    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 49.6k Views 17 Watching
      Mykle1 Project Sponsor Module Developer @dasbooter
      @dasbooter said in MMM-Snow - Yet another Snow Module:
      Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it!
      Please consider posting your findings and the procedure you took to rectify your issue in this topic.
      https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/210
      It will certainly help someone at some time, as did the other findings in that topic.
      Many thanks, mate. :-)
      • Andrius okA Offline
        Andrius ok @strawberry 3.141
        Hello @strawberry-3.141 first Happy Holidays! and thank you for your answer. Yes I see now that only working with the Chromium browser on RPi3
        After spending a day to find the solution on how to make work MM on Raspberry Pi Zero W with Chromium I found the solution and it works like a charm! :)
        I tried many browsers (Midori, Kweb, Epiphany) no one is working correctly with es6 and css3 only Chromium.
        There is link on how to make work Chromium on RPi W Zero:
        https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=157049
        Also on how to start Chromium with root (if someone is needed):
        https://www.linkedin.com/pulse/20141028025215-79939846-google-chrome-and-chromium-as-root-on-kali-linux/
        There is my start.sh script:
        #! /bin/bash
        cd ~/MagicMirror
        node serveronly &
        sleep 45
        sudo xbacklight -set 100
        sudo xinit /home/pi/startMirror.sh
        and startMirror.sh script:
        #!/bin/sh
        xset -dpms # disable DPMS (Energy Star) features.
        xset s off # disable screen saver
        xset s noblank # don’t blank the video device
        xbacklight -set 100
        #Chromium Browser
        matchbox-window-manager &
        unclutter &
        sed -i ‘s/“exited_cleanly”: false/“exited_cleanly”: true/’ ~/.config/chromium/Default/Preference
        chromium-browser --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
        Everything the same config like there (only Chromium browser needed instead Midori):
        https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
        Maybe for someone it will be usefull on how to start MM on Raspberry Pi Zero W with all features working.
        Happy Holidays!
          Mykle1 Project Sponsor Module Developer @Andrius ok
          @Andrius-ok said in MMM-Snow - Yet another Snow Module:
          Nice work! :-)
          • lavolp3L Offline
            lavolp3 Module Developer
            Happy New Year everyone!
            I need to bring one neverending topic back again here:
            I tried to use MMM-Snow recently with a Pi 3B+ and stretch installed.
            Currently I have today’s MM 2.6.0 with electron 2.0.x installed, but I have tried electron v1.4.15 as well.
            The snowflakes are lagging on my mirror, not falling fluently. If I use the web version from a laptop it’s fluent, so it should be a browser issue.
            Config:
                    module: 'MMM-Snow',
                    position: 'fullscreen_above',
                    config: { // See 'Configuration options' for more information.
                        flakeCount: 40,
                        theme: "winter"
            I have tried the kms driver, the fake kms driver (which gives me a flickering screen after some time for some odd reasons), and no kms driver at all. No recognizable change with regards to the snowflake performance.
            Is there any chance for fluent animations using electron at the moment that I have overseen?
            As far as I understand none of the electron versions work properly with hardware support. Is that true?
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              bhepler Module Developer @lavolp3
              @lavolp3 - Electron has always been a bit flakey with animations. Pardon the pun.
              I have 50 flakes running on the office mirror right now and it’s acceptable. But I haven’t upgraded the office mirror to the latest versions yet. If you need, I’ll swing by and check out what version it’s running.
              • rudibaraniR Offline
                rudibarani Project Sponsor
                Dear all,
                would it be possible to have this module hidden until a weather module (e.g. MMM-DarkSkyForecast broadcasts a DARK_SKY_FORECAST_WEATHER_UPDATE) broadcasts a weather update that contains a snow forecast for today? That would be really useful :)
                • lavolp3L Offline
                  lavolp3 Module Developer @bhepler
                  @bhepler That would be great thanks. Also, if you have one of the drivers enabled and what relosution you’re running.
                    @lavolp3 - Will do. I should be at the office tomorrow. I’ll check it then.
                      Sorry for the delay. I’m running v2.5.0 of the Magic Mirror at work. Electron is (I think) v2.0, using the fake OpenGL drivers.
                      Resolution is 1920x1080.
                      ETA - Confirmed. Electron is v2.0.0
                      • lavolp3L Offline
                        @bhepler Is it fluent or would you say it is lagging a bit?
                        That’s a bit non-scientific now so a video would help most but I 'd undterstand if you don’t want to go through the trouble of uploading a video.
                        I have a Pi 3b+ with MM v2.6.0 and all else like above, but it is lagging too much for me to enjoy it.
                        I’ll try running it on Chrome locally as described above. But I don’t like this workaround.
                          Ask and ye shall receive. https://youtu.be/2WksYxILZa0
                          • lavolp3L Offline
                            @bhepler Thanks! Looks good, especially the beard :-D
                            Don’t understand why it wont work as fluent on my device.
                              @lavolp3 - Perhaps switch between the fake and the real OpenGL driver.
                              PS - the word you’re looking for is “fluid”, not “fluent”.
                              • N Offline
                                nobita @jasondreher
                                to @jasondreher or anyone
                                If i would like to change Theme (winter,love,water) ,I have to edit in config
                                but If i can change Theme in MMM-RemoteControl (replace to edit in config)
                                How can to do that
                                Thanks for your help
                                • T Offline
                                  tintkovich
                                  Hi guys!
                                  Did somebody integrat mmm-snow with currentweather module, and can tell me how may I do it? ;)
                                  • StoffbeuteluweS Offline
                                    Stoffbeuteluwe Project Sponsor @tintkovich
                                    @tintkovich
                                    that would be cool …
                                      jasondreher
                                      @tintkovich
                                      see
                                      https://forum.magicmirror.builders/post/37353
                                      • T Offline
                                        tintkovich @jasondreher
                                        @jasondreher I saw it, but I need Home Assistant, right?
                                        I prefere to integrate currentweather with mmm-snow just like compliments module:
                                        	compliments: {
                                        		day_sunny: [
                                        			"Today is a sunny day",
                                        			"It's a beautiful day"
                                        		snow: [
                                        			"Snowball battle!"
                                        		rain: [
                                        			"Don't forget your umbrella"
                                        Is it possible?
                                        sifuhallS 1 Reply Last reply Reply Quote 1
                                        • sifuhallS Offline
                                          sifuhall @tintkovich
                                          For those interested in a dynamic weather module check here:
                                          https://github.com/scottcl88/MMM-DynamicWeather
