    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 118.2k Views 25 Watching
    • FoziF Offline
      Fozi Project Sponsor
      Hi folks,
      sooner than expected I modified the sensor with a trimmer resistor.
      For that I also updated my initial post and enhanced the tutorial, where now both options are described. Enjoy and give me your feedback, how that works for you.
      S Mykle1M 2 Replies Last reply Reply Quote 2
        sdetweil @Fozi
        @Fozi nice update… very clear and helpful
        • cowboysdudeC Offline
          Once again excellent work! I love the trimmer it’s a great idea for those with limited space!
          For some strange reason I have left a gap at the top of my mirror that fits what I build perfectly!
          I wanted a bigger mirror so I bought the glass oversized and centered the monitor in it :)
          This, accidently, left me enough room to fit this in perfectly!
          So what I did was design a “T” with a whole in it to mount the sensor and install it inside the box.
          I am a contractor so having aluminum tape was not a hard thing for me to come up with.
          Thank you @Fozi for this entire project! Allows me to get rid of the ugly PIR sensor outside the mirror and place a sensor behind the scenes but works as intended.
          So for me option 1 works great! This won’t work for everyone but in my case perfect!
          [Have NOT installed it in the mirror yet but will today]
          Here’s the pictures.
          Box
          3d PLA Printed ‘T’
          Fits inside of box
          Picture of sensor on ‘T’
          Once again, Thank you @Fozi !!!
          FoziF 1 Reply Last reply Reply Quote 2
            Mykle1 Project Sponsor Module Developer @Fozi
            @Fozi said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
            Dude, (can I call you dude?) although I don’t use a sensor (I have a cam on my first mirror w/Pi) I appreciate what you’ve done here. I’ll say it again (in different words), I think this is the death knell of the PIR sensor. So, thanks. :thumbsup:
            Peace!
            FoziF 1 Reply Last reply Reply Quote 1
            • FoziF Offline
              Fozi Project Sponsor @cowboysdude
              @cowboysdude I‘m totally happy that I cold help and to receive so positive feedback! I love it when a plan works!😁 Thanks!
              This T-shaped holder, is it 3D-printed or an off-the-shelf available part? It‘s totally cool!
              • FoziF Offline
                Fozi Project Sponsor @Mykle1
                Sure, call me Dude, if you like😁
                Let‘s get the warts outta here!🤣 and thanks for the overwhelming feedback!
                  Ok so here’s my final and it’s working perfectly! I tried it in various spots.
                  Thanks to @Fozi again…now there’s a very complete forum topic that anyone can follow!!
                  I added 2 additional layers of aluminum tape… there are no untaped spaces on the box anywhere… then moved it to the back of the cabinet and now you have to walk up to it to make it come on… PERFECT!! :)
                  I tried behind the glass… too sensitive
                  I tried taped to the back of the monitor … too sensitive.
                  Moved to the back of the cabinet which makes it about 4" away from the glass… BINGO!!
                  [PS… don’t mind my ugly wiring LOL]
                  FoziF lavolp3L 2 Replies Last reply Reply Quote 0
                  • FoziF Offline
                    @cowboysdude Great News, excellent!👍🏻
                    • lavolp3L Offline
                      lavolp3 Module Developer @cowboysdude
                      @cowboysdude
                      am I seeing it right that also the side of the case looking at you is aluminium taped?
                      So the whole case is taped in your case?
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      • lavolp3L Offline
                        @cowboysdude @Fozi Guys, which module are you using for the recognition?
                        I can’t get neither MMM-PIR-Sensor nor MMM-PIR to work currently. Both have the same problem with epoll which is installed via the node module “onoff”, if I see correctly.
                        What are you using?
                        THe mirror won’t load with any of the modules activated giving the error
                         The module '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/onoff/node_modules/epoll/build/Release/epoll.node'
                        was compiled against a different Node.js version using
                        NODE_MODULE_VERSION 67. This version of Node.js requires
                        NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                        the module (for instance, using `npm rebuild` or `npm install`).
                        @cowboysdude I remember you’re using your own script?
                        @Fozi you?
                        node v 11.4.0
                        npm v 6.13.0
                        cowboysdudeC FoziF 2 Replies Last reply Reply Quote 0
                          cowboysdude Module Developer @lavolp3
                          @lavolp3 I use my own for that… it’s not a module but it’s right here.
                          https://github.com/cowboysdude/Pir-Sensor
                          Easy to follow :)
                          The box is just a cardboard box taped with alum duct tape. I am however waiting for my trimmer resister so I can tune it down and take it out of the box. I only want the mirror to come on when someone walks up to it…say like 2 ft. away… so it doesn’t come on when I walk by the bathroom doorway… looks more like a pro thing :)
                          • FoziF Offline
                            Fozi Project Sponsor @lavolp3
                            @lavolp3 I use MMM-PIR-Sensor without any modifications. Are you using @paviro master oder any other fork of the module?
                            As I see, you have more recent npm/node versions installed.
                            I am still on node 10.17.0 / npm 6.11.3.
                            Edit: I’d recommend to try the script from @cowboysdude . It is robust against any node.js stuff as it written in python.
                            • NortonN Offline
                              Norton
                              FoziF 1 Reply Last reply Reply Quote -1
                              • FoziF Offline
                                Fozi Project Sponsor @Norton
                                @Norton said in UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.:
                                It is important to replace the PIR sensor with a Doppler Microwave Sensor.
                                This spam bot is sooo right!:face_with_tears_of_joy:
                                  bachoo786 @Fozi
                                  @Fozi Hi
                                  Can i solder pin 1 and 2 of the resistor to the radar sensor? I accidentally broke pin no 3.
                                  • FoziF Offline
                                    Fozi Project Sponsor @bachoo786
                                    @bachoo786 yes, you can also use pin 1 and 2.
                                    An example:
                                    The max value of the resistor (Rmax) is between pin 1 and 3.
                                    Between pin 1 and 2 is the restitor value R1, and
                                    between pin 2 and 3 is the resistor value R2.
                                    Rmax = R1 + R2. (or R1=Rmax - R2, resp, R2=Rmax - R1)
                                    Thus, you can use both options (R1 pin 1/2 or R2 pin 2/3).
                                      bachoo786 @Fozi
                                      @Fozi so I got a new radar sensor set the resistance to 80ohms which would give me around 40 to 50cm detection distance. I am using @cowboysdude script.
                                      My mm is running on my rpi 4b 4g and at present its connected to my TV. However the rada sensor is not working as the script is meant to detect motion and if there is no motion it would turn the tv off after 20 seconds. I tried many times but have failed.
                                      Any ideas? Or maybe my sensor is not working. Is there a simple script that I could test the sensor?
                                      Thanks.
                                      FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
                                      • FoziF Offline
                                        @bachoo786 First re-check if the sensor is cabled correctly to the GPIO as described in my tutorial. Further check if the resistor is soldered correctly to the sensor. Maybe there is a “cold soldering joint”. Sounds trivial, but the devil is a squirrel (old german saying 0_1578041639036_41a3b8fa-8272-448b-8e93-36c6fb58809d-image.png )
                                        Then, extend the detection range to the max, to check if the sensor is generally OK (200 Ohms) and re-run @cowboysdude script. If this works, then reduce the resistor step by step until you reach the desired detection range. Theoretically 80 Ohms should provide a range of 40-50 cm, but from my experience this may vary strongly as the resistor value does not correspond linearly to the detection range.
                                          bachoo786 @Fozi
                                          @Fozi ok will do thanks.
                                            bachoo786 @Fozi
                                            @Fozi Hi
                                            I am on raspberry pi 4 and I think wiringPi does not work with it as the guy has stopped developing it any further. Is there any other way I could make this work?
                                            Thanks.
                                            • 2 / 6
