    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 50.0k Views 17 Watching
    • MichMichM
      MichMich
      Description:
      Inspired by NHubbard’s Snow Plugin I created a little more realistic snow plugin to improve your winter experience!
      Screenshot:
      alt text
      Download:
      [card:MichMich/MMM-Snow]
      Initial Version
      A 1 Reply Last reply Reply Quote 3
      • A
        aluini @MichMich
        @MichMich sadly, the page is blank
        but the idea is cool !
        MichMichM 1 Reply Last reply Reply Quote 0
        • MichMichM
          MichMich @aluini
          @aluini Try this link: https://github.com/MichMich/MMM-Snow
          A Andrius okA 2 Replies Last reply Reply Quote 0
          • A
            aluini @MichMich
            @MichMich better ! 😎
              broberg Project Sponsor
              Sweet!
              There should be a seasonal module like this, or maybe an extension for the weather apps (snow when the weather says snow and rain, hail, sunny, cloudy etc etc).
              M 1 Reply Last reply Reply Quote 6
                McSorley @broberg
                @broberg said in Yet another Snow Module:
                Sweet!
                Would this be possible? Think it would be pretty sweet to have the screen snowing when its snowing outside.
                B J 2 Replies Last reply Reply Quote 0
                  broberg Project Sponsor @McSorley
                  @McSorley should be a matter of having the weather module sending a notifaction to the snow module
                  • Andrius okA
                    Andrius ok
                    Hello, does it work with Raspberry Pi Zero W and Midori browser? I cannot get working.
                    Everythin what’s in config file is working but not MMM-Snow
                    Here is my config.js
                                            module: "MMM-Snow",
                                            position: 'fullscreen',
                    • Y
                      yawns Moderator @Andrius ok
                      @Andrius-ok
                      position should be fullscreen_above or fullscreen_below
                      Andrius okA 1 Reply Last reply Reply Quote 1
                        jasondreher @McSorley
                        @McSorley
                        I have done this, worked quite well this weekend. Used HomeAssistant to know when it was snowing and if the description changes to “Snow” then have MM unhide the MMM-Snow module. I used RemoteControl to unhide and hide…
                          bhepler Module Developer
                          Heh. Love the recent update, @michmich. Thanks for the entertainment.
                          • Andrius okA
                            Andrius ok @yawns
                            @yawns I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                            maybe there is any restriction that on Raspberry Pi Zero W is not working? Or there is an issue with Midori browser? Is it needed any plugins to show this snow?
                            Thank You
                            • Andrius okA
                              Andrius ok @jasondreher
                              Hello @jasondreher, could you share yours config.js configuration? It would be a very kind. Thanks You
                                jasondreher @Andrius ok
                                @Andrius-ok
                                You need both MMM-Snow and MMM-Remote-Control, and its not just my config you need. here are the basic steps I took…
                                1. Using home assistant (for me on another pi) https://home-assistant.io/
                                2. Set up a Sensor in configuration.yaml for HomeAssistant for weather underground
                                - platform: wunderground
                                  api_key: xxxxxxxxxxxxx
                                  monitored_conditions:
                                    - alerts
                                    - dewpoint_f
                                    - temp_f
                                    - weather
                                1. Automation in Home Assistant will use sell commands in configuration.yaml to run
                                switch
                                    mmsnow:
                                      command_on: 'curl "http://192.XXX.X.XXX:8090/remote?action=SHOW&module=module_0_MMM-Snow"'
                                      command_off: 'curl "http://192.XXX.X.XXX:8090/remote?action=HIDE&module=module_0_MMM-Snow"'
                                4. Automation in HA calls these when the state changes to "Snow"
                                • alias: “ShowSnow”
                                  initial_state: True
                                  trigger:
                                  platform: state
                                  entity_id: sensor.pws_weather
                                  to: ‘Snow’
                                  action:
                                  • service: shell_command.show_snow
                                • alias: “HideSnow”
                                  initial_state: True
                                  trigger:
                                  platform: state
                                  action:
                                  • service: shell_command.hide_snow
                                I use home assistant along with smartthings to automate my lights...
                                I plan to share my entire project soon.
                                Andrius okA N 2 Replies Last reply Reply Quote 2
                                • Andrius okA
                                  @jasondreher said in MMM-Snow - Yet another Snow Module:
                                  MMM-Snow
                                  cannot make MMM-Snow module to work on Midori :(
                                  • Andrius okA
                                    Andrius ok
                                    Maybe someone can share MMM-Snow config.js configuration? cannot make module to work on Midori. Thanks!
                                    • Andrius okA
                                      Andrius ok @MichMich
                                      Hello @MichMich I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                                      Cannot make module to work on Midori
                                      Thank You
                                      • Sandy2503S
                                        Sandy2503
                                        @Andrius ok
                                        here is the Snow Module in my config.js
        module: "clock",
        header: "",
        displaySeconds: false
        module: "MMM-Snow",
        position: "fullscreen_above",
        header: "",
        flakeCount: 25
        module: "calendar_monthly",
                                        I hope this can help you
                                        Greetz
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                          @Andrius-ok midori doesnt support es6 thats why a lot of modules dont work on midori, but from a quick scan i couldnt spot a es6 feature. But I could imagine that midori also doesnt support css3 and this module is making havy use of css3
                                          Andrius okA 1 Reply Last reply Reply Quote 0
                                          • dasbooterD
                                            dasbooter
                                            Thanks a bunch for this. Its quite jerky for me. I have limited the flake count to 25 in the config. Whats my expectation here on a rasberry pi 3 with default modules plus globe, remote module , and traffic . Wondering if i didnt maybe nerf something in the initial first time install of the magic mirror following a tutorial?
                                            Edit: Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it! Thanks a bunch for this module and the MM
                                            Mykle1M 1 Reply Last reply Reply Quote 3
