    Stop the screensaver!
    42 Posts 17 Posters 49.4k Views 16 Watching
    • cowboysdudeC
      cowboysdude Module Developer @frog
      @frog said in Stop the screensaver!:
      There’s no need for that attitude. Please desist as this is a forum for helping people. I also had this problem so it isn’t isolated. It may not be possible to add a keyboard and mouse to the screen and use the screensaver utility.
      Attitude? Oh you haven’t seen my attitude… just making a simple suggestion where there doesn’t need a case made out of it. It’s THE simplest way for NON programmers to do it…
      • rcollieR
        rcollie
        I realize how (super) old this topic is, but for anyone who stumbles across it and still dealing with this, xscreensaver really is the easiest solution.
        sudo apt-get install xscreensaver
        Just change the screen saver in there to no screen saver, and you’re sorted.
          PaulB
          Hey guys,
          there is another option on disabling the screensaver, which worked perfectly for me.
          Just disable the screensaver in the option menu of debian.
          Hope this helps someone :)
            BlackTalon
            Revived again. I have xscreensaver installed and the screensaver disabled. It still blanks the screen after a day.
            • ChrisC
              Chris
              After a total reinstall of the recent raspberry to integrate Google Assist Pi, I also have the same problem.
              After watching, I end up with an empty screen after about 6 hours. I am forced to restart MagicMirror via the MMM-Remote-Control module.
              On the other hand I do not have xsceensaver of installed but the modification of the lines of command indicated in the wiki of installation of MM
              I did not experience this problem before. The only difference between my two installations is the 2.3.1 update of MagicMirror.
              Would it affect?
              Regards,
              • G
                Gabev
                I had the same problem where. I stumbled across this thread, check out the answer given by JimmyN… it helped me at least.
                  m0111k @cowboysdude
                  @cowboysdude tried that, screen still went standby… any clue for fix?
                  ps im newb here, how can i remove xscreensaver when it doesnt work? Thanks
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @m0111k
                    @m0111k said in Stop the screensaver!:
                    sudo apt-get remove xscreensaver
                    However, I don’t think xscreensaver is capable of putting your display into standby. That is likely your system or settings.
                    • A
                      Anthony Project Sponsor @Mykle1
                      @Mykle1
                      Is there any possibillity that Lucy interacts somehow with the screen saver? I am asking this because I have installed xscreensaver and working good but if I have lucy enabled I get the black screen and I must move the mouse to sho the MM again. Just a thought!
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Anthony
                        @Anthony
                        Perhaps, but I’ve never seen this behavior or heard about it before this. I will see if I can reproduce that here.
                        • Mykle1M
                          @Anthony
                          I’m not seeing this behavior at all. You can clearly see that I have xscreensaver running with the “Screen Saver DIsabled” but I can’t reproduce what it happening to you. Lucy responds normally and no black screen issue. If you say “SHOW MODULES” does Lucy show them?
                          ![0_1551838003790_Screenshot.png](Uploading 100%)
                          Edit: Something seems to be amiss. The forum isn’t allowing me to post an image at the moment.
                          Picture below.
                          • Mykle1M
                            • A
                              @Mykle1
                              Thank you for your reply. I haven’t try to see if Lucy works when I see the black screen because I can’t see the “Say, ‘Hello Lucy’” message and because of the latency problems I have I don’t know when it recognizes the keyword and wait for commands. My guess is that it will work but when I am finished with my mirrorsetup I will hung it on the wall so I won’t have mouse and keyboard connected to move or press a button for the mirror to show. Also the black screen appears not only in the standby mode. Last night I left the mirror showing my page 1 modules and in the morning I saw the black screen again. Moved the mouse and evertything showed up.
                                sdetweil @Anthony
                                @Anthony said in Stop the screensaver!:
                                that means screensaver kicked in… MM doesn’t do module visibility by mouse movement…
                                • A
                                  Anthony Project Sponsor @sdetweil
                                  I agree. But it doesn’t happen when I have voice disabled in my config. And I realized that it also doesn’t happen with voice enabled and MMM-ImageSlideShow showing my pics. Maybe because the pictures change every 10 seconds. But if I have voice enabled and MM shows only clock, calendar, weather etc after 30 minutes screen goes black.
                                    sdetweil @Anthony
                                    @Anthony and if MM is not running at all, what happens?
                                    I run voice, and imageslideshow and don’t see this. If I shut down MM, screen will stay in forever
                                    • A
                                      Mine too. If MM is shut down my screen is always on. This also happen if modules with movement are shown in the MM like MMM-ImageSlideShow which have pictures rotating. My screen goes black only when I have modules like clock,calendar,forunecookie,rfacs etc shown. I don’t know if a specific module cause this. For example I now have my MM on for 5 days without black screen and the modules shown are clock, calendar, stats, compliments, news, pictures and weather. If I hide pictures module or replace it with rfacts for example in about half an hour I will get the screensaver black screen.
                                      • A
                                        Update.
                                        Last 3-4 days my MM was running just fine without screensaver appears. Last night it happened again so I restart MM in dev mode to see if I find an error after the the screensaver’s black screen. When I moved the mouse (after some time the screensaver had appeared) the screen was white and in dev console I had a message saying websocket disconnected or something like that. Usually when I moved the mouse after the screensaver and without the dev tools enabled the black screen dissapears and I get my MM screen back. This time was different. I’ll try to upload a screenshot when I get home.
                                          usually when u see that the MM runtime has crashed for some reason… even the debug console is gone
                                          I haven’t found a way to debug what has happened… I see this occasionally…
                                          • A
                                            This is getting too weird. Yesterday I had the MM running in dev mode and after I saw the screensaver I moved the mouse and everything came back as normal and no errors in the console. I don’t know why this happens not all the time and with different characteristics everytime.
                                            • 2 / 3
