    MMM-MyCalendar
    109 Posts 40 Posters 152.1k Views 38 Watching
    • ? Offline
      A Former User @j.e.f.f
      @j.e.f.f Hi jeff I have replaced the code as you said in the config file and still nothing :/ its showing the clock but nothing else on the page. Not even the loading anymore. Any ideas? & I think ive deleted my other post, it shows as greyed out now.
        j.e.f.f Project Sponsor Module Developer @Guest
        @PCPAYN3 Can you confirm you installed the module by following these steps:
        1. Navigate to the MagicMirror/modules directory
        2. Execute git clone https://github.com/jclarke0000/MMM-MyCalendar.git
        3. Add the relevant configuration to config.js
        4. Restart Magic Mirror
        And yes, your post shows as deleted.
        ? 3 Replies Last reply Reply Quote 0
        • ? Offline
          @j.e.f.f Thanks @j-e-f-f no I didn’t do that, I have done it now. And trying it out. Sorry im new to this, and really appreciate your help.
          • ? Offline
            @j.e.f.f After reboot it is now showing the second calendar i entered for UK holidays but not the top one which was my google calendar :( any ideas?
            • ? Offline
              @j.e.f.f Sorry to keep bothering you, i have everything on the screen now apart from the google calender. Can i embed in as an iframe on the html page? As i am familiar with html.
                @PCPAYN3 google calendar should work – I’m using two separate google calendars with mine.
                You can confirm that you got your ics link by following these instructions?
                (full instructions here: https://www.smsclientreminders.com/how_to_share_your_calendar_with_other_applications#google)
                • ? Offline
                  @j.e.f.f Hi jeff yes thats what ive done and got that link and still not showing. Do i edit the module to show this link? Or in the config file? As i tried to also edit the .js file in the MMM-Calendar module but it said permission denied when saving.
                  • ? Offline
                    A Former User
                    As I know, private calendar sharing works only in Google Calendar. If you want to use calendar in other application, you should use public calendar. (I might be wrong.)
                      I worked with @PCPAYN3 over chat to figure out this issue. For anyone else this might help, the problem was as follows:
                      The following error came up in the log:
                      Error: dates lower than Thu Jan 01 1970 00:00:00 GMT-0500 (EST) are not supported
                      A bit of Googling pointed me to this thread:
                      https://forum.magicmirror.builders/topic/2208/calendar-shows-no-entries-after-mm-update/29?page=3
                      Apparently the problem is that there is an entry in the calendar that has a date prior to Jan 1, 1970. The solution was to edit the following file:
                      /home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js
                      and change the ORDINAL_BASE property on line 56 to an earlier date.
                      example, I changed:
                      ORDINAL_BASE: new Date(1970, 0, 1),
                      to
                      ORDINAL_BASE: new Date(1900, 0, 1),
                      and then the calendar worked.
                      Z B 2 Replies Last reply Reply Quote 3
                      • Z Offline
                        zzaidi148 @j.e.f.f
                        @j.e.f.f Hi Jeff! I love your module and its been easily booting up nicely. However, I tried adding two of my google calendars on it, and as I booted the module it up, it loaded and said no upcoming events. While today I dont have any events, tomorrow I do. I set the max number of days in the future to a huge number but stilll nothing. Any ideas?
                        J C 2 Replies Last reply Reply Quote 1
                          j.e.f.f Project Sponsor Module Developer @zzaidi148
                          @zzaidi148 Can you confirm that you got your Gmail ICS link by following the instructions here?
                          If so, send me a private message and I’ll troubleshoot your config.
                            bmarofsky @j.e.f.f
                            @j.e.f.f Thank You! Spent 3 days trying to figure this out after my SD card corrupted and I had to rebuild my MM.
                            (making sure I remember where I store my backup .img)
                              Buggy
                              Hi all. Has someone seen this? Today ist the 4th. The second term is wrong “heute” (today) and the third term is correct “morgen” (tomorrow)
                              • ? Offline
                                A Former User @Buggy
                                @Buggy
                                I don’t know why creater leave this issue until now, but there is a hot-fix about that.
                                https://github.com/jclarke0000/MMM-MyCalendar/issues/3
                                B J 2 Replies Last reply Reply Quote 1
                                  Buggy @Guest
                                  @Sean Thank you. I will apply this hot-fix.
                                    @Sean I’m currently moving to the UK, so I haven’t had time to fix this. If the hot fix worked for you, then great! I probably won’t get around to addressing this until sometime in the new year.
                                    • N Offline
                                      nitram @j.e.f.f
                                      @j.e.f.f Hi all, firstly thanks for this module - it’s fab. I’m having the exact same issue as above with today/tomorrow not working properly. I tried applying the hotfix, but it didn’t seem to work for me (though that was quite a way beyond my skill level so I could have done that wrong!). Has anyone else got this sorted?
                                        rrrene
                                        Hello,
                                        first of all thanks for the great looking module.
                                        Unfortunately I don‘t get it up on my side…
                                        It doesnt‘t show anything no matter if I load your example ics or my iCloud calendar Url (is this supposed to work?)
                                        Below you can see my module config, maybe someone can help me out :)
                                        		module: "MMM-MyCalendar",
                                        			maximumEntries: 6,
                                        					url: "http://calendarlabs.com/templates/ical/US-Holidays.ics"
                                        Thanks in advance.
                                        Best regards,
                                        René
                                        • H Offline
                                          Hotstepper @rrrene
                                          This post is deleted!
                                          • H Offline
                                            Hotstepper
                                            @rrrene said in MMM-MyCalendar:
                                            Hello,
                                            I have had the same issue and have searched the error for a while…
                                            My fault was, that the entry in the “MMM-Carousel”-Module in the slides-Section was missing.
                                            So the Module wasn’t showing.
                                            		module: 'MMM-Carousel',
                                                            		slides: [
        ['MMM-MyCalendar',.....],
                                            Best regards
                                            Lutz
                                            • 6
                                            • 3 / 6
