    690 Posts 77 Posters 3.1m Views 70 Watching
      Mykle1 Project Sponsor Module Developer @Manu85
      @Manu85
      Are you asking about MMM-NOAA3? There is no date in NOAA3. This thread is about the NOAA3 module.
        Manu85 @Mykle1
        @Mykle1
        hello, I speak well of this module, the forecasts are eg: 04-22. 04-23 and I will want: Monday. Tuesday
          @Manu85 said in MMM-NOAA - Another Weather Module:
          Oh, yes, I see now. I don’t know how you got the date instead of the day names. Mine only shows day names. That’s strange.
          Are you using the newest version of the module? Please run git pull in the MMM-NOAA3 directory. Then run npm install as well. Are you using the darksky api? I think there was an issue with some of the other providers. You will have the most success with a darksky api key.
            seramik
            does this module contain configuration options ?
            if I dont want all this plenty of information ?
            is there an exemple of config.js with darkside provider ?
            ok, i found the p51 one, and i just understood for airkey.
              bhepler Module Developer @seramik
              @seramik said in MMM-NOAA - Another Weather Module:
              You can always adjust the custom CSS file to reduce the size of the elements you wish to hide to zero.
                andyyy
                In my case the 4 day forecast is not shown. There is nothing below the bar. I am using openweather as provider. What could be the issue?
                A Mykle1M 2 Replies Last reply Reply Quote 0
                  andyyy @andyyy
                  @andyyy
                  however, with weatherunlocked it seems to work!
                    Mykle1 Project Sponsor Module Developer @andyyy
                    @andyyy
                    Try another provider, such as @andyyy’s, or darksky, and see if it works correctly. There may be some issue with the provider you are using. Report your results back here.
                    Using darksky provider:
                      Buncie
                      So I’m using this modules and I was wondering how to change it from celsius to fahrenheit. Can anyone help me?
                        Buncie
                        Nevermind
                        • cowboysdudeC Offline
                          cowboysdude Module Developer @Buncie
                          @Buncie said in MMM-NOAA - Another Weather Module:
                          Nevermind
                          Did you get it? LOL
                            BD0G
                            Here is my syntax within the config.js for MMM-NOAA3
                            		module: 'MMM-NOAA3',
                            		position: 'top_left',
                            			provider: "darksky", // From list above
                            			apiKey: "65141db17f5fe5d7d9dd8879b81a61a9",        // From one of the providers listed above
                            			airKey: "5ac100c9-5114-4140-9955-3067633998f9",
                            			css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                            			userlat: "39.164581", //MUST HAVE BOTH
                            			userlon: "-119.766922"  //MUST HAVE BOTH
                            My config.js does not present any errors and when the module loads in the upper left hand corner it displays undefined
                            then NaN o and all the values below that are not properly populated.
                            I have checked the entries and cannot seem to find the issue.
                              Mykle1 Project Sponsor Module Developer @BD0G
                              @BD0G said in MMM-NOAA - Another Weather Module:
                              There is no issue with your config entry. I just used it and here is the result.
                              In the future you should not post your api keys. They are yours and should be kept private.
                              How are things in Carson City? :-)
                                BD0G @Mykle1
                                @Mykle1 Thanks for checking it for me. Strangely it does not appear to be displaying the values. If someone wants to use my API keys - I say let em. It would display Carson City, NV specific data which is useless unless one happens to be in the same area.
                                Its great here ! We just had our first snowfall of the year 2 days ago and its really adds to the ambiance of the season. Headed to Lake Tahoe today for the best Thanksgiving buffet at Harrahs Casino (Forest Buffet). Beautiful views of snow covered ski resorts viewed through panoramic windows!
                                  BD0G
                                  Here is what I get
                                    Here is what I get
                                    Ok, well we know it’s not the config entry so lets check:
                                    1. Did you run npm install in the MMM-NOAA3 directory?
                                    2. Tried deleting and recloning the module from guthub?
                                    3. Disabling your other modules?
                                      Nice. Enjoy your holiday.
                                        BD0G @Mykle1
                                        @Mykle1
                                        Did you run npm install in the MMM-NOAA3 directory? Yes - appeared to install correctly.
                                        Tried deleting and recloning the module from guthub? No. Next on the list of things to do.
                                        Disabling your other modules? Thats another great suggestion. Gotta try that after a reclone and reinstall.
                                          BD0G
                                          Did you run npm install in the MMM-NOAA3 directory? YES
                                          Tried deleting and recloning the module from guthub? YES!
                                          Still not working at this point
                                          Disabling your other modules? YES! Disabled every other module and restarted Magic Mirror.
                                          Now the MMM-NOAA3 module is displayed !
                                          So there appears to be a conflict with another module.
                                          Next steps are to enable each module one by one and restart after doing so with each one.
                                          I wonder which one it is?
                                            You only need restart MM, not your entire system. That shouldn’t take too long. Let me know your findings.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
