    690 Posts 77 Posters 3.3m Views 70 Watching
    • A
      Anthony Project Sponsor @cowboysdude
      @cowboysdude
      Sorry mate but still everything is in English. No Greek at all. Am I doing something wrong?
        Paddi @nobita
        @nobita
        I really like the way you are presenting information ! Great Job.
        It is for the NOAA3 module on this picture
        https://forum.magicmirror.builders/assets/uploads/files/1530492418205-edit.png
        Would you be able to share you css ?
        Thanks a lot.
          dazza120
          Guys are you having issues with this module constantly calling Darksky? even on default settings.
          • A
            @cowboysdude
            I think something is wrong with the module’s translation because when the language in my config.js is en the module’s language is in English but when I change the language in my config.js in gr I get black blank screen. But if disable NOAA3 everything loads as they should. I hope this will help you to find the solution.
            • F
              Fonfon
              Thanks for this beautiful module !!
              I have only one problem why under "4 days forecast " there are nothing ???
              thanks for your help
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @Fonfon
                @Fonfon
                1. Have you modified any of the module files?
                2. Are there any errors being reported in the dev console?
                3. What provider are you using? Darksky seems to be the most reliable.
                4. It might be your location. If you give me your latitude and longitude I will test it for you.
                This is with Paris, France latitude and longitude, using Darksky API and AQI key
                • F
                  Fonfon
                  Thanks for Your help Mykle1 works great with darksky !
                  • N
                    NoNameRo
                    How can I change it so it looks like in the picture ?
                      Manu85 @cowboysdude
                      @cowboysdude
                      hello, I’m sorry but my english very bad … I installed the module MMM-NOAA3 and I thank the creator of this module it is really very effective, for cons I can not change the format of the date in the forecast module, the date is displayed digitally and I would like to have the days of the week as in the images of the github ie Monday, Tuesday, Wednesday etc. can you help me please, Regards
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Manu85
                        @Manu85
                        Are you asking about MMM-NOAA3? There is no date in NOAA3. This thread is about the NOAA3 module.
                          Manu85 @Mykle1
                          @Mykle1
                          hello, I speak well of this module, the forecasts are eg: 04-22. 04-23 and I will want: Monday. Tuesday
                          • Mykle1M
                            @Manu85 said in MMM-NOAA - Another Weather Module:
                            Oh, yes, I see now. I don’t know how you got the date instead of the day names. Mine only shows day names. That’s strange.
                            Are you using the newest version of the module? Please run git pull in the MMM-NOAA3 directory. Then run npm install as well. Are you using the darksky api? I think there was an issue with some of the other providers. You will have the most success with a darksky api key.
                              seramik
                              does this module contain configuration options ?
                              if I dont want all this plenty of information ?
                              is there an exemple of config.js with darkside provider ?
                              ok, i found the p51 one, and i just understood for airkey.
                              bheplerB 1 Reply Last reply
                              • bheplerB
                                bhepler Module Developer @seramik
                                @seramik said in MMM-NOAA - Another Weather Module:
                                You can always adjust the custom CSS file to reduce the size of the elements you wish to hide to zero.
                                • A
                                  andyyy
                                  In my case the 4 day forecast is not shown. There is nothing below the bar. I am using openweather as provider. What could be the issue?
                                  A Mykle1M 2 Replies Last reply
                                  • A
                                    andyyy @andyyy
                                    @andyyy
                                    however, with weatherunlocked it seems to work!
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @andyyy
                                      @andyyy
                                      Try another provider, such as @andyyy’s, or darksky, and see if it works correctly. There may be some issue with the provider you are using. Report your results back here.
                                      Using darksky provider:
                                        Buncie
                                        So I’m using this modules and I was wondering how to change it from celsius to fahrenheit. Can anyone help me?
                                          Buncie
                                          Nevermind
                                          • cowboysdudeC
                                            cowboysdude Module Developer @Buncie
                                            @Buncie said in MMM-NOAA - Another Weather Module:
                                            Nevermind
                                            Did you get it? LOL
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
