    MMM-ImagesPhotos - Show images from a directory
    85 Posts 26 Posters 127.3k Views 26 Watching
      Peter
      Very nice module.
      I have about 2000 pictures in the Upload directory, all resized to 100 kb.
      But the module only shows about 50 of them.
      Why does it not show the other pictures?
      Any idea?
      Peter
      N 1 Reply Last reply
      • N
        ninjabreadman @Peter
        @Peter
        What does your config look like? Where are your images? What type(s) are they? I tried making a folder with 100 files (well over 50), but that seemed to work fine.
        Do you have the photos in multiple folders/paths? If so, have you tried removing the path of the photos that work to leave the other paths (to determine they work)? Have you tried adding treatAllPathsAsOne: true to your module config?
        What is the content of photos.txt if you type curl http://localhost:8080/MMM-ImagesPhotos/photos > photos.txt into a separate console (while MM is running)?
        Don’t post it all here, but if there are not several thousand entries, the module is not seeing all of your files (but you knew that).
        P 1 Reply Last reply
          Peter @ninjabreadman
          @ninjabreadman solved.
          I did something stupid.
          I had 70 pictures (5mb each) and it caused trouble, so I resized them to 100kb.
          But I also have 2 sd cards …
          I put 2000 pictures (100kb) on one card and left the 70 (5mb) pictures on the other card.
          And then I changed cards …
          Peter
          • N
            @Peter At least it’s fixed! Cheers.
              pepebc
              I like this module, but I would like it to start hidden by default in order to add the possibility of making it visible with voice command (use alexyak / voicecontrol). I have tried several options but I have no results.
              Mykle1M 1 Reply Last reply
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @pepebc
                @pepebc
                Take a look at the Hello-Lucy files. You can adapt what you find there to alex yak voice control. :-)
                • twosquirrelsT
                  twosquirrels
                  I realize this might not be the fault of the module, but many of my images display with the orientation incorrect on this module. I open them on my Mac, and the orientation is correct. I open them in the built-in image viewer on the raspberry pi, and the orientation is correct.
                  I’ve tried using exiftool to remove the orientation settings entirely with no success. I also tried using exiftool to change the orientation with no success.
                  My magic mirror is in portrait mode, so I wonder if that matters, but the built-in viewer has no problems.
                  • N
                    ninjabreadman @twosquirrels
                    @twosquirrels So, I suspect (but cannot be certain) that this is your problem. I’ve not found great browser support for EXIF image rotation. There are a variety of command line approaches available, and even some GUI apps.
                    twosquirrelsT 1 Reply Last reply
                    • twosquirrelsT
                      twosquirrels @ninjabreadman
                      @ninjabreadman exiftran worked wonderfully! I used the “automatic” option and it fixed them all! Thanks!
                        chassain 0 @Galang
                        @Galang Hello, no news about no random ? it will be great for my configuration
                          sdetweil @chassain 0
                          @chassain-0 ImagesPhotos already does random all the time.
                          	randomPhoto: function() {
                          		var photos = this.photos;
                          		var index = this.randomIndex(photos);
                          		return photos[index];
                          	getDom: function() {
                          		var self = this;
                          		var photoImage = this.randomPhoto();
                          C 1 Reply Last reply
                            chassain 0 @sdetweil
                            @sdetweil sorry…i would say in order
                              @chassain-0 ah, turn off random
                                chassain 0
                                yes of course…but not so easy for me…i 'm looking for :)
                                B 1 Reply Last reply
                                  broberg Project Sponsor @chassain 0
                                  @chassain-0
                                  I don’t know if this works but
                                  	randomIndex: function(photos) {
                                  		if (photos.length === 1) {
                                  			return 0;
                                  		var generate = function() {
                                  			return Math.floor(Math.random() * photos.length);
                                  		var photoIndex = generate();
                                  		this.lastPhotoIndex = photoIndex;
                                  		return photoIndex;
                                  try to change return Math.floor(Math.random() * photos.length); to return Math.floor(photos.length);
                                  However it’s Just a guess
                                    sdetweil @broberg
                                    @broberg no. it needs more… need to USE the this.lastPhotoIndex, and check for over the end of the list,
                                    and reset the index when new list is loaded (even tho you didn’t get thru the list, as the module refreshes on a fixed time schedule (not calculated from number of images found)… I would add another config parm
                                    I have a fork of this module already, but have many local changes, so cannot make another.
                                      chassain 0
                                      I found this module : https://github.com/AdamMoses-GitHub/MMM-ImageSlideshow
                                      Maybe a solution. I m going to test this night
                                      • KamiSchamiK
                                        KamiSchami
                                        I would like to install it twice. If I just copy the folder and rename it, it won’t work anymore. Can somebody help me?
                                        Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                                          u can try mine too
                                          https://github.com/sdetweil/MMM-ImagesPhotos
                                          to make images from a server the module/uploads folder needs to be replaced by a linked (ln command) to the server share folder
                                          ln -s server_share uploads
                                          I am very picky about how my images are displayed, no distortion allowed…
                                          I also support color or blurred image fill where the image does not cover the full screen
                                          • KamiSchamiK
                                            KamiSchami
                                            ok, it has the same name. can I rename the module for myself, the folder?
                                            • 4 / 5
