    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @surger13
      @surger13 ok, looks like we have to fight the manual way
      do
      git stash
      git merge
      npm install
      C S 2 Replies Last reply Reply Quote 0
      • evroomE
        evroom @sdetweil
        @sdetweil said in new update/upgrade script, ready for testing:
        weird… the package.json says
        Which exact package.json would that be?
        Perhaps mine tells to use 3.1.13?
        Although:
        pi@raspberrypi:~ $ grep electron ~/MagicMirror/package.json
          "main": "js/electron.js",
            "electron": "^3.0.13"
        MagicMirror version: 2.37.0
          sdetweil @evroom
          @evroom ah, it say CLOSE TO 3.0.13 (the hat char), not exactly 3.0.13
          so, do the manual step
          npm install electron@3.0.13
          evroomE 2 Replies Last reply Reply Quote 0
          • evroomE
            evroom @sdetweil
            ~version “Approximately equivalent to version”, will update you to the next patch version.
            ^version Will update you to the next minor version.
            version Will update you to the exact given version.
            • evroomE
              evroom @sdetweil
              Sam, shall I update my ~/MagicMirror/package.json file and try again?
              Edit:
              Just did.
              It says I am on 2.10.0 already, even though it was interrupted on the electro download.
              How can I force the upgrade or make it believe 2.9.0 is still active?
              In the package.json file?
              Edit 2:
              Changed from 2.10.0 to 2.9.0 and now it is running.
                sdetweil @evroom
                @evroom no… just issue the command on the commandline
                Is this a pi 0?
                  ChrizZz @sdetweil
                  do
                  git stash
                  git merge
                  npm install
                  took the manual way too because of the same probs. Now my Pi is downloading the electron v3.1.13 version with 3.01 kB/s. can I stop the installation process to update electron manually?
                  S evroomE 2 Replies Last reply Reply Quote 0
                    sdetweil @ChrizZz
                    @ChrizZz I do not know
                      surger13 Project Sponsor @sdetweil
                      do
                      git stash
                      git merge
                      npm install
                      the fight was an easy one. everything worked. just had to restore the custom.css from a backup.
                      thanks again Sam
                      • evroomE
                        evroom @ChrizZz
                        @ChrizZz said in new update/upgrade script, ready for testing:
                        It looks like github has problems. I also cannot download other stuff from it with proper speed or without running into a timeout. Perhaps local or depends on your ISP region.
                          ChrizZz @evroom
                          @evroom said in new update/upgrade script, ready for testing:
                          I started installing electron in a new terminal session and it is downloading now with 16 kB/s. Maybe a stupid decission, maybe not.
                          Current status: 45% downloaded in the new terminal session, 18.5% downloaded as part of the MM update.
                          //edit: I stopped the inital installation, downloaded the right electron file from a mirror and placed the zip file in the /home/pi/.cache/electron folder. After that I updated electron manually. It worked well and after that I started npm install of the new MM version again. Now everything is updated without waiting years to download the zip from Github.
                            bdream
                            @sdetweil Hi Sam, after weeks being off I saw availability of v2.10.0 :slightly_smiling_face:
                            I run your script ```
                            bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                            Do I need to stop MM first or 'only' run the script in MagicMirror folder?
                            cheers, bdream
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @bdream
                              @bdream
                              Just open a new terminal and run the script. MM should not be running, I believe.
                                panos
                                Guys, I’m little confused.
                                I currently running at v2.9 and I wish to upgrade to v2.10
                                If I run the command:
                                bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
                                MM won’t update to v2.10
                                If I try the ‘traditional’ way 'git pull && npm install’ and ignore any changes that I make I receive the error:
                                The following untracked working tree files would be overwritten by merge: installers/dumpactivemodules.js
                                see here:
                                https://forum.magicmirror.builders/topic/11912/problem-with-updating-to-2-10-0-from-2-9-0-using-update-script/2
                                Any suggestion on how to update to 2.10?
                                  sdetweil @panos
                                  @panos the official script has a bug. Erase that file and use the updated version.
                                  See
                                  https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
                                    bdream
                                    See
                                    Sam, your link is looping or I’m wrong.
                                    Can you please provide the link to the right script again? Sorry I’m confused and not able to update the MM.
                                    cheers, bdream
                                      sdetweil @bdream
                                      @bdream the 1st post of this topic has the commands
                                        bdream
                                        it works :thumbs_up:
                                        Many thanks AGAIN Sam!
                                        cheers, bdream
                                        • spitzlbergerjS
                                          spitzlbergerj Project Sponsor Module Developer
                                          @sdetweil thanks for your great work. Unfortunately it does not work for me with the script.
                                          When I execute the script I get the following messages:
                                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                          the log will be /home/pi/MagicMirror/installers/upgrade.log
                                          No LSB modules are available.
                                          doing test run = true
                                          saving custom.css
                                          upgrading from version 2.9.0 to 2.10.0
                                          fetching latest revisions
                                          fatal: Couldn't find remote ref origin
                                          MagicMirror git fetch failed
                                          restoring custom.css
                                          The log file also contains the following:
                                          not english or locale not set, set git alias
                                          alias git='LC_ALL=en_US.UTF-8 git'
                                          remote name = github-desktop-darkniki origin
                                          git fetch rc=128
                                          Should I update manually or is there another way with the script?
                                          Sepp
                                          Regards
                                          Josef
                                          http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                                            sdetweil @spitzlbergerj
                                            @spitzlbergerj well, thats a new one…
                                            i try to find the upstream git repo this installation came from, and then get the changes from there,
                                            cause I want to be able to test the application of the changes without breaking the local system.
                                            can u do
                                            git remote
                                            and
                                            git remote -v
                                            thanks… it should be one word, but it looks like two on your system
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
