    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 133.6k Views 25 Watching
    • FoziF
      Fozi Project Sponsor @lavolp3
      @lavolp3 yes, should do equally. I had some leftover of the tape and it was more convenient to apply. I found some post from you a few months ago, when you struggled to make the sensor work. I hope you get some better results now.
      • cowboysdudeC
        cowboysdude Module Developer @Fozi
        @Fozi Is there a wiring diagram for this? I know where the wires on my pi are and there two wires running to the sensor but where are they connected on the actual sensor?
        Thanks!
        • FoziF
          Fozi Project Sponsor @cowboysdude
          @cowboysdude
          You only use Vin (5V), Vout and GND. CDS (for applying a photo diode) and 3V3 (delivers 3.3V output) remain unused. For Vout you can use also oher GPIO pins (labeled “Digital I/O” in the 2nd diagram), in case GPIO_4 is already used.
          The ferrite bead is optional. It is a left over from the PIR sensor I had attached. If you may need one, you can dismantle an old VGA cable and use that one.
          Here the wireing diagram:
          • cowboysdudeC
            Super Awesome yet again!! Thank you! I don’t use the PIR module… I have a Python script I run behind everything. It works very well for me but this will work so nice, and now I can move it behind the glass!
            Now if I can just remember where I put my ferrite beads… I know I have some … but where LOL
            • FoziF
              Hi folks,
              sooner than expected I modified the sensor with a trimmer resistor.
              For that I also updated my initial post and enhanced the tutorial, where now both options are described. Enjoy and give me your feedback, how that works for you.
              S Mykle1M 2 Replies Last reply Reply Quote 2
                sdetweil @Fozi
                @Fozi nice update… very clear and helpful
                • cowboysdudeC
                  Once again excellent work! I love the trimmer it’s a great idea for those with limited space!
                  For some strange reason I have left a gap at the top of my mirror that fits what I build perfectly!
                  I wanted a bigger mirror so I bought the glass oversized and centered the monitor in it :)
                  This, accidently, left me enough room to fit this in perfectly!
                  So what I did was design a “T” with a whole in it to mount the sensor and install it inside the box.
                  I am a contractor so having aluminum tape was not a hard thing for me to come up with.
                  Thank you @Fozi for this entire project! Allows me to get rid of the ugly PIR sensor outside the mirror and place a sensor behind the scenes but works as intended.
                  So for me option 1 works great! This won’t work for everyone but in my case perfect!
                  [Have NOT installed it in the mirror yet but will today]
                  Here’s the pictures.
                  Box
                  3d PLA Printed ‘T’
                  Fits inside of box
                  Picture of sensor on ‘T’
                  Once again, Thank you @Fozi !!!
                  FoziF 1 Reply Last reply Reply Quote 2
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @Fozi
                    @Fozi said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                    Dude, (can I call you dude?) although I don’t use a sensor (I have a cam on my first mirror w/Pi) I appreciate what you’ve done here. I’ll say it again (in different words), I think this is the death knell of the PIR sensor. So, thanks. :thumbsup:
                    Peace!
                    FoziF 1 Reply Last reply Reply Quote 1
                    • FoziF
                      @cowboysdude I‘m totally happy that I cold help and to receive so positive feedback! I love it when a plan works!😁 Thanks!
                      This T-shaped holder, is it 3D-printed or an off-the-shelf available part? It‘s totally cool!
                      • FoziF
                        Fozi Project Sponsor @Mykle1
                        Sure, call me Dude, if you like😁
                        Let‘s get the warts outta here!🤣 and thanks for the overwhelming feedback!
                        • cowboysdudeC
                          Ok so here’s my final and it’s working perfectly! I tried it in various spots.
                          Thanks to @Fozi again…now there’s a very complete forum topic that anyone can follow!!
                          I added 2 additional layers of aluminum tape… there are no untaped spaces on the box anywhere… then moved it to the back of the cabinet and now you have to walk up to it to make it come on… PERFECT!! :)
                          I tried behind the glass… too sensitive
                          I tried taped to the back of the monitor … too sensitive.
                          Moved to the back of the cabinet which makes it about 4" away from the glass… BINGO!!
                          [PS… don’t mind my ugly wiring LOL]
                          FoziF lavolp3L 2 Replies Last reply Reply Quote 0
                          • FoziF
                            @cowboysdude Great News, excellent!👍🏻
                            • lavolp3L
                              lavolp3 Module Developer @cowboysdude
                              @cowboysdude
                              am I seeing it right that also the side of the case looking at you is aluminium taped?
                              So the whole case is taped in your case?
                              How to troubleshoot modules
                              MMM-soccer v2, MMM-AVStock
                              • lavolp3L
                                @cowboysdude @Fozi Guys, which module are you using for the recognition?
                                I can’t get neither MMM-PIR-Sensor nor MMM-PIR to work currently. Both have the same problem with epoll which is installed via the node module “onoff”, if I see correctly.
                                What are you using?
                                THe mirror won’t load with any of the modules activated giving the error
                                 The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff/node_modules/epoll/build/Release/epoll.node'
                                was compiled against a different Node.js version using
                                NODE_MODULE_VERSION 67. This version of Node.js requires
                                NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                the module (for instance, using `npm rebuild` or `npm install`).
                                @cowboysdude I remember you’re using your own script?
                                @Fozi you?
                                node v 11.4.0
                                npm v 6.13.0
                                cowboysdudeC FoziF 2 Replies Last reply Reply Quote 0
                                • cowboysdudeC
                                  cowboysdude Module Developer @lavolp3
                                  @lavolp3 I use my own for that… it’s not a module but it’s right here.
                                  https://github.com/cowboysdude/Pir-Sensor
                                  Easy to follow :)
                                  The box is just a cardboard box taped with alum duct tape. I am however waiting for my trimmer resister so I can tune it down and take it out of the box. I only want the mirror to come on when someone walks up to it…say like 2 ft. away… so it doesn’t come on when I walk by the bathroom doorway… looks more like a pro thing :)
                                  • FoziF
                                    @lavolp3 I use MMM-PIR-Sensor without any modifications. Are you using @paviro master oder any other fork of the module?
                                    As I see, you have more recent npm/node versions installed.
                                    I am still on node 10.17.0 / npm 6.11.3.
                                    Edit: I’d recommend to try the script from @cowboysdude . It is robust against any node.js stuff as it written in python.
                                    • NortonN
                                      Norton
                                      FoziF 1 Reply Last reply Reply Quote -1
                                      • FoziF
                                        Fozi Project Sponsor @Norton
                                        @Norton said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                                        It is important to replace the PIR sensor with a Doppler Microwave Sensor.
                                        This spam bot is sooo right!:face_with_tears_of_joy:
                                          bachoo786 @Fozi
                                          @Fozi Hi
                                          Can i solder pin 1 and 2 of the resistor to the radar sensor? I accidentally broke pin no 3.
                                          • FoziF
                                            Fozi Project Sponsor @bachoo786
                                            @bachoo786 yes, you can also use pin 1 and 2.
                                            An example:
                                            The max value of the resistor (Rmax) is between pin 1 and 3.
                                            Between pin 1 and 2 is the restitor value R1, and
                                            between pin 2 and 3 is the resistor value R2.
                                            Rmax = R1 + R2. (or R1=Rmax - R2, resp, R2=Rmax - R1)
                                            Thus, you can use both options (R1 pin 1/2 or R2 pin 2/3).
                                            • 2 / 6
