    Advise for a voice assistant
    21 Posts 7 Posters 12.7k Views 9 Watching
      A Former User @thedoorsfanatic
      @thedoorsfanatic
      Give me a telegram When you are stuck on. Telegram:@eouia
      • T
        THeStigh @thedoorsfanatic
        @thedoorsfanatic
        What hardware and OS are you using ?
        thedoorsfanaticT 1 Reply Last reply
        • thedoorsfanaticT
          thedoorsfanatic @THeStigh
          @THeStigh
          I am using a Raspi 3 B+ and latest release of Stretch and MagicMirror.
          I am a newbie and though I tried all the troubleshooting tipps described I wasn’t able to install Hotword and snowboy.
          My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          • T
            @thedoorsfanatic Snowboy can be tricky, but @sean has made some good troubleshooting guides on the page for MMM-Hotword. But you can delete the MMM-Hotword folder and try to re-install it following these instructions to do it quite manually. If it fails, you at least will get a clear picture of where it actually failed:
            cd ~/MagicMirror/modules/
            sudo apt-get install libmagic-dev libatlas-base-dev sox libsox-fmt-all
            git clone https://github.com/eouia/MMM-Hotword.git
            cd MMM-Hotword
            npm install
            cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
            npm install --save-dev electron-rebuild
            npm install nan
            ./node_modules/.bin/electron-rebuild
            Reply Quote 2
            • thedoorsfanaticT
              thedoorsfanatic
              This is the error code:
              snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
              node-pre-gyp install --fallback-to-build
              node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
              node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.15.2 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
              node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
              internal/modules/cjs/loader.js:583
              throw err;
              Error: Cannot find module ‘nan’
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
              at Function.Module._load (internal/modules/cjs/loader.js:507:25)
              at Module.require (internal/modules/cjs/loader.js:637:17)
              at require (internal/modules/cjs/helpers.js:22:18)
              at [eval]:1:1
              at Script.runInThisContext (vm.js:96:20)
              at Object.runInThisContext (vm.js:303:38)
              at Object. ([eval]-wrapper:6:22)
              at Module._compile (internal/modules/cjs/loader.js:689:30)
              at evalScript (internal/bootstrap/node.js:587:27)
              gyp: Call to ‘node -e “require(‘nan’)”’ returned exit status 1 while in binding.gyp. while trying to load binding.gyp
              throw err;
              at [eval]:1:1
              gyp ERR! configure error
              gypgyp ERR! stack Error: gyp failed with exit code: 1
              gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
              ERR!gyp ERR!configure error
              stack at ChildProcess.emit (events.js:189:13)
              gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp ERR! System Linux 4.14.98-v7+
              gyp ERR!gyp stack Error: gyp failed with exit code: 1
              ERR!gyp commandERR! “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
              gyp gypERR! ERR!stack at ChildProcess.emit (events.js:189:13)
              cwdgyp /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
              ERR! gypstack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              ERR! node -v v10.15.2
              gyp ERR! node-gyp -v v3.8.0
              gyp ERR! not ok
              gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node” “–module_name=snowboy” “–module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm”
              gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
              gyp ERR! node -v v10.15.2
              gyp ERR! not ok
              node-pre-gyp ERR! build error
              node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm’ (1)
              node-pre-gyp ERR! stack at ChildProcess. (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
              node-pre-gyp ERR! stack at ChildProcess.emit (events.js:189:13)
              node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:970:16)
              node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
              node-pre-gyp ERR! System Linux 4.14.98-v7+
              node-pre-gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
              node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
              node-pre-gyp ERR! node -v v10.15.2
              node-pre-gyp ERR! node-pre-gyp -v v0.6.39
              node-pre-gyp ERR! not ok
              npm WARN MMM-Hotword@1.1.0 No repository field.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! snowboy@1.3.1 install: node-pre-gyp install --fallback-to-build
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the snowboy@1.3.1 install script.
                bibi
                @ejay-ibm, @THeStigh i have installed MMM-Hotword. I hope correctly? as i got only warning via npm like
                pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
                npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                I am not sure how i can test it tho?
                Or there is nothing to expect with only MMM-hotword installed?
                (sorry if my question is stupid :) )
                S ? 2 Replies Last reply
                  sdetweil @bibi
                  @bibi start mirror in dev mode
                  npm start dev
                  Select the console tab in the developers window
                  You should see MMM-Hotword sending notifications of the words it recognizes
                    A Former User @bibi
                    @bibi
                    You can ignore some WARN unless your program is working.
                      bibi
                      @ejay-ibm, i wanted to follow your good practice and update MM to latest (ok) and OS to stretch (ok) but now it pm2 won’t start MM automatically as it did in the past… would kindly help me to solve this issue before i can install mk2?
                      thx alot for any help as well
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @bibi
                        @bibi
                        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
                          bibi
                          @Mykle1, thx for your post. It appears that when i want to check npm version, the system issues :
                          pi@raspberrypi:~ $ npm -v
                          -bash: npm: command not found
                          Therefore something went wrong during the system upgrade to stretch.
                          If i am not wrong npm comes along with nodejs which i have current version
                          pi@raspberrypi:~ $ nodejs -v
                          v8.11.1
                          I think i would just install it again but i don’t know if I should do it from /home/pi or from inside /home/pi/MagicMirror ?
                          • Mykle1M
                            @bibi said in Advise for a voice assistant:
                            pi@raspberrypi:~ Here!
                              bibi
                              finally what i did and what did work is :)
                              sudo apt-get remove nodered -y
                              sudo apt-get remove nodejs nodejs-legacy -y
                              sudo apt-get remove npm -y
                              sudo curl -sL https://deb.nodesource.com/setup_6.x | sudo bash -
                              sudo apt-get install -y nodejs
                              node -v
                              npm -v
                                bibi
                                Hi @ejay-ibm, was a bit busy last days… couldn’t work on MM. I finally install both MMM-Hotword and Mk2. Works fine but need some fine tuning. Maybe you or anybody can guide/help me on the following:
                                Mk2 side, i still need to understand how it works and how i can “interact” with the other modules… If you have a simple example to show how to “link” Mk2 with any other modules, it would be very helpful!
                                As usual thx to all for always supporting the community!
