    690 Posts 77 Posters 3.1m Views 70 Watching
      dazza120
      Guys are you having issues with this module constantly calling Darksky? even on default settings.
        Anthony Project Sponsor
        @cowboysdude
        I think something is wrong with the module’s translation because when the language in my config.js is en the module’s language is in English but when I change the language in my config.js in gr I get black blank screen. But if disable NOAA3 everything loads as they should. I hope this will help you to find the solution.
        • F Offline
          Fonfon
          Thanks for this beautiful module !!
          I have only one problem why under "4 days forecast " there are nothing ???
          thanks for your help
            Mykle1 Project Sponsor Module Developer @Fonfon
            @Fonfon
            1. Have you modified any of the module files?
            2. Are there any errors being reported in the dev console?
            3. What provider are you using? Darksky seems to be the most reliable.
            4. It might be your location. If you give me your latitude and longitude I will test it for you.
            This is with Paris, France latitude and longitude, using Darksky API and AQI key
            • F Offline
              Fonfon
              Thanks for Your help Mykle1 works great with darksky !
              • N Offline
                NoNameRo
                How can I change it so it looks like in the picture ?
                  Manu85 @cowboysdude
                  @cowboysdude
                  hello, I’m sorry but my english very bad … I installed the module MMM-NOAA3 and I thank the creator of this module it is really very effective, for cons I can not change the format of the date in the forecast module, the date is displayed digitally and I would like to have the days of the week as in the images of the github ie Monday, Tuesday, Wednesday etc. can you help me please, Regards
                    Mykle1 Project Sponsor Module Developer @Manu85
                    @Manu85
                    Are you asking about MMM-NOAA3? There is no date in NOAA3. This thread is about the NOAA3 module.
                      Manu85 @Mykle1
                      @Mykle1
                      hello, I speak well of this module, the forecasts are eg: 04-22. 04-23 and I will want: Monday. Tuesday
                        @Manu85 said in MMM-NOAA - Another Weather Module:
                        Oh, yes, I see now. I don’t know how you got the date instead of the day names. Mine only shows day names. That’s strange.
                        Are you using the newest version of the module? Please run git pull in the MMM-NOAA3 directory. Then run npm install as well. Are you using the darksky api? I think there was an issue with some of the other providers. You will have the most success with a darksky api key.
                          seramik
                          does this module contain configuration options ?
                          if I dont want all this plenty of information ?
                          is there an exemple of config.js with darkside provider ?
                          ok, i found the p51 one, and i just understood for airkey.
                            bhepler Module Developer @seramik
                            @seramik said in MMM-NOAA - Another Weather Module:
                            You can always adjust the custom CSS file to reduce the size of the elements you wish to hide to zero.
                              andyyy
                              In my case the 4 day forecast is not shown. There is nothing below the bar. I am using openweather as provider. What could be the issue?
                              A Mykle1M 2 Replies Last reply Reply Quote 0
                                andyyy @andyyy
                                @andyyy
                                however, with weatherunlocked it seems to work!
                                  Mykle1 Project Sponsor Module Developer @andyyy
                                  @andyyy
                                  Try another provider, such as @andyyy’s, or darksky, and see if it works correctly. There may be some issue with the provider you are using. Report your results back here.
                                  Using darksky provider:
                                    Buncie
                                    So I’m using this modules and I was wondering how to change it from celsius to fahrenheit. Can anyone help me?
                                      Buncie
                                      Nevermind
                                      • cowboysdudeC Offline
                                        cowboysdude Module Developer @Buncie
                                        @Buncie said in MMM-NOAA - Another Weather Module:
                                        Nevermind
                                        Did you get it? LOL
                                          BD0G
                                          Here is my syntax within the config.js for MMM-NOAA3
                                          		module: 'MMM-NOAA3',
                                          		position: 'top_left',
                                          			provider: "darksky", // From list above
                                          			apiKey: "65141db17f5fe5d7d9dd8879b81a61a9",        // From one of the providers listed above
                                          			airKey: "5ac100c9-5114-4140-9955-3067633998f9",
                                          			css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                                          			userlat: "39.164581", //MUST HAVE BOTH
                                          			userlon: "-119.766922"  //MUST HAVE BOTH
                                          My config.js does not present any errors and when the module loads in the upper left hand corner it displays undefined
                                          then NaN o and all the values below that are not properly populated.
                                          I have checked the entries and cannot seem to find the issue.
                                            Mykle1 Project Sponsor Module Developer @BD0G
                                            @BD0G said in MMM-NOAA - Another Weather Module:
                                            There is no issue with your config entry. I just used it and here is the result.
                                            In the future you should not post your api keys. They are yours and should be kept private.
                                            How are things in Carson City? :-)
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
