    No sound from my RPi 3 B.
    16 Posts 4 Posters 7.8k Views 3 Watching
      BillW
      Thanks in advance. I’ve been searching the forum and have not found an solution for this. Currently I am running a Raspberry Pi 3 B. I have MM loaded and some modules loaded. I have a HDMI to DVI cable attached going to my monitor. Any help is appreciated.
      Thanks,
      Bill
        sdetweil @BillW
        @BillW dvi does not carry sound so you would need a separate cable
        My main computer has dvi, monitor is HDMI. Uses sep cable to monitor
          BillW
          I should have included in my first post, but I did attach a separate cable for sound to speakers, but that didn’t work so I tried earphones to make sure. Thanks for confirming that for me. Any other suggestions?
            sdetweil @BillW
            @BillW did the earphones work?
            S B 2 Replies Last reply Reply Quote 0
              @sdetweil do system sounds work?
                BillW @sdetweil
                @sdetweil No
                  https://www.raspberrypi.org/documentation/configuration/audio-config.md
                  Sound is going out the HDMI cable
                    BillW
                    I’ll follow the link and check it out, then I’ll let you know what I did. Thanks for the guidance.
                      sdetweil @BillW
                      @BillW this one too
                      https://www.cb-net.co.uk/linux/getting-analogue-sound-working-raspberry-pi-3b-raspbian-stretch/
                        BillW
                        Ok, tried all three but no luck, not sure what to do next. Here’s a copy of my config file if that may help
                        For more options and information see
                        http://rpf.io/configtxt
                        Some settings may impact device functionality. See link above for details
                        uncomment if you get no picture on HDMI for a default “safe” mode
                        #hdmi_safe=1
                        uncomment this if your display has a black border of unused pixels visible
                        and your display can output without overscan
                        #disable_overscan=1
                        uncomment the following to adjust overscan. Use positive numbers if console
                        goes off screen, and negative if there is too much border
                        #overscan_left=16
                        #overscan_right=16
                        #overscan_top=16
                        #overscan_bottom=16
                        uncomment to force a console size. By default it will be display’s size minus
                        overscan.
                        #framebuffer_width=1280
                        #framebuffer_height=720
                        uncomment if hdmi display is not detected and composite is being output
                        #hdmi_force_hotplug=1
                        uncomment to force a specific HDMI mode (this will force VGA)
                        #hdmi_group=1
                        #hdmi_mode=1
                        uncomment to force a HDMI mode rather than DVI. This can make audio work in
                        DMT (computer monitor) modes
                        #hdmi_drive=2
                        uncomment to increase signal to HDMI, if you have interference, blanking, or
                        no display
                        #config_hdmi_boost=4
                        uncomment for composite PAL
                        #sdtv_mode=2
                        #uncomment to overclock the arm. 700 MHz is the default.
                        #arm_freq=800
                        Uncomment some or all of these to enable the optional hardware interfaces
                        #dtparam=i2c_arm=on
                        #dtparam=i2s=on
                        #dtparam=spi=on
                        Uncomment this to enable the lirc-rpi module
                        #dtoverlay=lirc-rpi
                        Additional overlays and parameters are documented /boot/overlays/README
                        Enable audio (loads snd_bcm2835)
                        #dtparam=audio=on
                        [pi0]
                        dtoverlay=dwc2
                        [all]
                        start_x=1
                        gpu_mem=128
                        dtoverlay=googlevoicehat-soundcard
                        display_rotate=1
                        Sorry for the large font, not well verse with the editing portion of this forum.
                          sdetweil @BillW
                          @BillW use the markdown 3 backticks before and after… key to the left of number 1
                          you can edit it… pound sign makes large font
                          my device doesn’t have an analog audio port
                            BillW
                            My knowledge of this is very limited, I don’t understand where you want me to put the markdown at?
                            S B Mykle1M 3 Replies Last reply Reply Quote 0
                              sdetweil @BillW
                              @BillW edit your previous post.
                              In front of the content you pasted in, on a separate line, put three backtics
                              Then go to the end of the content you pasted, add a new line and put three backtics there. Submit your post update
                                bhepler Module Developer @BillW
                                @BillW - You can find the markdown commands at this link. Please use them to post code, file contents and commands.
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @BillW
                                  @BillW
                                  Just to add to what @bhepler and @sdetweil are suggesting about posting code on the forum;
                                  https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                    BillW
                                    I have sound! Thanks for all the help. What I did, after I read some the links provided, I decided to format another SD card and reload all my programs and I got sound. Then I compared the two SD card files and found that the original card had a file called AIY Project Voice, this program overwrote some of the files and change the parameters for output, apparently my grandson downloaded it thinking he was helping. Now all is good and I’ve learned a lot with every ones help. Thanks again.
