    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 49.6k Views 17 Watching
      broberg Project Sponsor
      Sweet!
      There should be a seasonal module like this, or maybe an extension for the weather apps (snow when the weather says snow and rain, hail, sunny, cloudy etc etc).
      M 1 Reply Last reply Reply Quote 6
        McSorley @broberg
        @broberg said in Yet another Snow Module:
        Sweet!
        Would this be possible? Think it would be pretty sweet to have the screen snowing when its snowing outside.
        B J 2 Replies Last reply Reply Quote 0
          broberg Project Sponsor @McSorley
          @McSorley should be a matter of having the weather module sending a notifaction to the snow module
          • Andrius okA Offline
            Andrius ok
            Hello, does it work with Raspberry Pi Zero W and Midori browser? I cannot get working.
            Everythin what’s in config file is working but not MMM-Snow
            Here is my config.js
                                    module: "MMM-Snow",
                                    position: 'fullscreen',
            • Y Offline
              yawns Moderator @Andrius ok
              @Andrius-ok
              position should be fullscreen_above or fullscreen_below
              Andrius okA 1 Reply Last reply Reply Quote 1
                jasondreher @McSorley
                @McSorley
                I have done this, worked quite well this weekend. Used HomeAssistant to know when it was snowing and if the description changes to “Snow” then have MM unhide the MMM-Snow module. I used RemoteControl to unhide and hide…
                  bhepler Module Developer
                  Heh. Love the recent update, @michmich. Thanks for the entertainment.
                    Andrius ok @yawns
                    @yawns I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                    maybe there is any restriction that on Raspberry Pi Zero W is not working? Or there is an issue with Midori browser? Is it needed any plugins to show this snow?
                    Thank You
                      Andrius ok @jasondreher
                      Hello @jasondreher, could you share yours config.js configuration? It would be a very kind. Thanks You
                        jasondreher @Andrius ok
                        @Andrius-ok
                        You need both MMM-Snow and MMM-Remote-Control, and its not just my config you need. here are the basic steps I took…
                        1. Using home assistant (for me on another pi) https://home-assistant.io/
                        2. Set up a Sensor in configuration.yaml for HomeAssistant for weather underground
                        - platform: wunderground
                          api_key: xxxxxxxxxxxxx
                          monitored_conditions:
                            - alerts
                            - dewpoint_f
                            - temp_f
                            - weather
                        1. Automation in Home Assistant will use sell commands in configuration.yaml to run
                        switch
                            mmsnow:
                              command_on: 'curl "http://192.XXX.X.XXX:8090/remote?action=SHOW&module=module_0_MMM-Snow"'
                              command_off: 'curl "http://192.XXX.X.XXX:8090/remote?action=HIDE&module=module_0_MMM-Snow"'
                        4. Automation in HA calls these when the state changes to "Snow"
                        • alias: “ShowSnow”
                          initial_state: True
                          trigger:
                          platform: state
                          entity_id: sensor.pws_weather
                          to: ‘Snow’
                          action:
                          • service: shell_command.show_snow
                        • alias: “HideSnow”
                          initial_state: True
                          trigger:
                          platform: state
                          action:
                          • service: shell_command.hide_snow
                        I use home assistant along with smartthings to automate my lights...
                        I plan to share my entire project soon.
                        Andrius okA N 2 Replies Last reply Reply Quote 2
                          @jasondreher said in MMM-Snow - Yet another Snow Module:
                          MMM-Snow
                          cannot make MMM-Snow module to work on Midori :(
                            Andrius ok
                            Maybe someone can share MMM-Snow config.js configuration? cannot make module to work on Midori. Thanks!
                              Andrius ok @MichMich
                              Hello @MichMich I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                              Cannot make module to work on Midori
                              Thank You
                              • Sandy2503S Offline
                                Sandy2503
                                @Andrius ok
                                here is the Snow Module in my config.js
                                                        module: "clock",
                                                        header: "",
        displaySeconds: false
                                                        module: "MMM-Snow",
                                                        position: "fullscreen_above",
                                                        header: "",
        flakeCount: 25
                                                        module: "calendar_monthly",
                                I hope this can help you
                                Greetz
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                  @Andrius-ok midori doesnt support es6 thats why a lot of modules dont work on midori, but from a quick scan i couldnt spot a es6 feature. But I could imagine that midori also doesnt support css3 and this module is making havy use of css3
                                  Andrius okA 1 Reply Last reply Reply Quote 0
                                  • dasbooterD Offline
                                    dasbooter
                                    Thanks a bunch for this. Its quite jerky for me. I have limited the flake count to 25 in the config. Whats my expectation here on a rasberry pi 3 with default modules plus globe, remote module , and traffic . Wondering if i didnt maybe nerf something in the initial first time install of the magic mirror following a tutorial?
                                    Edit: Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it! Thanks a bunch for this module and the MM
                                    Mykle1M 1 Reply Last reply Reply Quote 3
                                      Mykle1 Project Sponsor Module Developer @dasbooter
                                      @dasbooter said in MMM-Snow - Yet another Snow Module:
                                      Please consider posting your findings and the procedure you took to rectify your issue in this topic.
                                      https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/210
                                      It will certainly help someone at some time, as did the other findings in that topic.
                                      Many thanks, mate. :-)
                                        Andrius ok @strawberry 3.141
                                        Hello @strawberry-3.141 first Happy Holidays! and thank you for your answer. Yes I see now that only working with the Chromium browser on RPi3
                                        After spending a day to find the solution on how to make work MM on Raspberry Pi Zero W with Chromium I found the solution and it works like a charm! :)
                                        I tried many browsers (Midori, Kweb, Epiphany) no one is working correctly with es6 and css3 only Chromium.
                                        There is link on how to make work Chromium on RPi W Zero:
                                        https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=157049
                                        Also on how to start Chromium with root (if someone is needed):
                                        https://www.linkedin.com/pulse/20141028025215-79939846-google-chrome-and-chromium-as-root-on-kali-linux/
                                        There is my start.sh script:
                                        #! /bin/bash
                                        node serveronly &
                                        sleep 45
                                        sudo xbacklight -set 100
                                        sudo xinit /home/pi/startMirror.sh
                                        and startMirror.sh script:
                                        #!/bin/sh
                                        xset -dpms # disable DPMS (Energy Star) features.
                                        xset s off # disable screen saver
                                        xset s noblank # don’t blank the video device
                                        xbacklight -set 100
                                        #Chromium Browser
                                        matchbox-window-manager &
                                        unclutter &
                                        sed -i ‘s/“exited_cleanly”: false/“exited_cleanly”: true/’ ~/.config/chromium/Default/Preference
                                        chromium-browser --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                                        Everything the same config like there (only Chromium browser needed instead Midori):
                                        https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                                        Maybe for someone it will be usefull on how to start MM on Raspberry Pi Zero W with all features working.
                                        Happy Holidays!
                                          Mykle1 Project Sponsor Module Developer @Andrius ok
                                          @Andrius-ok said in MMM-Snow - Yet another Snow Module:
                                          Nice work! :-)
                                          • lavolp3L Offline
                                            lavolp3 Module Developer
                                            Happy New Year everyone!
                                            I need to bring one neverending topic back again here:
                                            I tried to use MMM-Snow recently with a Pi 3B+ and stretch installed.
                                            Currently I have today’s MM 2.6.0 with electron 2.0.x installed, but I have tried electron v1.4.15 as well.
                                            The snowflakes are lagging on my mirror, not falling fluently. If I use the web version from a laptop it’s fluent, so it should be a browser issue.
                                            Config:
                                                    module: 'MMM-Snow',
                                                    position: 'fullscreen_above',
                                                    config: { // See 'Configuration options' for more information.
                                                        flakeCount: 40,
                                                        theme: "winter"
                                            I have tried the kms driver, the fake kms driver (which gives me a flickering screen after some time for some odd reasons), and no kms driver at all. No recognizable change with regards to the snowflake performance.
                                            Is there any chance for fluent animations using electron at the moment that I have overseen?
                                            As far as I understand none of the electron versions work properly with hardware support. Is that true?
                                            How to troubleshoot modules
                                            MMM-soccer v2, MMM-AVStock
