    MMM-CalendarExt3
    688 Posts 82 Posters 2.8m Views 86 Watching
    • Z Offline
      zelmo @MMRIZE
      @MMRIZE Thanks a lot! Was about to suggest it just in case someone would run it horizontal. Then it might be useful and enough space. I’ll test out at least. Thanks again.
        Studio472
        I added an mlb team calendar. The little baseball symbol shows up on my google calendar on the web browser. In this module, the icon isn’t coming through. Is there a module or font-pack I need to install on my raspbizzle?
          MMRIZE @Studio472
          @Studio472
          Maybe emoji font should be installed to use/display emojis.
          https://raspberrypi.stackexchange.com/questions/104181/colored-emojis-in-chromium
          • W Offline
            whimsicality
            Hi, thanks for the work on this module. I am struggling to get it to load. I finally ran the npm dev through terminal and it is coming up with a number of errors… “failed to retrieve device information”, “failed to open kms_swrast”, “failed to open swrast”, “gpu process exited unexpectedly” exit_code=11", “failed to send GpuControl.createcommandbuffer” and then it looks like electron exited with signal “SIGINT”.
            Is this something I need to troubleshoot with the module itself or does this mean I need to fix something elsewhere? thanks!
              sdetweil @whimsicality
              @whimsicality
              for the mesa errors this is an electron/graphics engine problem. but you can turn off gpu use.
              in the script that starts mm, ~/MagicMirror/installers/mm.sh if you used my install script, add
              export ELECTRON_DISABLE_GPU=1
              above the line that does npm start
              • K Offline
                kasperinline @fedale
                @fedale
                I’m not able to get rid of the text “CW”. Can you help me, by sharing your lines.
                Regards
                • K Offline
                  kasperinline @kasperinline
                  @kasperinline said in MMM-CalendarExt3:
                  @fedale
                  Regards
                  Got i’t by myself, and learned a little more :-)
                  .CX3 .cw::before {
                  content: "CW ";
                  display: none;
                    MMRIZE @kasperinline
                    @kasperinline
                    Do that in your ‘custom.css’ not in the ‘MMM-CalendarExt3.css’
                    • K Offline
                      kasperinline @MMRIZE
                      @MMRIZE said in MMM-CalendarExt3:
                      @kasperinline
                      Yes of course :-)
                      Always in the ‘custom.css’
                        Studio472
                        I have an MLB calendar displaying my favorite team. West coast evening games span 2 days in my calendar (which looks goofy).
                        Is there a way to transform an event to only run 1 hour so it displays in a single day?
                        • 24
                        • 25
                        • 26
                        • 27
                        • 28
                        • 68
                        • 69
                        • 26 / 69
