    MMM-Snow - Yet another Snow Module
    Scheduled Pinned Locked Moved Fun & Games
    39 Posts 18 Posters 50.6k Views 17 Watching
    • yawnsY
      yawns Moderator @Andrius ok
      @Andrius-ok
      position should be fullscreen_above or fullscreen_below
      Andrius okA 1 Reply Last reply
        jasondreher @McSorley
        @McSorley
        I have done this, worked quite well this weekend. Used HomeAssistant to know when it was snowing and if the description changes to “Snow” then have MM unhide the MMM-Snow module. I used RemoteControl to unhide and hide…
        • bheplerB
          bhepler Module Developer
          Heh. Love the recent update, @michmich. Thanks for the entertainment.
          • Andrius okA
            Andrius ok @yawns
            @yawns I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
            maybe there is any restriction that on Raspberry Pi Zero W is not working? Or there is an issue with Midori browser? Is it needed any plugins to show this snow?
            Thank You
            • Andrius okA
              Andrius ok @jasondreher
              Hello @jasondreher, could you share yours config.js configuration? It would be a very kind. Thanks You
              J 1 Reply Last reply
                jasondreher @Andrius ok
                @Andrius-ok
                You need both MMM-Snow and MMM-Remote-Control, and its not just my config you need. here are the basic steps I took…
                1. Using home assistant (for me on another pi) https://home-assistant.io/
                2. Set up a Sensor in configuration.yaml for HomeAssistant for weather underground
                - platform: wunderground
                  api_key: xxxxxxxxxxxxx
                  monitored_conditions:
                    - alerts
                    - dewpoint_f
                    - temp_f
                    - weather
                1. Automation in Home Assistant will use sell commands in configuration.yaml to run
                switch
                    mmsnow:
                      command_on: 'curl "http://192.XXX.X.XXX:8090/remote?action=SHOW&module=module_0_MMM-Snow"'
                      command_off: 'curl "http://192.XXX.X.XXX:8090/remote?action=HIDE&module=module_0_MMM-Snow"'
                4. Automation in HA calls these when the state changes to "Snow"
                • alias: “ShowSnow”
                  initial_state: True
                  trigger:
                  platform: state
                  entity_id: sensor.pws_weather
                  to: ‘Snow’
                  action:
                  • service: shell_command.show_snow
                • alias: “HideSnow”
                  initial_state: True
                  trigger:
                  platform: state
                  action:
                  • service: shell_command.hide_snow
                I use home assistant along with smartthings to automate my lights...
                I plan to share my entire project soon.
                Andrius okA N 2 Replies Last reply
                Reply Quote 2
                • Andrius okA
                  @jasondreher said in MMM-Snow - Yet another Snow Module:
                  MMM-Snow
                  cannot make MMM-Snow module to work on Midori :(
                  • Andrius okA
                    Andrius ok
                    Maybe someone can share MMM-Snow config.js configuration? cannot make module to work on Midori. Thanks!
                    • Andrius okA
                      Andrius ok @MichMich
                      Hello @MichMich I have tried position: ‘fullscreen_above’, and position: ‘fullscreen_below’, but no luck :(
                      Cannot make module to work on Midori
                      Thank You
                      • Sandy2503S
                        Sandy2503
                        @Andrius ok
                        here is the Snow Module in my config.js
                                                module: "clock",
                                                header: "",
                                                        displaySeconds: false
                                                module: "MMM-Snow",
                                                position: "fullscreen_above",
                                                header: "",
                                                        flakeCount: 25
                                                module: "calendar_monthly",
                        I hope this can help you
                        Greetz
                        • strawberry 3.141S
                          strawberry 3.141 Project Sponsor Module Developer @Andrius ok
                          @Andrius-ok midori doesnt support es6 thats why a lot of modules dont work on midori, but from a quick scan i couldnt spot a es6 feature. But I could imagine that midori also doesnt support css3 and this module is making havy use of css3
                          • dasbooterD
                            dasbooter
                            Thanks a bunch for this. Its quite jerky for me. I have limited the flake count to 25 in the config. Whats my expectation here on a rasberry pi 3 with default modules plus globe, remote module , and traffic . Wondering if i didnt maybe nerf something in the initial first time install of the magic mirror following a tutorial?
                            Edit: Found the Answer had to downgrade electron bc I’m using stretch. Took forty minutes to locate an answer on google but worth it! Thanks a bunch for this module and the MM
                            Mykle1M 1 Reply Last reply
                            Reply Quote 3
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @dasbooter
                              @dasbooter said in MMM-Snow - Yet another Snow Module:
                              Please consider posting your findings and the procedure you took to rectify your issue in this topic.
                              https://forum.magicmirror.builders/topic/4684/electron-cpu-usage/210
                              It will certainly help someone at some time, as did the other findings in that topic.
                              Many thanks, mate. :-)
                              • Andrius okA
                                Andrius ok @strawberry 3.141
                                Hello @strawberry-3.141 first Happy Holidays! and thank you for your answer. Yes I see now that only working with the Chromium browser on RPi3
                                After spending a day to find the solution on how to make work MM on Raspberry Pi Zero W with Chromium I found the solution and it works like a charm! :)
                                I tried many browsers (Midori, Kweb, Epiphany) no one is working correctly with es6 and css3 only Chromium.
                                There is link on how to make work Chromium on RPi W Zero:
                                https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=157049
                                Also on how to start Chromium with root (if someone is needed):
                                https://www.linkedin.com/pulse/20141028025215-79939846-google-chrome-and-chromium-as-root-on-kali-linux/
                                There is my start.sh script:
                                #! /bin/bash
                                node serveronly &
                                sleep 45
                                sudo xbacklight -set 100
                                sudo xinit /home/pi/startMirror.sh
                                and startMirror.sh script:
                                #!/bin/sh
                                xset -dpms # disable DPMS (Energy Star) features.
                                xset s off # disable screen saver
                                xset s noblank # don’t blank the video device
                                xbacklight -set 100
                                #Chromium Browser
                                matchbox-window-manager &
                                unclutter &
                                sed -i ‘s/“exited_cleanly”: false/“exited_cleanly”: true/’ ~/.config/chromium/Default/Preference
                                chromium-browser --start-maximized --noerrdialogs --kiosk --incognito http://localhost:8080
                                Everything the same config like there (only Chromium browser needed instead Midori):
                                https://forum.magicmirror.builders/topic/1183/how-i-got-my-magic-mirror-working-on-a-raspberry-pi-0-zero
                                Maybe for someone it will be usefull on how to start MM on Raspberry Pi Zero W with all features working.
                                Happy Holidays!
                                Reply Quote 2
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @Andrius ok
                                  @Andrius-ok said in MMM-Snow - Yet another Snow Module:
                                  Nice work! :-)
                                  • lavolp3L
                                    lavolp3 Module Developer
                                    Happy New Year everyone!
                                    I need to bring one neverending topic back again here:
                                    I tried to use MMM-Snow recently with a Pi 3B+ and stretch installed.
                                    Currently I have today’s MM 2.6.0 with electron 2.0.x installed, but I have tried electron v1.4.15 as well.
                                    The snowflakes are lagging on my mirror, not falling fluently. If I use the web version from a laptop it’s fluent, so it should be a browser issue.
                                    Config:
                                            module: 'MMM-Snow',
                                            position: 'fullscreen_above',
                                            config: { // See 'Configuration options' for more information.
                                                flakeCount: 40,
                                                theme: "winter"
                                    I have tried the kms driver, the fake kms driver (which gives me a flickering screen after some time for some odd reasons), and no kms driver at all. No recognizable change with regards to the snowflake performance.
                                    Is there any chance for fluent animations using electron at the moment that I have overseen?
                                    As far as I understand none of the electron versions work properly with hardware support. Is that true?
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
                                    bheplerB 1 Reply Last reply
                                    • bheplerB
                                      bhepler Module Developer @lavolp3
                                      @lavolp3 - Electron has always been a bit flakey with animations. Pardon the pun.
                                      I have 50 flakes running on the office mirror right now and it’s acceptable. But I haven’t upgraded the office mirror to the latest versions yet. If you need, I’ll swing by and check out what version it’s running.
                                      lavolp3L 1 Reply Last reply
                                      • rudibaraniR
                                        rudibarani Project Sponsor
                                        Dear all,
                                        would it be possible to have this module hidden until a weather module (e.g. MMM-DarkSkyForecast broadcasts a DARK_SKY_FORECAST_WEATHER_UPDATE) broadcasts a weather update that contains a snow forecast for today? That would be really useful :)
                                        • lavolp3L
                                          lavolp3 Module Developer @bhepler
                                          @bhepler That would be great thanks. Also, if you have one of the drivers enabled and what relosution you’re running.
                                          • bheplerB
                                            @lavolp3 - Will do. I should be at the office tomorrow. I’ll check it then.
