    [MMM-Remote-Control] Can not access remote control module
    76 Posts 21 Posters 74.5k Views 19 Watching
    • P Offline
      PaulB
      @Mykle1,
      thanks :-D
      call me dumb hahahahahahaha
      Unfortunately the modules are not loading now.
      But whats interesting is that if your Ip adress is like “12.10.0.xxx”, the module won’t accept it. If you give your devices a new static IP adress like “12.10.0.xx” then the module works fine. But shows a black screen.
        budwha
        I cannot get this to work also…I have added my PC and my phone to the white list, but both say it refused to connect. My “var config” is set to “localhost”…do I need to change that to something else…I am not sure what that part is asking for.
        • cruunnerrC Offline
          cruunnerr
          @budwha
          do it like Mykle said
          https://forum.magicmirror.builders/topic/1517/mmm-remote-control-can-not-access-remote-control-module/18
          B M 2 Replies Last reply Reply Quote 0
            sunnypurba @Mykle1
            @Mykle1 amazing, thanks!
              budwha @cruunnerr
              @cruunnerr Thank you…it works now.
                motdog
                hmmm stuck. I get the create a config screen Heres what I have
                var config = {
                	address: "0.0.0.0", // Address to listen on, can be:
                	port: 8080,
                	ipWhitelist: [], // Set [] to allow all IP addresses
                then on my config
                	        module: 'MMM-Remote-Control'
                	        // uncomment the following line to show the URL of the remote control on the mirror
                	        // , position: 'bottom_left'
                	        // you can hide this module afterwards from the remote control itself
                	            apiKey: ''
                thanks for helping the clueless rookie
                  stuartiannaylor
                  you have mm listening on all adapters 0.0.0.0 which correct but the 2[] brackets of your ip whitelist the other side is completely empty.
                  What is your routers address? Usually its something like 192.168.1.1 if it was that then 192.168.1.0/24 would allow any local ip to access connected internally on your network
                    motdog
                    @stuartiannaylor tried adding my router info but not successful
                      stuartiannaylor
                      yeah but you have wiped what there before have a look at :-
                      (3) For security reasons, the MagicMirror (and therefore the Remote Control) is not reachable externally. To change this, configure address, and ipWhitelist in your config.js (see these lines in the sample config). For example change address to 0.0.0.0 and add two allowed devices with IP-Adresses 192.168.0.42 and 192.168.0.50:
                      address : '0.0.0.0',
                      port: 8080,
                      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.42", "::ffff:192.168.0.50"],"
                      You can also add multiple devices in an IP range (e.g. all devices with 192.168.0.X):
                      ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/120", "192.168.0.1/24"],
                      Have a look at config.js.sample to get the originals back.
                      Then as it is above your router ip address might be 192.168.1.1 so it would be the above but with ::ffff:192.168.1.42, ::ffff:192.168.1.50  you can also put your router address in there but make the last octal 0/24 and you can then access from your desktop.
                      Then the next big thing you are missing is apiKey: "",         // Optional, See API/README.md for details
                        motdog @cruunnerr
                        @cruunnerr said in [MMM-Remote-Control] Can not access remote control module:
                        @budwha
                        I think I have yet I still am getting config screen.
                        var config = {
                        	address: "0.0.0.0",
                        	ipWhitelist: [],
                        	language: "en",
                        	timeFormat: 12,
                        	units: "imperial",
                        		        customCommand: {},  // Optional, See "Using Custom Commands" below
                        		        customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                        		        showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                        I also watched this and at 4:41 seem to have exactly the same thing.
                        https://www.youtube.com/watch?v=539zmAJREe4
                          Mykle1 Project Sponsor Module Developer @motdog
                          @motdog
                          Your config entry for MMM-Remote-Control is missing a comma after position: 'bottom_left'. It’s not your fault as I see you copied it directly from the readme. I removed the comments. Try this entry below;
                              module: 'MMM-Remote-Control',
                              position: 'bottom_left',
                                  customCommand: {},
                                  apiKey: "",
                          I have not tested this as I do not use this module. However, it should work for you unless something else is amiss in your config
                            motdog @Mykle1
                            @Mykle1 its weird. I have a working config. I add the module exactly as you have it, I follow the directions and it doesn’t work. I have tried adding my phone IP into the whitelist area, doesn’t work. I followed the directions from the video which match your suggestion of
                            var config = {
                               address: "0.0.0.0",
                               port: 8080,
                               ipWhitelist: [],
                            and still nothing. The crazy thing is I somehow got it working once before. then i had to rebuild my config and here I am.
                              @motdog said in [MMM-Remote-Control] Can not access remote control module:
                              Ok, just to be sure. You rebuilt your config and now MM errors at startup, telling you to create a config? Perhaps the error is generated by something else in your config. Please post your entire config.js file here, in a code block, so that all can see it. This way, any errors will be noticed more quickly.
                              Or, make a copy of the config.js.sample and rename the copy to config.js. This will get you up and running again. Then you can add one module entry at a time, saving each time you are successful. When an addition fails, you know where the problem is.
                                motdog @Mykle1
                                @Mykle1 my bad. I am confusing on this. I did a fresh reboot of the whole thing using Jesse instead of Raspian stretch and don’t have the start up issues. I rebuilt the config like I wanted with all of the modules working good. I then add the remote module and change the address etc and get the please make a config file error. As soon as I remove the remote control info things work again. So I know the error comes when I add this module. The frustrating thing is at a previous point I was able to get the remote control module working. That’s why I am confused but here is my working config without remote control.
                                Thanks for your patience with me on this
                                var config = {
                                	port: 8080,
                                	language: "en",
                                	timeFormat: 12,
                                	units: "imperial",
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_left"
                                						symbol: "calendar-check",
                                						url: "http://kuathletics.com/calendar.ashx/calendar.ics?sport_id=4&schedule_id=0&_=dd9bfb6f-df5f-4a47-9975-dd3bb74bd06a"
                                						url: "https://calendar.google.com/calenxxxxxxxxxxx7495e80bc22/basic.ics"
                                						url: "http://ical-cdn.tex3xxxxxxxxxx4e056117.ics"
                                						url: "http://ical-cdn.teamsnap.com/team_schedule/xxxxxxxxxxa68b.ics"
                                			module: "compliments",
                                			position: "lower_third"
                                	        module: 'MMM-NOAA3',
                                			    provider: "darksky",
                                			    apiKey: "6462c3f6d7c6dxxxxx311",
                                			    airKey: "WZzmCBxxxxxmBM",
                                		        css: "NOAA4",
                                			userlat: "x8.7xx9",
                                		        userlon: "-x0.5xx"
                                			  module: "MMM-NowPlayingOnSpotify",
                                			  position: "bottom_right",
                                			    clientID: "85d8bxxxxxxx",
                                			    clientSecret: "e6b226e4b819xxxxxx",
                                			    accessToken: "Bxxxi-UItbKL3NR1dQXpC8sJ1041J5NjVeafoAb3fGVsicRUataJodmfa1urp0akDwThbo",
                                			    refreshToken: "AQBP1w70KP5TqlxiFNgA4RU6mdTct0AHb58nasw2sEpl17iIz-uPDq9M0ifITQcOxxxxxx"
                                			  module: "MMM-MyScoreboard",
                                			  classes: "default everyone",
                                			  header: "My Scoreboard",
                                			    showLeagueSeparators: true,
                                			    colored: true,
                                			    viewStyle: "mediumLogos",
                                			    sports: [
                                			        league: "NHL",
                                			        teams: ["STL"]
                                			        league: "NBA",
                                			        teams: ["BOS", "GS", "HOU", "PHI"],
                                			        league: "MLB",
                                				teams: ["STL"]
                                			        league: "NFL",
                                			        league: "NCAAM",
                                			        groups: ["Top 25"]
                                			module: "currentweather",
                                				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                				appid: "YOUR_OPENWEATHER_API_KEY"
                                			module: "weatherforecast",
                                			header: "Weather Forecast",
                                				locationID: "5128581",  //ID from https://openweathermap.org/city
                                			module: "newsfeed",
                                			position: "bottom_bar",
                                				feeds: [
                                						title: "New York Times",
                                				showSourceTitle: true,
                                				showPublishDate: true
                                S Mykle1M 3 Replies Last reply Reply Quote 0
                                  sdetweil @motdog
                                  @motdog whenever you get the ‘create a config file’ error, run
                                  npm run check:config
                                  and work thru the errors from the top down
                                    @motdog
                                    I went and installed MMM-Remote-Control on a laptop running ubuntu and MM v2.5.0. I used this config entry:
                                    The module loads (bottom right):
                                    I’ll send a picture from my other machine. brb
                                      @motdog
                                      You can clearly see that it is working remotely.
                                      It would not allow connection with address: "localhost",. Take your working config and carefully add my entry for Remote-Control, address and ipWhitelist It should work.
                                        motdog @Mykle1
                                        @Mykle1 Awesome! Thanks so much for your help.
                                          @motdog
                                          So, does that mean that it’s working for you now? If so, mark the topic as solved.
                                            AshDarko
                                            Hi, i too have the same issue. I have changed my router IP to be something other than 192.XXX.X.XX
                                            Could this be the problem? I can access via browser on the Pi…?
                                            When i run the remote in browser on the pi, i notice in terminal this message:
                                            MMM-Remote-Control customMenu Requested, but file:/home/pi/MagicMirror/config/custom_menu.json was not found
                                            i receive an “Access Denied to IP address 10.100.10.1” in terminal and a message on m y phone saying the device is not allowed to access your mirror
                                            Here is config code:
                                            	port: 8080,
                                            	ipWhitelist: [ "127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:10.100.10.0/24",], // Set [] to allow all IP addresses
                                            	language: "en",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            And here is my module code:
                                            		/**position: 'bottom_left',**/
                                            			/**apiKey: "",         // Optional, See API/README.md for details**/
                                            The module code is pretty much the defaults.
                                            • 2 / 4
