    MMM-ImagesPhotos - Show images from a directory
    85 Posts 26 Posters 127.3k Views 26 Watching
    • N
      ninjabreadman @Peter
      @Peter
      What does your config look like? Where are your images? What type(s) are they? I tried making a folder with 100 files (well over 50), but that seemed to work fine.
      Do you have the photos in multiple folders/paths? If so, have you tried removing the path of the photos that work to leave the other paths (to determine they work)? Have you tried adding treatAllPathsAsOne: true to your module config?
      What is the content of photos.txt if you type curl http://localhost:8080/MMM-ImagesPhotos/photos > photos.txt into a separate console (while MM is running)?
      Don’t post it all here, but if there are not several thousand entries, the module is not seeing all of your files (but you knew that).
      P 1 Reply Last reply
        Peter @ninjabreadman
        @ninjabreadman solved.
        I did something stupid.
        I had 70 pictures (5mb each) and it caused trouble, so I resized them to 100kb.
        But I also have 2 sd cards …
        I put 2000 pictures (100kb) on one card and left the 70 (5mb) pictures on the other card.
        And then I changed cards …
        Peter
        N 1 Reply Last reply
        • N
          @Peter At least it’s fixed! Cheers.
            pepebc
            I like this module, but I would like it to start hidden by default in order to add the possibility of making it visible with voice command (use alexyak / voicecontrol). I have tried several options but I have no results.
            Mykle1M 1 Reply Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @pepebc
              @pepebc
              Take a look at the Hello-Lucy files. You can adapt what you find there to alex yak voice control. :-)
              • twosquirrelsT
                twosquirrels
                I realize this might not be the fault of the module, but many of my images display with the orientation incorrect on this module. I open them on my Mac, and the orientation is correct. I open them in the built-in image viewer on the raspberry pi, and the orientation is correct.
                I’ve tried using exiftool to remove the orientation settings entirely with no success. I also tried using exiftool to change the orientation with no success.
                My magic mirror is in portrait mode, so I wonder if that matters, but the built-in viewer has no problems.
                • N
                  ninjabreadman @twosquirrels
                  @twosquirrels So, I suspect (but cannot be certain) that this is your problem. I’ve not found great browser support for EXIF image rotation. There are a variety of command line approaches available, and even some GUI apps.
                  twosquirrelsT 1 Reply Last reply
                  • twosquirrelsT
                    twosquirrels @ninjabreadman
                    @ninjabreadman exiftran worked wonderfully! I used the “automatic” option and it fixed them all! Thanks!
                      chassain 0 @Galang
                      @Galang Hello, no news about no random ? it will be great for my configuration
                        sdetweil @chassain 0
                        @chassain-0 ImagesPhotos already does random all the time.
                        	randomPhoto: function() {
                        		var photos = this.photos;
                        		var index = this.randomIndex(photos);
                        		return photos[index];
                        	getDom: function() {
                        		var self = this;
                        		var photoImage = this.randomPhoto();
                        C 1 Reply Last reply
                          chassain 0 @sdetweil
                          @sdetweil sorry…i would say in order
                            @chassain-0 ah, turn off random
                              chassain 0
                              yes of course…but not so easy for me…i 'm looking for :)
                              B 1 Reply Last reply
                                broberg Project Sponsor @chassain 0
                                @chassain-0
                                I don’t know if this works but
                                	randomIndex: function(photos) {
                                		if (photos.length === 1) {
                                			return 0;
                                		var generate = function() {
                                			return Math.floor(Math.random() * photos.length);
                                		var photoIndex = generate();
                                		this.lastPhotoIndex = photoIndex;
                                		return photoIndex;
                                try to change return Math.floor(Math.random() * photos.length); to return Math.floor(photos.length);
                                However it’s Just a guess
                                  sdetweil @broberg
                                  @broberg no. it needs more… need to USE the this.lastPhotoIndex, and check for over the end of the list,
                                  and reset the index when new list is loaded (even tho you didn’t get thru the list, as the module refreshes on a fixed time schedule (not calculated from number of images found)… I would add another config parm
                                  I have a fork of this module already, but have many local changes, so cannot make another.
                                    chassain 0
                                    I found this module : https://github.com/AdamMoses-GitHub/MMM-ImageSlideshow
                                    Maybe a solution. I m going to test this night
                                    • KamiSchamiK
                                      KamiSchami
                                      I would like to install it twice. If I just copy the folder and rename it, it won’t work anymore. Can somebody help me?
                                      Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
                                        u can try mine too
                                        https://github.com/sdetweil/MMM-ImagesPhotos
                                        to make images from a server the module/uploads folder needs to be replaced by a linked (ln command) to the server share folder
                                        ln -s server_share uploads
                                        I am very picky about how my images are displayed, no distortion allowed…
                                        I also support color or blurred image fill where the image does not cover the full screen
                                        • KamiSchamiK
                                          KamiSchami
                                          ok, it has the same name. can I rename the module for myself, the folder?
                                            sdetweil @KamiSchami
                                            @KamiSchami rename the old folder, then git clone again from my repo, fixup any config parts, make link, or move link from old folder
                                            • 4 / 5
