    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 50.6k Views 17 Watching
    • aluiniA
      aluini @MichMich
      @MichMich better ! 😎
      • brobergB
        broberg Project Sponsor
        Sweet!
        There should be a seasonal module like this, or maybe an extension for the weather apps (snow when the weather says snow and rain, hail, sunny, cloudy etc etc).
        M 1 Reply Last reply
        Reply Quote 6
          McSorley @broberg
          @broberg said in Yet another Snow Module:
          Sweet!
          Would this be possible? Think it would be pretty sweet to have the screen snowing when its snowing outside.
          brobergB J 2 Replies Last reply
          • brobergB
            broberg Project Sponsor @McSorley
            @McSorley should be a matter of having the weather module sending a notifaction to the snow module
            • Andrius okA
              Andrius ok
              Hello, does it work with Raspberry Pi Zero W and Midori browser? I cannot get working.
              Everythin what’s in config file is working but not MMM-Snow
              Here is my config.js
                                      module: "MMM-Snow",
                                      position: 'fullscreen',
              yawnsY 1 Reply Last reply
              • yawnsY
                yawns Moderator @Andrius ok
                @Andrius-ok
                position should be fullscreen_above or fullscreen_below
                Andrius okA 1 Reply Last reply
                  jasondreher @McSorley
                  @McSorley
                  I have done this, worked quite well this weekend. Used HomeAssistant to know when it was snowing and if the description changes to “Snow” then have MM unhide the MMM-Snow module. I used RemoteControl to unhide and hide…
                  • bheplerB
                    bhepler Module Developer
                    Heh. Love the recent update, @michmich. Thanks for the entertainment.
                    • Andrius okA
                      Andrius ok @yawns
                      @yawns I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                      maybe there is any restriction that on Raspberry Pi Zero W is not working? Or there is an issue with Midori browser? Is it needed any plugins to show this snow?
                      Thank You
                      • Andrius okA
                        Andrius ok @jasondreher
                        Hello @jasondreher, could you share yours config.js configuration? It would be a very kind. Thanks You
                        J 1 Reply Last reply
                          jasondreher @Andrius ok
                          @Andrius-ok
                          You need both MMM-Snow and MMM-Remote-Control, and its not just my config you need. here are the basic steps I took…
                          1. Using home assistant (for me on another pi) https://home-assistant.io/
                          2. Set up a Sensor in configuration.yaml for HomeAssistant for weather underground
                          - platform: wunderground
                            api_key: xxxxxxxxxxxxx
                            monitored_conditions:
                              - alerts
                              - dewpoint_f
                              - temp_f
                              - weather
                          1. Automation in Home Assistant will use sell commands in configuration.yaml to run
                          switch
                              mmsnow:
                                command_on: 'curl "http://192.XXX.X.XXX:8090/remote?action=SHOW&module=module_0_MMM-Snow"'
                                command_off: 'curl "http://192.XXX.X.XXX:8090/remote?action=HIDE&module=module_0_MMM-Snow"'
                          4. Automation in HA calls these when the state changes to "Snow"
                          • alias: “ShowSnow”
                            initial_state: True
                            trigger:
                            platform: state
                            entity_id: sensor.pws_weather
                            to: ‘Snow’
                            action:
                            • service: shell_command.show_snow
                          • alias: “HideSnow”
                            initial_state: True
                            trigger:
                            platform: state
                            action:
                            • service: shell_command.hide_snow
                          I use home assistant along with smartthings to automate my lights...
                          I plan to share my entire project soon.
                          Andrius okA N 2 Replies Last reply
                          Reply Quote 2
                          • Andrius okA
                            @jasondreher said in MMM-Snow - Yet another Snow Module:
                            MMM-Snow
                            cannot make MMM-Snow module to work on Midori :(
                            • Andrius okA
                              Andrius ok
                              Maybe someone can share MMM-Snow config.js configuration? cannot make module to work on Midori. Thanks!
                              • Andrius okA
                                Andrius ok @MichMich
                                Hello @MichMich I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                                Cannot make module to work on Midori
                                Thank You
                                • Sandy2503S
                                  Sandy2503
                                  @Andrius ok
                                  here is the Snow Module in my config.js
                                                          module: "clock",
                                                          header: "",
        displaySeconds: false
                                                          module: "MMM-Snow",
                                                          position: "fullscreen_above",
                                                          header: "",
        flakeCount: 25
                                                          module: "calendar_monthly",
                                  I hope this can help you
                                  Greetz
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                                    @Andrius-ok midori doesnt support es6 thats why a lot of modules dont work on midori, but from a quick scan i couldnt spot a es6 feature. But I could imagine that midori also doesnt support css3 and this module is making havy use of css3
                                    • dasbooterD
                                      dasbooter
                                      Thanks a bunch for this. Its quite jerky for me. I have limited the flake count to 25 in the config. Whats my expectation here on a rasberry pi 3 with default modules plus globe, remote module , and traffic . Wondering if i didnt maybe nerf something in the initial first time install of the magic mirror following a tutorial?
                                      Edit: Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it! Thanks a bunch for this module and the MM
                                      Mykle1M 1 Reply Last reply
                                      Reply Quote 3
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @dasbooter
                                        @dasbooter said in MMM-Snow - Yet another Snow Module:
                                        Please consider posting your findings and the procedure you took to rectify your issue in this topic.
                                        https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/210
                                        It will certainly help someone at some time, as did the other findings in that topic.
                                        Many thanks, mate. :-)
                                        • Andrius okA
                                          Andrius ok @strawberry 3.141
                                          Hello @strawberry-3.141 first Happy Holidays! and thank you for your answer. Yes I see now that only working with the Chromium browser on RPi3
                                          After spending a day to find the solution on how to make work MM on Raspberry Pi Zero W with Chromium I found the solution and it works like a charm! :)
                                          I tried many browsers (Midori, Kweb, Epiphany) no one is working correctly with es6 and css3 only Chromium.
                                          There is link on how to make work Chromium on RPi W Zero:
                                          https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=157049
                                          Also on how to start Chromium with root (if someone is needed):
                                          https://www.linkedin.com/pulse/20141028025215-79939846-google-chrome-and-chromium-as-root-on-kali-linux/
                                          There is my start.sh script:
                                          #! /bin/bash
                                          node serveronly &
                                          sleep 45
                                          sudo xbacklight -set 100
                                          sudo xinit /home/pi/startMirror.sh
                                          and startMirror.sh script:
                                          #!/bin/sh
                                          xset -dpms # disable DPMS (Energy Star) features.
                                          xset s off # disable screen saver
                                          xset s noblank # don’t blank the video device
                                          xbacklight -set 100
                                          #Chromium Browser
                                          matchbox-window-manager &
                                          unclutter &
                                          sed -i ‘s/“exited_cleanly”: false/“exited_cleanly”: true/’ ~/.config/chromium/Default/Preference
                                          chromium-browser --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                                          Everything the same config like there (only Chromium browser needed instead Midori):
                                          https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                                          Maybe for someone it will be usefull on how to start MM on Raspberry Pi Zero W with all features working.
                                          Happy Holidays!
                                          Reply Quote 2
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Andrius ok
                                            @Andrius-ok said in MMM-Snow - Yet another Snow Module:
                                            Nice work! :-)
