    Stop the screensaver!
    42 Posts 17 Posters 49.7k Views 16 Watching
      markiper @KirAsh4
      @KirAsh4 I am reviving this topic as I have run into this same issue and have not been able to figure how to solve it. I started playing with a Magic Mirror a few days back (thanks to all the contributors), prior to that, I have read multiple posts, tutorials, blogs, etc; one of them is actually from you @KirAsh4
      https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
      You mention that there are two locatons where chagnes need to be made in order to disable the screen saver:
      ’ sudo nano /etc/xdg/lxsession/LXDE-pi/autostart ’
      ’ sudo nano /etc/lightdm/lightdm.conf ’
      I am not able to find the first file, so I started reading this forum and came across this post:
      https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
      following the directions, the first file is on a different location:
      ’ sudo nano /etc/xdg/lxsession/LXDE/autostart ’
      I did find that file and made the changes as described, my autostart file looks like this:
      @lxpanel --profile LXDE
      @pcmanfm --desktop --profile LXDE
      @xscreensaver -no-splash
      @xset s noblank
      @xset s off
      @xset -dpms
      I also changed the second variable under ’ sudo nano /etc/lightdm/lightdm.conf ', I verified that I am indeed changing the actual variable and not the variable description. As far as I can tell, everything has been done as stipulated in the tutorials, but my screen saver still kicks in every 5 minutes (roughly). Is there anything that I am leaving out, thus creating the issue. I started witha fresh Jessie Lite installation following the tutorial: https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide
      Any help will be greatly appreciated, I have been stumbling around reading forum entries here and at the raspberry pi foundation, but nothing seems to solve my problem (and I am no Linux guru), so any help you can provide will be greatly appreciated
        mjtice
        I had the same problem where I could’t get the screensaver (or screen blanking) to stop turning on. I stumbled across this thread, check out the answer given by JimmyN… it helped me at least.
        disable screensaver
        • cowboysdudeC
          Good lord just install xscreensaver and then disable the screen saver from there… easiest way without having to modify a ton of files… then being frustrated because it still doesn’t work :)
          https://www.reddit.com/r/raspberry_pi/comments/4hwdwy/how_to_install_the_latest_xscreensaver_on_a/
          M 1 Reply Last reply
          Reply Quote 2
          • F
            frog
            There’s no need for that attitude. Please desist as this is a forum for helping people. I also had this problem so it isn’t isolated. It may not be possible to add a keyboard and mouse to the screen and use the screensaver utility.
            • O
              onetwankyfive
              or buy a mouse jiggler
              https://www.amazon.com/WiebeTech-Programmable-Mouse-Jiggler-MJ-3/dp/B00MTZY7Y4/ref=sr_1_1?ie=UTF8&qid=1482934294&sr=8-1&keywords=mouse+jiggler
              F 1 Reply Last reply
              • F
                frog @onetwankyfive
                @onetwankyfive said in Stop the screensaver!:
                  markiper
                  Thanks everyone for the erplies. I am still having the same issue, but doing some more testing and reading. I found this post:
                  http://www.geeks3d.com/hacklab/20160108/how-to-disable-the-blank-screen-on-raspberry-pi-raspbian/
                  In theory, just modifying the lightdm.conf should do the trick with newer versions of Raspbian Jessie Lite. I will poke around some more, hopefully i find a fix, so I can provide something back to this community.
                  • lolobyteL
                    lolobyte
                    Hi all,
                    after doing this
                    Disable the screensaver:
                    Go to LXDE-autostart config:
                    add the following lines:
                    @xset s noblank
                    @xset s off
                    @xset -dpms
                    Save and close, using the commands CTRL-O and CTRL-X.
                    Go to lightdm.conf:
                    add the following lines in section [SeatDefaults]:
                    xserver-command=X -s 0 -dpms
                    The fucking screensaver is starting again.
                    Then i do following:
                    sudo apt-get install xscreensaver
                    sudo apt-get remove xscreensaver
                    An i never see a starting screensaver gain.
                    Good luck!
                      markiper
                      So here is how I was able to fix my issue with the screen saver. I started this project following the tutorial from here:
                      When you get to the Disable the ScreenSaver portion of the article, instead of changing the autostart file under
                      You should modify the autostart file under ~/.config/lxsession/LXDE/autostart
                      sudo nano ~/.config/lxsession/LXDE/autostart
                      Comment the first 3 lines (using a #), then add the same three lines listed in the tutorial. The final autostart file after all modifications should look similar to:
                      #@lxpanel --profile LXDE
                      #@pcmanfm --desktop --profile LXDE
                      #@xscreensaver -no-splash
                      @xset s noblack
                      @xset s off
                      @xset -dpms
                      Once that is done, follow the instructions to modify the lightdm.conf file:
                      [SeatDefaults]
                      Save the changes, reboot your raspberry pi (I am using an RPi3), and the screen saver is gone for good. Hopefully this helps someone else having the same issue.
                      • cowboysdudeC
                        cowboysdude Module Developer @frog
                        @frog said in Stop the screensaver!:
                        Attitude? Oh you haven’t seen my attitude… just making a simple suggestion where there doesn’t need a case made out of it. It’s THE simplest way for NON programmers to do it…
                        • rcollieR
                          rcollie
                          I realize how (super) old this topic is, but for anyone who stumbles across it and still dealing with this, xscreensaver really is the easiest solution.
                          Just change the screen saver in there to no screen saver, and you’re sorted.
                            PaulB
                            Hey guys,
                            there is another option on disabling the screensaver, which worked perfectly for me.
                            Just disable the screensaver in the option menu of debian.
                            Hope this helps someone :)
                              BlackTalon
                              Revived again. I have xscreensaver installed and the screensaver disabled. It still blanks the screen after a day.
                              • ChrisC
                                Chris
                                After a total reinstall of the recent raspberry to integrate Google Assist Pi, I also have the same problem.
                                After watching, I end up with an empty screen after about 6 hours. I am forced to restart MagicMirror via the MMM-Remote-Control module.
                                On the other hand I do not have xsceensaver of installed but the modification of the lines of command indicated in the wiki of installation of MM
                                I did not experience this problem before. The only difference between my two installations is the 2.3.1 update of MagicMirror.
                                Would it affect?
                                Regards,
                                • G
                                  Gabev
                                  I had the same problem where. I stumbled across this thread, check out the answer given by JimmyN… it helped me at least.
                                    m0111k @cowboysdude
                                    @cowboysdude tried that, screen still went standby… any clue for fix?
                                    ps im newb here, how can i remove xscreensaver when it doesnt work? Thanks
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @m0111k
                                      @m0111k said in Stop the screensaver!:
                                      However, I don’t think xscreensaver is capable of putting your display into standby. That is likely your system or settings.
                                      A 1 Reply Last reply
                                      • A
                                        Anthony Project Sponsor @Mykle1
                                        @Mykle1
                                        Is there any possibillity that Lucy interacts somehow with the screen saver? I am asking this because I have installed xscreensaver and working good but if I have lucy enabled I get the black screen and I must move the mouse to sho the MM again. Just a thought!
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @Anthony
                                          @Anthony
                                          Perhaps, but I’ve never seen this behavior or heard about it before this. I will see if I can reproduce that here.
                                          • Mykle1M
                                            @Anthony
                                            I’m not seeing this behavior at all. You can clearly see that I have xscreensaver running with the “Screen Saver DIsabled” but I can’t reproduce what it happening to you. Lucy responds normally and no black screen issue. If you say “SHOW MODULES” does Lucy show them?
                                            ![0_1551838003790_Screenshot.png](Uploading 100%)
                                            Edit: Something seems to be amiss. The forum isn’t allowing me to post an image at the moment.
                                            Picture below.
