    690 Posts 77 Posters 2.9m Views 70 Watching
      andyyy
      In my case the 4 day forecast is not shown. There is nothing below the bar. I am using openweather as provider. What could be the issue?
      A Mykle1M 2 Replies Last reply Reply Quote 0
        andyyy @andyyy
        @andyyy
        however, with weatherunlocked it seems to work!
          Mykle1 Project Sponsor Module Developer @andyyy
          @andyyy
          Try another provider, such as @andyyy’s, or darksky, and see if it works correctly. There may be some issue with the provider you are using. Report your results back here.
          Using darksky provider:
            Buncie
            So I’m using this modules and I was wondering how to change it from celsius to fahrenheit. Can anyone help me?
              Buncie
              Nevermind
              • cowboysdudeC Offline
                cowboysdude Module Developer @Buncie
                @Buncie said in MMM-NOAA - Another Weather Module:
                Nevermind
                Did you get it? LOL
                  BD0G
                  Here is my syntax within the config.js for MMM-NOAA3
                  		module: 'MMM-NOAA3',
                  		position: 'top_left',
                  			provider: "darksky", // From list above
                  			apiKey: "65141db17f5fe5d7d9dd8879b81a61a9",        // From one of the providers listed above
                  			airKey: "5ac100c9-5114-4140-9955-3067633998f9",
                  			css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                  			userlat: "39.164581", //MUST HAVE BOTH
                  			userlon: "-119.766922"  //MUST HAVE BOTH
                  My config.js does not present any errors and when the module loads in the upper left hand corner it displays undefined
                  then NaN o and all the values below that are not properly populated.
                  I have checked the entries and cannot seem to find the issue.
                    Mykle1 Project Sponsor Module Developer @BD0G
                    @BD0G said in MMM-NOAA - Another Weather Module:
                    There is no issue with your config entry. I just used it and here is the result.
                    In the future you should not post your api keys. They are yours and should be kept private.
                    How are things in Carson City? :-)
                      BD0G @Mykle1
                      @Mykle1 Thanks for checking it for me. Strangely it does not appear to be displaying the values. If someone wants to use my API keys - I say let em. It would display Carson City, NV specific data which is useless unless one happens to be in the same area.
                      Its great here ! We just had our first snowfall of the year 2 days ago and its really adds to the ambiance of the season. Headed to Lake Tahoe today for the best Thanksgiving buffet at Harrahs Casino (Forest Buffet). Beautiful views of snow covered ski resorts viewed through panoramic windows!
                        BD0G
                        Here is what I get
                          Here is what I get
                          Ok, well we know it’s not the config entry so lets check:
                          1. Did you run npm install in the MMM-NOAA3 directory?
                          2. Tried deleting and recloning the module from guthub?
                          3. Disabling your other modules?
                            Nice. Enjoy your holiday.
                              BD0G @Mykle1
                              @Mykle1
                              Did you run npm install in the MMM-NOAA3 directory? Yes - appeared to install correctly.
                              Tried deleting and recloning the module from guthub? No. Next on the list of things to do.
                              Disabling your other modules? Thats another great suggestion. Gotta try that after a reclone and reinstall.
                                BD0G
                                Did you run npm install in the MMM-NOAA3 directory? YES
                                Tried deleting and recloning the module from guthub? YES!
                                Still not working at this point
                                Disabling your other modules? YES! Disabled every other module and restarted Magic Mirror.
                                Now the MMM-NOAA3 module is displayed !
                                So there appears to be a conflict with another module.
                                Next steps are to enable each module one by one and restart after doing so with each one.
                                I wonder which one it is?
                                  You only need restart MM, not your entire system. That shouldn’t take too long. Let me know your findings.
                                    BD0G @Mykle1
                                    @Mykle1 Yup. I just do a PM2 restart 0. :)
                                      @BD0G
                                      Hope you’re having some success getting a fresh config.js.sample. Remember never to modify this file. Only use “copies” of it that you rename to config.js.
                                      Here you can see that the calendar and noaa3 run happily together. Talk tomorrow. Peace.
                                        Good things happen when your config.js is working ;)
                                          @cowboysdude
                                          What’s a config.js?
                                            BD0G
                                            Now that I have scrapped my Pi Zero W and have done a fresh install of “Buster” and MM on my Pi 3 B Plus everything is playing together nicely!
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
