    MMM-RAIN-MAP (new: version 2.x)
    193 Posts 39 Posters 308.5k Views 42 Watching
    • JalibuJ Offline
      Jalibu Module Developer @plainbroke
      @pminich the same way. The German fork contains world wide map data.
      plainbrokeP 1 Reply Last reply Reply Quote 0
      • plainbrokeP Offline
        plainbroke @Jalibu
        @Jalibu
        Ok it finally found my location.
        The Lon and Lat where not registering in the module for some reason now they are… So all is good again…
          sdetweil @plainbroke
          @plainbroke said in MMM-RAIN-MAP (new: version 2.x):
          system is case sensitive, and " (quotes) around numbers become strings, which cause problems all over the place
          • O Offline
            Oboudreaux
            Does “substitudeModules” work in server only mode? “displayOnlyOnRain” works just fine but when the rain map pops up it appears under the module it’s supposed to hide.
            • H Offline
              hogedir
              I have an issue, I want to setup rain map to france, but I have that : NO MAP at all (with openmap) can you help me please? thanks.
              JalibuJ 1 Reply Last reply Reply Quote 0
              • JalibuJ Offline
                Jalibu Module Developer @hogedir
                @hogedir can you please create an issue on github for that? Without further information (config, version) it is hard to find the reason 😉
                • H Offline
                  hogedir @Jalibu
                  @Jalibu ok no problem. can you indicate me where i can find some logs for this module especially?
                  • JalibuJ Offline
                    @hogedir in the Browser‘s console log and net tab
                    • H Offline
                      hogedir
                      @Jalibu it’s simply a raspi 4B 8GB, with a normal installation of MMM. I don’t know if i need to open a bug, it’s just the dump of the map that doesn’t work as you see on the screen.
                      A question : Your module accept FRENCH locations no for the rain map ?
                      Your module works well here, it’s only the map that is not get.
                      I don’t have any blocker in the dns. so I don’t undertand because all the other modules works fine, except of that map dump.
                      Here is my config.js :
                      module: “MMM-RAIN-MAP”,
                      position: “top_center”,
                      animationSpeedMs: 400,
                      colorScheme: 2,
                      colorizeTime: true,
                      defaultZoomLevel: 8,
                      displayTime: true,
                      displayTimeline: true,
                      displayClockSymbol: true,
                      displayHoursBeforeRain: -1,
                      extraDelayLastFrameMs: 1000,
                      extraDelayCurrentFrameMs: 3000,
                      // markers: [
                      // { lat: 49.41, lng: 8.717, color: “red” },
                      // { lat: 48.856, lng: 2.35, color: “green” },
                      // mapPositions: [
                      // { lat: 8.717, lng: -2.725, zoom: 9, loops: 1 },
                      // { lat: 8.717, lng: -2.725, zoom: 6, loops: 2 },
                      // { lat: 48.856, lng: 2.35, zoom: 6, loops: 1 },
                      // { lat: 48.856, lng: 2.35, zoom: 9, loops: 2 },
                      // { lat: 49.15, lng: 6.154, zoom: 5, loops: 2 },
                      // mapUrl: “https://a.tile.openstreetmap.de/48.2649/{x}/{y}.png”,
                      mapUrl: “https://a.tile.openstreetmap.de/#map=8/48.471/-2.725”,
                      // mapUrl: “https://tiles.wmflabs.org/bw-mapnik/8/48.471/-2.725”,
                      mapHeight: “420px”, // must be a pixel value (no percent)
                      mapWidth: “420px”, // must be a pixel value (no percent)
                      maxHistoryFrames: -1,
                      maxForecastFrames: -1,
                      substitudeModules: [],
                      updateIntervalInSeconds: 300,
                      • JalibuJ Offline
                        @hogedir your configuration is buggy. Please read the module’s Readme.
                        You don’t have to (and should not) change the mapUrl at all.
                        Use mapPositions to justify it. The module should work world-wide.
                        I’d recommend to use the default values whenever possible and just to set values you need to override.
                        Does that work for you?
                         module: "MMM-RAIN-MAP",
                         position: "top_center",
                          mapPositions: [
                           { lat: 48.472, lng: -2.725 }
                        • H Offline
                          hogedir @Jalibu
                          @Jalibu Thanks. I copied your code, and nothing again. No map.
                          S JalibuJ 2 Replies Last reply Reply Quote 0
                            sdetweil @hogedir
                            @hogedir can you show the messages at mm startup?
                            either npm start or if you use pm2, then
                            pm2 logs --lines=50
                            • JalibuJ Offline
                              @hogedir I noticed there were wrong double quote characters in the code of my last post.
                              Please try again with the code below. Otherwise, please open an issue on GitHub and provide all the information asked in the form (entire config & logs)
                                mapPositions: [
                              • H Offline
                                hogedir
                                @hogedir @Jalibu it’s working now Thanks ! : the map is showing well now BUT the rain is not showed very well !
                                I compared what i see outside of my home and we had 5minutes before some rain and your data flow is not precise at all, i did not saw a rain in my region on your map but i saw it in weatherplaza.
                                I give you the page which is more precise and realistic than the rain data you have in the module : https://www.weerplaza.nl/regenradar/europa/frankrijk/
                                Map of rains with weather plaza : :
                                Map of rains with your module : :
                                Lots of difference, weather plaza is realistic (i checked outside 2 times yesterday, your module did not show well the rain.)
                                • Second thing, I noticed something too : i want the “pause” time before the red zone to be more fast (some mms more fast). is it possible to change the “pause timer” ? Thanks
                                • H Offline
                                  hogedir @Jalibu
                                  @Jalibu Look Here is the map of Weatherplaza (meteoplaza) in the same time than yours, if it can help.
                                  and then the data flow on the module (less rain and less precise) :
                                  thanks
                                    sdetweil @hogedir
                                    @hogedir it’s not ‘his’ data. he is requesting a graphic from a service, and displaying what they give.
                                    H 2 Replies Last reply Reply Quote 0
                                    • H Offline
                                      hogedir @sdetweil
                                      This post is deleted!
                                      • H Offline
                                        hogedir @sdetweil
                                        @sdetweil @Jalibu Obiviously !
                                        I mean it’s Rainviewer data but rainviewer is not 100% legit.
                                        weerplaza is the best radar information worldwide. They use sevral radar information worldwide and unite all these data for free. I think the only one very precise to offer this type of information.
                                        They have a widget API too ! you could integrate in addition to Openweather+rainviewer.
                                        The weerplaza api is here : https://www.weerplaza.nl/weerwidgets/
                                        And @Jalibu Thanks for your work, I like the zoom option and the ultimate option you added and it’s very useful.
                                          MajorC Project Sponsor
                                          I have also often had the feeling that Rainviewer’s data is not particularly accurate.
                                          If the option to switch to another provider were to be built in, I could only welcome that.
                                          • JalibuJ Offline
                                            Jalibu Module Developer @MajorC
                                            @MajorC @hogedir
                                            Unfortunately, Weerplaza.nl does not offer an API. I can’t just take their weather data and use it in MMM-RAIN-MAP.
                                            They only allow to embed their service as an iFrame. You can easily do this on your own with https://github.com/alberttwong/MMM-iFrame
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 9 / 10
