    Advise for a voice assistant
    21 Posts 7 Posters 12.2k Views 9 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic @THeStigh
      @THeStigh
      I am using a Raspi 3 B+ and latest release of Stretch and MagicMirror.
      I am a newbie and though I tried all the troubleshooting tipps described I wasn’t able to install Hotword and snowboy.
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      • T Offline
        THeStigh @thedoorsfanatic
        @thedoorsfanatic Snowboy can be tricky, but @sean has made some good troubleshooting guides on the page for MMM-Hotword. But you can delete the MMM-Hotword folder and try to re-install it following these instructions to do it quite manually. If it fails, you at least will get a clear picture of where it actually failed:
        cd ~/MagicMirror/modules/
        sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
        git clone https://github.com/eouia/MMM-Hotword.git
        cd MMM-Hotword
        npm install
        cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
        npm install --save-dev electron-rebuild
        npm install nan
        ./node_modules/.bin/electron-rebuild
          thedoorsfanatic
          This is the error code:
          snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          node-pre-gyp install --fallback-to-build
          node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
          node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.15.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
          node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
          internal/modules/cjs/loader.js:583
          throw err;
          Error: Cannot find module ‘nan’
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
          at Function.Module._load (internal/modules/cjs/loader.js:507:25)
          at Module.require (internal/modules/cjs/loader.js:637:17)
          at require (internal/modules/cjs/helpers.js:22:18)
          at [eval]:1:1
          at Script.runInThisContext (vm.js:96:20)
          at Object.runInThisContext (vm.js:303:38)
          at Object. ([eval]-wrapper:6:22)
          at Module._compile (internal/modules/cjs/loader.js:689:30)
          at evalScript (internal/bootstrap/node.js:587:27)
          gyp: Call to ‘node -e “require(‘nan’)”’ returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          throw err;
          at [eval]:1:1
          gyp ERR! configure error
          gypgyp ERR! stack Error: gyp failed with exit code: 1
          gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
          ERR!gyp ERR!configure error
          stack at ChildProcess.emit (events.js:189:13)
          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 4.14.98-v7+
          gyp ERR!gyp stack Error: gyp failed with exit code: 1
          ERR!gyp commandERR! “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
          gyp gypERR! ERR!stack at ChildProcess.emit (events.js:189:13)
          cwdgyp /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          ERR! gypstack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          ERR! node -v v10.15.2
          gyp ERR! node-gyp -v v3.8.0
          gyp ERR! not ok
          gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          gyp ERR! node -v v10.15.2
          gyp ERR! not ok
          node-pre-gyp ERR! build error
          node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)
          node-pre-gyp ERR! stack at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR! stack at ChildProcess.emit (events.js:189:13)
          node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:970:16)
          node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          node-pre-gyp ERR! System Linux 4.14.98-v7+
          node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
          node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
          node-pre-gyp ERR! node -v v10.15.2
          node-pre-gyp ERR! node-pre-gyp -v v0.6.39
          node-pre-gyp ERR! not ok
          npm WARN MMM-Hotword@1.1.0 No repository field.
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! snowboy@1.3.1 install: node-pre-gyp install --fallback-to-build
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the snowboy@1.3.1 install script.
            bibi
            @ejay-ibm, @THeStigh i have installed MMM-Hotword. I hope correctly? as i got only warning via npm like
            pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
            npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
            npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
            I am not sure how i can test it tho?
            Or there is nothing to expect with only MMM-hotword installed?
            (sorry if my question is stupid :) )
            S ? 2 Replies Last reply Reply Quote 0
              sdetweil @bibi
              @bibi start mirror in dev mode
              npm start dev
              Select the console tab in the developers window
              You should see MMM-Hotword sending notifications of the words it recognizes
                [[global:former-user]] @bibi
                @bibi
                You can ignore some WARN unless your program is working.
                  bibi
                  @ejay-ibm, i wanted to follow your good practice and update MM to latest (ok) and OS to stretch (ok) but now it pm2 won’t start MM automatically as it did in the past… would kindly help me to solve this issue before i can install mk2?
                  thx alot for any help as well
                    Mykle1 Project Sponsor Module Developer @bibi
                    @bibi
                    https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                      bibi
                      @Mykle1, thx for your post. It appears that when i want to check npm version, the system issues :
                      pi@raspberrypi:~ $ npm -v
                      -bash: npm: command not found
                      Therefore something went wrong during the system upgrade to stretch.
                      If i am not wrong npm comes along with nodejs which i have current version
                      pi@raspberrypi:~ $ nodejs -v
                      v8.11.1
                      I think i would just install it again but i don’t know if I should do it from /home/pi or from inside /home/pi/MagicMirror ?
                        @bibi said in Advise for a voice assistant:
                        pi@raspberrypi:~ Here!
                          bibi
                          finally what i did and what did work is :)
                          sudo apt-get remove nodered -y
                          sudo apt-get remove nodejs nodejs-legacy -y
                          sudo apt-get remove npm -y
                          sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
                          sudo apt-get install -y nodejs
                          node -v
                          npm -v
                            bibi
                            Hi @ejay-ibm, was a bit busy last days… couldn’t work on MM. I finally install both MMM-Hotword and Mk2. Works fine but need some fine tuning. Maybe you or anybody can guide/help me on the following:
                            Mk2 side, i still need to understand how it works and how i can “interact” with the other modules… If you have a simple example to show how to “link” Mk2 with any other modules, it would be very helpful!
                            As usual thx to all for always supporting the community!
