    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 50.6k Views 17 Watching
      jasondreher @Andrius ok
      @Andrius-ok
      You need both MMM-Snow and MMM-Remote-Control, and its not just my config you need. here are the basic steps I took…
      1. Using home assistant (for me on another pi) https://home-assistant.io/
      2. Set up a Sensor in configuration.yaml for HomeAssistant for weather underground
      - platform: wunderground
        api_key: xxxxxxxxxxxxx
        monitored_conditions:
          - alerts
          - dewpoint_f
          - temp_f
          - weather
      1. Automation in Home Assistant will use sell commands in configuration.yaml to run
      switch
          mmsnow:
            command_on: 'curl "http://192.XXX.X.XXX:8090/remote?action=SHOW&module=module_0_MMM-Snow"'
            command_off: 'curl "http://192.XXX.X.XXX:8090/remote?action=HIDE&module=module_0_MMM-Snow"'
      4. Automation in HA calls these when the state changes to "Snow"
      • alias: “ShowSnow”
        initial_state: True
        trigger:
        platform: state
        entity_id: sensor.pws_weather
        to: ‘Snow’
        action:
        • service: shell_command.show_snow
      • alias: “HideSnow”
        initial_state: True
        trigger:
        platform: state
        action:
        • service: shell_command.hide_snow
      I use home assistant along with smartthings to automate my lights...
      I plan to share my entire project soon.
      Andrius okA N 2 Replies Last reply
      Reply Quote 2
      • Andrius okA
        Andrius ok @jasondreher
        @jasondreher said in MMM-Snow - Yet another Snow Module:
        MMM-Snow
        cannot make MMM-Snow module to work on Midori :(
        • Andrius okA
          Andrius ok
          Maybe someone can share MMM-Snow config.js configuration? cannot make module to work on Midori. Thanks!
          • Andrius okA
            Andrius ok @MichMich
            Hello @MichMich I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
            maybe there is any restriction that on Raspberry Pi Zero W is not working? Or there is an issue with Midori browser? Is it needed any plugins to show this snow?
            Cannot make module to work on Midori
            Thank You
            • Sandy2503S
              Sandy2503
              @Andrius ok
              here is the Snow Module in my config.js
                                      module: "clock",
                                      header: "",
                                              displaySeconds: false
                                      module: "MMM-Snow",
                                      position: "fullscreen_above",
                                      header: "",
                                              flakeCount: 25
                                      module: "calendar_monthly",
              I hope this can help you
              Greetz
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                @Andrius-ok midori doesnt support es6 thats why a lot of modules dont work on midori, but from a quick scan i couldnt spot a es6 feature. But I could imagine that midori also doesnt support css3 and this module is making havy use of css3
                Andrius okA 1 Reply Last reply
                • dasbooterD
                  dasbooter
                  Thanks a bunch for this. Its quite jerky for me. I have limited the flake count to 25 in the config. Whats my expectation here on a rasberry pi 3 with default modules plus globe, remote module , and traffic . Wondering if i didnt maybe nerf something in the initial first time install of the magic mirror following a tutorial?
                  Edit: Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it! Thanks a bunch for this module and the MM
                  Mykle1M 1 Reply Last reply
                  Reply Quote 3
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @dasbooter
                    @dasbooter said in MMM-Snow - Yet another Snow Module:
                    Please consider posting your findings and the procedure you took to rectify your issue in this topic.
                    https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/210
                    It will certainly help someone at some time, as did the other findings in that topic.
                    Many thanks, mate. :-)
                    • Andrius okA
                      Andrius ok @strawberry 3.141
                      Hello @strawberry-3.141 first Happy Holidays! and thank you for your answer. Yes I see now that only working with the Chromium browser on RPi3
                      After spending a day to find the solution on how to make work MM on Raspberry Pi Zero W with Chromium I found the solution and it works like a charm! :)
                      I tried many browsers (Midori, Kweb, Epiphany) no one is working correctly with es6 and css3 only Chromium.
                      There is link on how to make work Chromium on RPi W Zero:
                      https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=157049
                      Also on how to start Chromium with root (if someone is needed):
                      https://www.linkedin.com/pulse/20141028025215-79939846-google-chrome-and-chromium-as-root-on-kali-linux/
                      There is my start.sh script:
                      #! /bin/bash
                      node serveronly &
                      sleep 45
                      sudo xbacklight -set 100
                      sudo xinit /home/pi/startMirror.sh
                      and startMirror.sh script:
                      #!/bin/sh
                      xset -dpms # disable DPMS (Energy Star) features.
                      xset s off # disable screen saver
                      xset s noblank # don’t blank the video device
                      xbacklight -set 100
                      #Chromium Browser
                      matchbox-window-manager &
                      unclutter &
                      sed -i ‘s/“exited_cleanly”: false/“exited_cleanly”: true/’ ~/.config/chromium/Default/Preference
                      chromium-browser --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                      Everything the same config like there (only Chromium browser needed instead Midori):
                      https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                      Maybe for someone it will be usefull on how to start MM on Raspberry Pi Zero W with all features working.
                      Happy Holidays!
                      Reply Quote 2
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Andrius ok
                        @Andrius-ok said in MMM-Snow - Yet another Snow Module:
                        Nice work! :-)
                        • lavolp3L
                          lavolp3 Module Developer
                          Happy New Year everyone!
                          I need to bring one neverending topic back again here:
                          I tried to use MMM-Snow recently with a Pi 3B+ and stretch installed.
                          Currently I have today’s MM 2.6.0 with electron 2.0.x installed, but I have tried electron v1.4.15 as well.
                          The snowflakes are lagging on my mirror, not falling fluently. If I use the web version from a laptop it’s fluent, so it should be a browser issue.
                          Config:
                                  module: 'MMM-Snow',
                                  position: 'fullscreen_above',
                                  config: { // See 'Configuration options' for more information.
                                      flakeCount: 40,
                                      theme: "winter"
                          I have tried the kms driver, the fake kms driver (which gives me a flickering screen after some time for some odd reasons), and no kms driver at all. No recognizable change with regards to the snowflake performance.
                          Is there any chance for fluent animations using electron at the moment that I have overseen?
                          As far as I understand none of the electron versions work properly with hardware support. Is that true?
                          How to troubleshoot modules
                          MMM-soccer v2, MMM-AVStock
                          bheplerB 1 Reply Last reply
                          • bheplerB
                            bhepler Module Developer @lavolp3
                            @lavolp3 - Electron has always been a bit flakey with animations. Pardon the pun.
                            I have 50 flakes running on the office mirror right now and it’s acceptable. But I haven’t upgraded the office mirror to the latest versions yet. If you need, I’ll swing by and check out what version it’s running.
                            lavolp3L 1 Reply Last reply
                            • rudibaraniR
                              rudibarani Project Sponsor
                              Dear all,
                              would it be possible to have this module hidden until a weather module (e.g. MMM-DarkSkyForecast broadcasts a DARK_SKY_FORECAST_WEATHER_UPDATE) broadcasts a weather update that contains a snow forecast for today? That would be really useful :)
                              • lavolp3L
                                lavolp3 Module Developer @bhepler
                                @bhepler That would be great thanks. Also, if you have one of the drivers enabled and what relosution you’re running.
                                • bheplerB
                                  @lavolp3 - Will do. I should be at the office tomorrow. I’ll check it then.
                                  • bheplerB
                                    Sorry for the delay. I’m running v2.5.0 of the Magic Mirror at work. Electron is (I think) v2.0, using the fake OpenGL drivers.
                                    Resolution is 1920x1080.
                                    ETA - Confirmed. Electron is v2.0.0
                                    • lavolp3L
                                      @bhepler Is it fluent or would you say it is lagging a bit?
                                      That’s a bit non-scientific now so a video would help most but I 'd undterstand if you don’t want to go through the trouble of uploading a video.
                                      I have a Pi 3b+ with MM v2.6.0 and all else like above, but it is lagging too much for me to enjoy it.
                                      I’ll try running it on Chrome locally as described above. But I don’t like this workaround.
                                      • bheplerB
                                        Ask and ye shall receive. https://youtu.be/2WksYxILZa0
                                        • lavolp3L
                                          @bhepler Thanks! Looks good, especially the beard :-D
                                          Don’t understand why it wont work as fluent on my device.
                                          • bheplerB
                                            @lavolp3 - Perhaps switch between the fake and the real OpenGL driver.
                                            PS - the word you’re looking for is “fluid”, not “fluent”.
