking_face:
                At first I thought that using MMM-WatchDog could sort the problem, but I feel like I misunderstood? :smiling_face_with_open_mouth_cold_sweat:
                S J 2 Replies Last reply
                  sdetweil @Cr4z33
                  @Cr4z33 watchdog will just allow you to restart when it crashes… not capture why…
                  I still don’t have a good method for capturing these kinds of failures…
                  • Cr4z33C
                    Cr4z33 @sdetweil
                    @sdetweil oh I see, but then even if my MM doesn’t look like it restarted.
                    By now I am trying to see the overall behaviour with the Update module being disabled to see if the issue is still happening.
                      sdetweil @Cr4z33
                      @Cr4z33 yeh. i don’t know how watchdog works… at some level if the MM process hangs, watchdog can’t work either… (my opinion without looking at the code)
                      • Cr4z33C
                        Cr4z33 @sdetweil
                        @sdetweil alright.
                        In the meantime disabling the Update module sorted out the issue… weird…
                        Oh well that means I will run the updater manually from time to time. :D
                          chris1971
                          Noob need some advice: Wunderground was running properly untill my API key expired. Now I try to install DarkSKy. I have updated MM to 2.6.0 and installed MMM-DarkSkyForecast and got a newe folder home/pi/MagicMirror/MMM-DarkSkyForecast.
                          How can I implement the module that its’s running? What do I have to change:
                          config.js:
                          module: “MMM-DarkSkyForecast”,
                          header: “Weather”,
                          position: “top_right”,
                          classes: “default everyone”,
                          disabled: false,
                          apikey: “xxxxxxxxxxxxxxxxxxxxxxx”,
                          latitude: “51.4185682”,
                          longitude: “6.8845226”,
                          iconset: “4c”,
                          concise: false,
                          forecastLayout: “table”
                          J 1 Reply Last reply
                            chris1971
                            So, I have added the nice module. I have to adjust the size - who can give some tips/ advice to bring the module in shape?
                            I would like to have it in this shape:
                            Mykle1M 1 Reply Last reply
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @chris1971
                              @chris1971
                              I think this should do it for you. In your config entry
                              forecastLayout: "tiled"
                                chris1971
                                Yes, have “tiled” in the config - but the size is not like in the pic…the module is shown over the entire right screen size… pls. refer to the upper picture…
                                • Mykle1M
                                  @chris1971 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                  Oh, I’m sorry, because your config entry above says, forecastLayout: "table",
                                    chris1971
                                    sorry - I copied the config of an older status…
                                    lavolp3L 1 Reply Last reply
                                    • lavolp3L
                                      lavolp3 Module Developer @chris1971
                                      @chris1971 Well the module gets wrapped because it doesn’t have enough space in the right bar.
                                      You could
                                      • exclude details in the forecast section (there’s an option)
                                      • give the right bar more space by determining it’s width with css
                                      • let the module show only 2 forecast items of each (instead of the 3 you have currently) (also via config options)
                                      How to troubleshoot modules
                                      MMM-soccer v2, MMM-AVStock
                                      • lavolp3L
                                        And of course you could switch off the long forecast text. I THINK you can do that as well via config options.
                                        Go through the options of the module, there’s a LOT to adjust.
                                          chris1971
                                          thanks- I tried to reduce the size of the long forecast text - do you know how to adjust? I think I have to do this in the DarkSky.css…
                                            chris1971
                                            The adjustment of the width was the key factor… thx…
                                            But I do not found out how to adjust the font size or position of the long forecast text… Do I have to do this in the custom.css?
                                            This is my try in the custom.css - but seem not to work as expected…
                                            .MMM-DarkSkyForecast .module-content {
                                            width: 400px;
                                            .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container,
                                            .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .precipitation-container,
                                            .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .wind-container {
                                            display: none;
                                            .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item > span,
                                            .MMM-DarkSkyForecast .wrapper.table .forecast-container .header-row > span {
                                            font-size: 4px;
                                            .MMM-DarkSkyForecast .attribution {
                                            font-size: 10px;
                                            line-height: 5px;
                                            color: #333;
                                            text-align: left;
                                            • 10
                                            • 16
                                            • 17
                                            • 8 / 17
