    No sound from my RPi 3 B.
    16 Posts 4 Posters 7.0k Views 3 Watching
      BillW
      I should have included in my first post, but I did attach a separate cable for sound to speakers, but that didn’t work so I tried earphones to make sure. Thanks for confirming that for me. Any other suggestions?
        sdetweil @BillW
        @BillW did the earphones work?
        S B 2 Replies Last reply Reply Quote 0
          @sdetweil do system sounds work?
            BillW @sdetweil
            @sdetweil No
              https://www.raspberrypi.org/documentation/configuration/audio-config.md
              Sound is going out the HDMI cable
                BillW
                I’ll follow the link and check it out, then I’ll let you know what I did. Thanks for the guidance.
                  sdetweil @BillW
                  @BillW this one too
                  https://www.cb-net.co.uk/linux/getting-analogue-sound-working-raspberry-pi-3b-raspbian-stretch/
                    BillW
                    Ok, tried all three but no luck, not sure what to do next. Here’s a copy of my config file if that may help
                    For more options and information see
                    http://rpf.io/configtxt
                    Some settings may impact device functionality. See link above for details
                    uncomment if you get no picture on HDMI for a default “safe” mode
                    #hdmi_safe=1
                    uncomment this if your display has a black border of unused pixels visible
                    and your display can output without overscan
                    #disable_overscan=1
                    uncomment the following to adjust overscan. Use positive numbers if console
                    goes off screen, and negative if there is too much border
                    #overscan_left=16
                    #overscan_right=16
                    #overscan_top=16
                    #overscan_bottom=16
                    uncomment to force a console size. By default it will be display’s size minus
                    overscan.
                    #framebuffer_width=1280
                    #framebuffer_height=720
                    uncomment if hdmi display is not detected and composite is being output
                    #hdmi_force_hotplug=1
                    uncomment to force a specific HDMI mode (this will force VGA)
                    #hdmi_group=1
                    #hdmi_mode=1
                    uncomment to force a HDMI mode rather than DVI. This can make audio work in
                    DMT (computer monitor) modes
                    #hdmi_drive=2
                    uncomment to increase signal to HDMI, if you have interference, blanking, or
                    no display
                    #config_hdmi_boost=4
                    uncomment for composite PAL
                    #sdtv_mode=2
                    #uncomment to overclock the arm. 700 MHz is the default.
                    #arm_freq=800
                    Uncomment some or all of these to enable the optional hardware interfaces
                    #dtparam=i2c_arm=on
                    #dtparam=i2s=on
                    #dtparam=spi=on
                    Uncomment this to enable the lirc-rpi module
                    #dtoverlay=lirc-rpi
                    Additional overlays and parameters are documented /boot/overlays/README
                    Enable audio (loads snd_bcm2835)
                    #dtparam=audio=on
                    [pi0]
                    dtoverlay=dwc2
                    [all]
                    start_x=1
                    gpu_mem=128
                    dtoverlay=googlevoicehat-soundcard
                    display_rotate=1
                    Sorry for the large font, not well verse with the editing portion of this forum.
                      sdetweil @BillW
                      @BillW use the markdown 3 backticks before and after… key to the left of number 1
                      you can edit it… pound sign makes large font
                      my device doesn’t have an analog audio port
                        BillW
                        My knowledge of this is very limited, I don’t understand where you want me to put the markdown at?
                        S bheplerB Mykle1M 3 Replies Last reply Reply Quote 0
                          sdetweil @BillW
                          @BillW edit your previous post.
                          In front of the content you pasted in, on a separate line, put three backtics
                          Then go to the end of the content you pasted, add a new line and put three backtics there. Submit your post update
                          • bheplerB Offline
                            bhepler Module Developer @BillW
                            @BillW - You can find the markdown commands at this link. Please use them to post code, file contents and commands.
                              Mykle1 Project Sponsor Module Developer @BillW
                              @BillW
                              Just to add to what @bhepler and @sdetweil are suggesting about posting code on the forum;
                              https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                BillW
                                I have sound! Thanks for all the help. What I did, after I read some the links provided, I decided to format another SD card and reload all my programs and I got sound. Then I compared the two SD card files and found that the original card had a file called AIY Project Voice, this program overwrote some of the files and change the parameters for output, apparently my grandson downloaded it thinking he was helping. Now all is good and I’ve learned a lot with every ones help. Thanks again.
