    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 136.3k Views 25 Watching
    • FoziF
      Fozi Project Sponsor @cowboysdude
      @cowboysdude Thanks! I’m looking forward to your experiences with the sensor!
      lavolp3L cowboysdudeC 2 Replies Last reply
      • lavolp3L
        lavolp3 Module Developer @Fozi
        @Fozi
        I’ll try this out hopefully tonight but not with an Aluminium tape but with aluminum foil. Should work as well as far as I can see.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        FoziF 1 Reply Last reply
        • FoziF
          Fozi Project Sponsor @lavolp3
          @lavolp3 yes, should do equally. I had some leftover of the tape and it was more convenient to apply. I found some post from you a few months ago, when you struggled to make the sensor work. I hope you get some better results now.
          • cowboysdudeC
            cowboysdude Module Developer @Fozi
            @Fozi Is there a wiring diagram for this? I know where the wires on my pi are and there two wires running to the sensor but where are they connected on the actual sensor?
            Thanks!
            • FoziF
              @cowboysdude
              You only use Vin (5V), Vout and GND. CDS (for applying a photo diode) and 3V3 (delivers 3.3V output) remain unused. For Vout you can use also oher GPIO pins (labeled “Digital I/O” in the 2nd diagram), in case GPIO_4 is already used.
              The ferrite bead is optional. It is a left over from the PIR sensor I had attached. If you may need one, you can dismantle an old VGA cable and use that one.
              Here the wireing diagram:
              Reply Quote 3
              • cowboysdudeC
                Super Awesome yet again!! Thank you! I don’t use the PIR module… I have a Python script I run behind everything. It works very well for me but this will work so nice, and now I can move it behind the glass!
                Now if I can just remember where I put my ferrite beads… I know I have some … but where LOL
                • FoziF
                  Hi folks,
                  sooner than expected I modified the sensor with a trimmer resistor.
                  For that I also updated my initial post and enhanced the tutorial, where now both options are described. Enjoy and give me your feedback, how that works for you.
                  S Mykle1M 2 Replies Last reply
                  Reply Quote 2
                    sdetweil @Fozi
                    @Fozi nice update… very clear and helpful
                    • cowboysdudeC
                      Once again excellent work! I love the trimmer it’s a great idea for those with limited space!
                      For some strange reason I have left a gap at the top of my mirror that fits what I build perfectly!
                      I wanted a bigger mirror so I bought the glass oversized and centered the monitor in it :)
                      This, accidently, left me enough room to fit this in perfectly!
                      So what I did was design a “T” with a whole in it to mount the sensor and install it inside the box.
                      I am a contractor so having aluminum tape was not a hard thing for me to come up with.
                      Thank you @Fozi for this entire project! Allows me to get rid of the ugly PIR sensor outside the mirror and place a sensor behind the scenes but works as intended.
                      So for me option 1 works great! This won’t work for everyone but in my case perfect!
                      [Have NOT installed it in the mirror yet but will today]
                      Here’s the pictures.
                      Box
                      3d PLA Printed ‘T’
                      Fits inside of box
                      Picture of sensor on ‘T’
                      Once again, Thank you @Fozi !!!
                      Reply Quote 2
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Fozi
                        @Fozi said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                        Dude, (can I call you dude?) although I don’t use a sensor (I have a cam on my first mirror w/Pi) I appreciate what you’ve done here. I’ll say it again (in different words), I think this is the death knell of the PIR sensor. So, thanks. :thumbsup:
                        Peace!
                        • FoziF
                          @cowboysdude I‘m totally happy that I cold help and to receive so positive feedback! I love it when a plan works!😁 Thanks!
                          This T-shaped holder, is it 3D-printed or an off-the-shelf available part? It‘s totally cool!
                          • FoziF
                            Fozi Project Sponsor @Mykle1
                            Sure, call me Dude, if you like😁
                            Let‘s get the warts outta here!🤣 and thanks for the overwhelming feedback!
                            • cowboysdudeC
                              Ok so here’s my final and it’s working perfectly! I tried it in various spots.
                              Thanks to @Fozi again…now there’s a very complete forum topic that anyone can follow!!
                              I added 2 additional layers of aluminum tape… there are no untaped spaces on the box anywhere… then moved it to the back of the cabinet and now you have to walk up to it to make it come on… PERFECT!! :)
                              I tried behind the glass… too sensitive
                              I tried taped to the back of the monitor … too sensitive.
                              Moved to the back of the cabinet which makes it about 4" away from the glass… BINGO!!
                              [PS… don’t mind my ugly wiring LOL]
                              FoziF lavolp3L 2 Replies Last reply
                              • FoziF
                                @cowboysdude Great News, excellent!👍🏻
                                • lavolp3L
                                  lavolp3 Module Developer @cowboysdude
                                  @cowboysdude
                                  am I seeing it right that also the side of the case looking at you is aluminium taped?
                                  So the whole case is taped in your case?
                                  • lavolp3L
                                    @cowboysdude @Fozi Guys, which module are you using for the recognition?
                                    I can’t get neither MMM-PIR-Sensor nor MMM-PIR to work currently. Both have the same problem with epoll which is installed via the node module “onoff”, if I see correctly.
                                    What are you using?
                                    THe mirror won’t load with any of the modules activated giving the error
                                     The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff/node_modules/epoll/build/Release/epoll.node'
                                    was compiled against a different Node.js version using
                                    NODE_MODULE_VERSION 67. This version of Node.js requires
                                    NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                    the module (for instance, using `npm rebuild` or `npm install`).
                                    @cowboysdude I remember you’re using your own script?
                                    @Fozi you?
                                    node v 11.4.0
                                    npm v 6.13.0
                                    cowboysdudeC FoziF 2 Replies Last reply
                                    • cowboysdudeC
                                      cowboysdude Module Developer @lavolp3
                                      @lavolp3 I use my own for that… it’s not a module but it’s right here.
                                      https://github.com/cowboysdude/Pir-Sensor
                                      Easy to follow :)
                                      The box is just a cardboard box taped with alum duct tape. I am however waiting for my trimmer resister so I can tune it down and take it out of the box. I only want the mirror to come on when someone walks up to it…say like 2 ft. away… so it doesn’t come on when I walk by the bathroom doorway… looks more like a pro thing :)
                                      • FoziF
                                        @lavolp3 I use MMM-PIR-Sensor without any modifications. Are you using @paviro master oder any other fork of the module?
                                        As I see, you have more recent npm/node versions installed.
                                        I am still on node 10.17.0 / npm 6.11.3.
                                        Edit: I’d recommend to try the script from @cowboysdude . It is robust against any node.js stuff as it written in python.
                                        • NortonN
                                          Norton
                                          Reply Quote -1
                                          • FoziF
                                            Fozi Project Sponsor @Norton
                                            @Norton said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                                            It is important to replace the PIR sensor with a Doppler Microwave Sensor.
                                            This spam bot is sooo right!:face_with_tears_of_joy:
                                            • 2 / 6
