    MMM-MyScoreboard
    Scheduled Pinned Locked Moved Sport
    277 Posts 60 Posters 635.7k Views 63 Watching
      SH20192 @sdetweil
      @sdetweil said in MMM-MyScoreboard:
      @SH20192 if you open the developers window on the client, ctrl-shift-i, select the console tab and scroll up… do you find any errors? usually red text
      Did some troubleshooting on this. Appears to be a conflict between this modules and MMM-GoogleMapsTraffic. If I disable that module then MMM-MyScoreboard works. That modules doesn’t impact any other modules though. Attached pic is the error it shows. Any thoughts? Like I said this only does this with clientonly.
      https://imgur.com/a/FcJbruR
      • CyruS1337C
        CyruS1337 Project Sponsor @j.e.f.f
        @j-e-f-f No, unfortunately not
          sdetweil @SH20192
          @SH20192
          edit MMM-Scorebpoard.js and change line 552 to
           Log.log("[MMM-MyScoreboard] Updating Scores");
          • N
            nona @BKeyport
            @BKeyport
            I also encountered with same problem. I tried troubleshooting but it didn’t worked for me. i created my account with the help of onlyfans hack.
            • L
              lotusvball
              Trying to install this and there is an issue with cryptiles . It won’t install and need upgraded cryptiles to version 4.1.3.
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @lotusvball
                @lotusvball for me it works fine, I have set up German leagues
                • L
                  lotusvball @Stoffbeuteluwe
                  @Stoffbeuteluwe So I misunderstood the message. It installs but gives a high vulnerability warning. It still needs to be fixed to fix the vulnerability.
                    sdetweil @lotusvball
                    @lotusvball sometimes u can fix those…
                    npm audit fix
                    sometimes u can’t as no fix is available yet
                    • L
                      lotusvball
                      tried that and it say that it needs done manually. I see the code in the .js part but don’t know how to fix it.
                      • L
                        lucallmon
                        @j-e-f-f is there a way you can change how often it updates the scores? what is the default set to? I’d like to change it to every 15 minutes. Thanks and standing by.
                          smoysauce
                          Any clue why it would only show Final score and not future or in progress? I have been looking through the code, comparing the ESPN feed to everything I can’t seem to figure it out.
                          • E
                            ensch25
                            Is there a way to change the time format into a 24h look?
                              socosurf
                              Is anyone else not having NBA scores populate? Is the module not supposed to show the scrimmage scores?
                              J 2 Replies Last reply Reply Quote 0
                              • J
                                j.e.f.f Project Sponsor Module Developer @socosurf
                                @socosurf the module gets its scores from a SportsNet.ca feed. If you see scores for games on their web site, then you should see them in the module. But I don’t think SportsNet has historically had exhibition games in their feed.
                                • J
                                  @socosurf actually I think for NBA the feed is from ESPN. In any case, same general idea applies. If you don’t see scores for these matches in the web site then you won’t see it in the module.
                                  • M
                                    motdog
                                    MLS scores don’t seem to be updating. Am I the only one with issues?
                                    • J
                                      JRichardson10
                                      Hi complete coding and raspberry pie newbie here, I was wondering if it’s possible to add a code sequence that allows you to only show the results from one sports division/league at a time and fade between all the listed divisions/leagues I’ve included in config.js file, similar to how it’s fades between each sports league table in the ‘MMM-MyStandings’ module. I’ve tried looking through the ‘MMM-MyScoreboard.js’ file but cannot find any solution.
                                      Apologies if this is a really simple solution, I’m very new to this😅. Any help would be greatly appreciated!
                                      • E
                                        Egnos
                                        Hi everyone, many thanks for the module, it is really beautiful!
                                        Is it possible to freeze match results until the next match?
                                        Now after the games have finished the results disappear …
                                        • BKeyportB
                                          BKeyport Module Developer @Egnos
                                          @Egnos Short answer: No. Long Answer: Noooooooooooooooooooooooooooooooooooooo.
                                          Due to the data feeds, the match is cleared as soon as they set up the new ones. You’d be better off to use a module specific to your target league for that, where the author took the time to cache results.
                                          • E
                                            Egnos @BKeyport
                                            @BKeyport thanks.
                                            If I set “rolloverHours” configuration parameter with a very high number … like 100?
                                            When the match schedule is updated would it change?
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 11 / 14
