    Advise for a voice assistant
    21 Posts 7 Posters 12.5k Views 9 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer @THeStigh
      @THeStigh Indeed, using it on a Rasp 3 b+ fully up to date.
      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
      • thedoorsfanaticT
        thedoorsfanatic @ejay-ibm
        @ejay-ibm
        I was able to run MK2assistant but never managed to install Hotword.
        Is there a tutorial out there which shows me how to do it, absolute beginner style?
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        ejay-ibmE T 2 Replies Last reply Reply Quote 0
        • ejay-ibmE
          ejay-ibm Project Sponsor Module Developer @thedoorsfanatic
          @thedoorsfanatic
          I think the Readme here : https://github.com/eouia/MMM-Hotword/
          is pretty clear, that is what I followed and I have it working directly.
          check out the Tip section to include hotword in the mk2 assistant and you should be good.
          If you run into issue you can share your config file and I can have a look .
          Ejay
          • thedoorsfanaticT
            @ejay-ibm
            all right, thanks, I will try it again but usually it failed when trying to install snowboy
              A Former User @thedoorsfanatic
              @thedoorsfanatic
              Give me a telegram When you are stuck on. Telegram:@eouia
              • T
                THeStigh @thedoorsfanatic
                @thedoorsfanatic
                What hardware and OS are you using ?
                • thedoorsfanaticT
                  thedoorsfanatic @THeStigh
                  @THeStigh
                  I am using a Raspi 3 B+ and latest release of Stretch and MagicMirror.
                  I am a newbie and though I tried all the troubleshooting tipps described I wasn’t able to install Hotword and snowboy.
                  • T
                    @thedoorsfanatic Snowboy can be tricky, but @sean has made some good troubleshooting guides on the page for MMM-Hotword. But you can delete the MMM-Hotword folder and try to re-install it following these instructions to do it quite manually. If it fails, you at least will get a clear picture of where it actually failed:
                    cd ~/MagicMirror/modules/
                    sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
                    git clone https://github.com/eouia/MMM-Hotword.git
                    cd MMM-Hotword
                    npm install
                    cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                    npm install --save-dev electron-rebuild
                    npm install nan
                    ./node_modules/.bin/electron-rebuild
                    • thedoorsfanaticT
                      thedoorsfanatic
                      This is the error code:
                      snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      node-pre-gyp install --fallback-to-build
                      node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
                      node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.15.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
                      node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
                      internal/modules/cjs/loader.js:583
                      throw err;
                      Error: Cannot find module ‘nan’
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:507:25)
                      at Module.require (internal/modules/cjs/loader.js:637:17)
                      at require (internal/modules/cjs/helpers.js:22:18)
                      at [eval]:1:1
                      at Script.runInThisContext (vm.js:96:20)
                      at Object.runInThisContext (vm.js:303:38)
                      at Object. ([eval]-wrapper:6:22)
                      at Module._compile (internal/modules/cjs/loader.js:689:30)
                      at evalScript (internal/bootstrap/node.js:587:27)
                      gyp: Call to ‘node -e “require(‘nan’)”’ returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                      throw err;
                      at [eval]:1:1
                      gyp ERR! configure error
                      gypgyp ERR! stack Error: gyp failed with exit code: 1
                      gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
                      ERR!gyp ERR!configure error
                      stack at ChildProcess.emit (events.js:189:13)
                      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                      gyp ERR! System Linux 4.14.98-v7+
                      gyp ERR!gyp stack Error: gyp failed with exit code: 1
                      ERR!gyp commandERR! “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
                      gyp gypERR! ERR!stack at ChildProcess.emit (events.js:189:13)
                      cwdgyp /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      ERR! gypstack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                      ERR! node -v v10.15.2
                      gyp ERR! node-gyp -v v3.8.0
                      gyp ERR! not ok
                      gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
                      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      gyp ERR! node -v v10.15.2
                      gyp ERR! not ok
                      node-pre-gyp ERR! build error
                      node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)
                      node-pre-gyp ERR! stack at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                      node-pre-gyp ERR! stack at ChildProcess.emit (events.js:189:13)
                      node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:970:16)
                      node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                      node-pre-gyp ERR! System Linux 4.14.98-v7+
                      node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
                      node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      node-pre-gyp ERR! node -v v10.15.2
                      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
                      node-pre-gyp ERR! not ok
                      npm WARN MMM-Hotword@1.1.0 No repository field.
                      npm ERR! code ELIFECYCLE
                      npm ERR! errno 1
                      npm ERR! snowboy@1.3.1 install: node-pre-gyp install --fallback-to-build
                      npm ERR! Exit status 1
                      npm ERR!
                      npm ERR! Failed at the snowboy@1.3.1 install script.
                        bibi
                        @ejay-ibm, @THeStigh i have installed MMM-Hotword. I hope correctly? as i got only warning via npm like
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
                        npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                        npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                        npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                        I am not sure how i can test it tho?
                        Or there is nothing to expect with only MMM-hotword installed?
                        (sorry if my question is stupid :) )
                        S ? 2 Replies Last reply Reply Quote 0
                          sdetweil @bibi
                          @bibi start mirror in dev mode
                          npm start dev
                          Select the console tab in the developers window
                          You should see MMM-Hotword sending notifications of the words it recognizes
                            A Former User @bibi
                            @bibi
                            You can ignore some WARN unless your program is working.
                              bibi
                              @ejay-ibm, i wanted to follow your good practice and update MM to latest (ok) and OS to stretch (ok) but now it pm2 won’t start MM automatically as it did in the past… would kindly help me to solve this issue before i can install mk2?
                              thx alot for any help as well
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @bibi
                                @bibi
                                https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                                  bibi
                                  @Mykle1, thx for your post. It appears that when i want to check npm version, the system issues :
                                  pi@raspberrypi:~ $ npm -v
                                  -bash: npm: command not found
                                  Therefore something went wrong during the system upgrade to stretch.
                                  If i am not wrong npm comes along with nodejs which i have current version
                                  pi@raspberrypi:~ $ nodejs -v
                                  v8.11.1
                                  I think i would just install it again but i don’t know if I should do it from /home/pi or from inside /home/pi/MagicMirror ?
                                  • Mykle1M
                                    @bibi said in Advise for a voice assistant:
                                    pi@raspberrypi:~ Here!
                                      bibi
                                      finally what i did and what did work is :)
                                      sudo apt-get remove nodered -y
                                      sudo apt-get remove nodejs nodejs-legacy -y
                                      sudo apt-get remove npm -y
                                      sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
                                      sudo apt-get install -y nodejs
                                      node -v
                                      npm -v
                                        bibi
                                        Hi @ejay-ibm, was a bit busy last days… couldn’t work on MM. I finally install both MMM-Hotword and Mk2. Works fine but need some fine tuning. Maybe you or anybody can guide/help me on the following:
                                        Mk2 side, i still need to understand how it works and how i can “interact” with the other modules… If you have a simple example to show how to “link” Mk2 with any other modules, it would be very helpful!
                                        As usual thx to all for always supporting the community!
