    Stop the screensaver!
    42 Posts 17 Posters 49.4k Views 16 Watching
    • A
      Anthony Project Sponsor @Mykle1
      @Mykle1
      Thank you for your reply. I haven’t try to see if Lucy works when I see the black screen because I can’t see the “Say, ‘Hello Lucy’” message and because of the latency problems I have I don’t know when it recognizes the keyword and wait for commands. My guess is that it will work but when I am finished with my mirrorsetup I will hung it on the wall so I won’t have mouse and keyboard connected to move or press a button for the mirror to show. Also the black screen appears not only in the standby mode. Last night I left the mirror showing my page 1 modules and in the morning I saw the black screen again. Moved the mouse and evertything showed up.
        sdetweil @Anthony
        @Anthony said in Stop the screensaver!:
        that means screensaver kicked in… MM doesn’t do module visibility by mouse movement…
        • A
          Anthony Project Sponsor @sdetweil
          I agree. But it doesn’t happen when I have voice disabled in my config. And I realized that it also doesn’t happen with voice enabled and MMM-ImageSlideShow showing my pics. Maybe because the pictures change every 10 seconds. But if I have voice enabled and MM shows only clock, calendar, weather etc after 30 minutes screen goes black.
            sdetweil @Anthony
            @Anthony and if MM is not running at all, what happens?
            I run voice, and imageslideshow and don’t see this. If I shut down MM, screen will stay in forever
            • A
              Mine too. If MM is shut down my screen is always on. This also happen if modules with movement are shown in the MM like MMM-ImageSlideShow which have pictures rotating. My screen goes black only when I have modules like clock,calendar,forunecookie,rfacs etc shown. I don’t know if a specific module cause this. For example I now have my MM on for 5 days without black screen and the modules shown are clock, calendar, stats, compliments, news, pictures and weather. If I hide pictures module or replace it with rfacts for example in about half an hour I will get the screensaver black screen.
              • A
                Update.
                Last 3-4 days my MM was running just fine without screensaver appears. Last night it happened again so I restart MM in dev mode to see if I find an error after the the screensaver’s black screen. When I moved the mouse (after some time the screensaver had appeared) the screen was white and in dev console I had a message saying websocket disconnected or something like that. Usually when I moved the mouse after the screensaver and without the dev tools enabled the black screen dissapears and I get my MM screen back. This time was different. I’ll try to upload a screenshot when I get home.
                  usually when u see that the MM runtime has crashed for some reason… even the debug console is gone
                  I haven’t found a way to debug what has happened… I see this occasionally…
                  • A
                    This is getting too weird. Yesterday I had the MM running in dev mode and after I saw the screensaver I moved the mouse and everything came back as normal and no errors in the console. I don’t know why this happens not all the time and with different characteristics everytime.
                      sdetweil @Anthony
                      @Anthony when the screen went to sleep was the developer window hidden too?
                      when my MMM-SleepWake hides all the modules, the Developers console is still on the screen
                      • A
                        In my case when the screen goes to sleep everything is hidden, modules, dev console etc. I see only black screen. Is there any possibility that pi “forgets” the setting to disable the screensaver? I will try to go and change this setting and after put it back again to see if anyhting changes.
                          sdetweil @Anthony
                          @Anthony interesting… neither of my systems has forgotten the screen saver setting, been running for over 2 years now…
                          • A
                            I don’t think that this is the problem but I want to test it just in case.
                              bhepler Module Developer
                              At this point, I’m thinking a sudo apt-get update && sudo apt-get upgrade might be in order. There could be a bug in the Pi’s power management routines.
                              • A
                                Anthony Project Sponsor @bhepler
                                @bhepler
                                I will try this as well but 3 days now the problem does not appear. I haven’t touch anything on my MM and I don’t see the black screen. I will try a sudo apt-get update && sudo apt-get upgrade although. It is always usefull. Thank you.
                                • A
                                  This is a screenshot of what happened after about half an hour after restarting magic mirror.0_1552744358584_2019-03-16-154428_1366x768_scrot.png
                                  • A
                                      bhepler Module Developer @Anthony
                                      @Anthony - That looks like a network outage. The errors show that the NASA module or whatever can’t pull images from the API. And then you lost connection to your mirror.
                                      Of course, it could be the Pi shutting off to disconnect the developer tools. Hrm.
                                      • 2 / 3
