No sound from my RPi 3 B.
16 Posts 4 Posters 5.2k Views 3 Watching
    BillW
    Thanks in advance. I’ve been searching the forum and have not found an solution for this. Currently I am running a Raspberry Pi 3 B. I have MM loaded and some modules loaded. I have a HDMI to DVI cable attached going to my monitor. Any help is appreciated.
    Thanks,
    Bill
    S 1 Reply Last reply Apr 16, 2019, 12:50 AM Reply Quote 0
    • S Away
      sdetweil @BillW
      @BillW dvi does not carry sound so you would need a separate cable
      My main computer has dvi, monitor is HDMI. Uses sep cable to monitor
        BillW
        I should have included in my first post, but I did attach a separate cable for sound to speakers, but that didn’t work so I tried earphones to make sure. Thanks for confirming that for me. Any other suggestions?
        S 1 Reply Last reply Apr 16, 2019, 1:50 AM Reply Quote 0
        • S Away
          sdetweil @BillW
          @BillW did the earphones work?
          S B 2 Replies Last reply Apr 16, 2019, 1:50 AM Reply Quote 0
          • S Away
            @sdetweil do system sounds work?
              BillW @sdetweil
              @sdetweil No
              • S Away
                https://www.raspberrypi.org/documentation/configuration/audio-config.md
                Sound is going out the HDMI cable
                  BillW
                  I’ll follow the link and check it out, then I’ll let you know what I did. Thanks for the guidance.
                  S 1 Reply Last reply Apr 16, 2019, 2:22 AM Reply Quote 0
                  • S Away
                    sdetweil @BillW
                    @BillW this one too
                    https://www.cb-net.co.uk/linux/getting-analogue-sound-working-raspberry-pi-3b-raspbian-stretch/
                      BillW
                      Ok, tried all three but no luck, not sure what to do next. Here’s a copy of my config file if that may help
                      For more options and information see
                      http://rpf.io/configtxt
                      Some settings may impact device functionality. See link above for details
                      uncomment if you get no picture on HDMI for a default “safe” mode
                      #hdmi_safe=1
                      uncomment this if your display has a black border of unused pixels visible
                      and your display can output without overscan
                      #disable_overscan=1
                      uncomment the following to adjust overscan. Use positive numbers if console
                      goes off screen, and negative if there is too much border
                      #overscan_left=16
                      #overscan_right=16
                      #overscan_top=16
                      #overscan_bottom=16
                      uncomment to force a console size. By default it will be display’s size minus
                      overscan.
                      #framebuffer_width=1280
                      #framebuffer_height=720
                      uncomment if hdmi display is not detected and composite is being output
                      #hdmi_force_hotplug=1
                      uncomment to force a specific HDMI mode (this will force VGA)
                      #hdmi_group=1
                      #hdmi_mode=1
                      uncomment to force a HDMI mode rather than DVI. This can make audio work in
                      DMT (computer monitor) modes
                      #hdmi_drive=2
                      uncomment to increase signal to HDMI, if you have interference, blanking, or
                      no display
                      #config_hdmi_boost=4
                      uncomment for composite PAL
                      #sdtv_mode=2
                      #uncomment to overclock the arm. 700 MHz is the default.
                      #arm_freq=800
                      Uncomment some or all of these to enable the optional hardware interfaces
                      #dtparam=i2c_arm=on
                      #dtparam=i2s=on
                      #dtparam=spi=on
                      Uncomment this to enable the lirc-rpi module
                      #dtoverlay=lirc-rpi
                      Additional overlays and parameters are documented /boot/overlays/README
                      Enable audio (loads snd_bcm2835)
                      #dtparam=audio=on
                      [pi0]
                      dtoverlay=dwc2
                      [all]
                      start_x=1
                      gpu_mem=128
                      dtoverlay=googlevoicehat-soundcard
                      display_rotate=1
                      Sorry for the large font, not well verse with the editing portion of this forum.
                      S 1 Reply Last reply Apr 16, 2019, 3:32 AM Reply Quote 0
