    After update 2.23.0 crash
    56 Posts 9 Posters 32.7k Views 8 Watching
    • W
      Wenike @sdetweil
      @sdetweil By chance, do you know of a command I can run to kill any running Node processes? I’m trying to run your upgrade script and its unable to upgrade Node because a process is already running. Googling gives me code to use within an application but that doesn’t seem like it’ll work from the CLI.
      doing test run = false
      update log will be in /home/pi/MagicMirror/installers/upgrade.log
      Check current Node installation ...
      Node currently installed. Checking version number.
      Minimum Node version: v16.13.1
      Installed Node version: v10.24.1
      Node should be upgraded.
      A Node process is currently running. Can't upgrade.
      Please quit all Node processes and restart the update.
      running process(s) are
      pi 881 879 0 09:05 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
      • mumblebajM
        mumblebaj Module Developer @JerryP
        @JerryP Always use Sam’s update script. I used it last night and updated from 2.21.0 to 2.23.0 no issues. Often modules with a package.json requires an npm install in that folder and the upgrade script takes care of all of that.
          sdetweil @Wenike
          @Wenike do this
          from a terminal window
          ps -ef | grep node
          this will show you the node processes running and parms to what they are running (file path)
          if all looks understandable and u can’t terminate them thru app shutdown (pm2 stop all will stop all.managed apps, mm included), do
          ps -ef | grep node | awk '{ print $2 }' | xargs kill -9
          this will hard kill all the node processes
            sdetweil @JoeFranz
            @JoeFranz
            the script does a new npm install in modules that have a package.json
            but I know the post install process is wrong for this module
            my fork fixes that
            https://github.com/sdetweil/MMM-PIR-Sensor
            • W
              Wenike @sdetweil
              @sdetweil Perfect, fixed it. Thanks!
                sdetweil @JerryP
                @JerryP said in After update 2.23.0 crash:
                sudo git pull
                just one more thing
                NEVER use sudo with MM no need for it.
                all it does is lead to trouble
                • H
                  hrjmsh @sdetweil
                  @sdetweil Thank you very much. Had the same error (cannot find module envsub) on updating the MagicMirror to the new version and this step (rm -rf node_modules and then npm install again) solved the issue for me.
                  S T 2 Replies Last reply Reply Quote 0
                    sdetweil @hrjmsh
                    @hrjmsh you should use my upgrade script
                    • H
                      hrjmsh @sdetweil
                      @sdetweil I did, both with and without changes applied. Unfortunately, it didn’t work for me. The only thing that worked was the solution you provided by removing the node_modules and then reinstalling npm.
                        sdetweil @hrjmsh
                        @hrjmsh can u send me the MagicMirror/installers/upgrade.log
                        same userid at gmail
                        never seen this problem
                        • T
                          Techneek @hrjmsh
                          @hrjmsh Thank you so much!!! (rm -rf node_modules and then npm install again) worked like a charm!
                          • D
                            DanClarkCBET3
                            After installing the latest update (04/11/2023 10:00) I can not get Magic Mirror to start on my Windows systems. In this case I’m using the default CSS and config with no added modules. See attached photo. Please help.MM2_23.png
                              sdetweil @DanClarkCBET3
                              @DanClarkCBET3 yes, there is a reported issue on Windows
                              https://github.com/MichMich/MagicMirror/issues/3083
                              I was able to change some code (listed) to resolve it, but so far it only fails on windows. so we are not sure of the cause.
                              no fix currently planned
                              • D
                                DanClarkCBET3 @sdetweil
                                @sdetweil Thanks for the link. The suggested changes corrected my problem. Now the only problem I have is that the Alt key is not working but that is not a big problem.
                                  @DanClarkCBET3 ctrl-m will minimize
                                    @DanClarkCBET3 a fix has been pushed to the develop branch for the next release. the code is different
                                    to test the develop branch see
                                    https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                                    • 3 / 3
